Question about Intel Motherboard
Need upgrade Memory for Intel D865GLC/D865PESO
I have 2 memory cards totally 1g. Two slots remain. I am interested in adding more memory. Size and whether they need to be in pairs or not.
    Sergeant:
    Champion:
  • 265 Answers
You have 1G, you can go up to 2G without any issues. If you go to 4g you will only use 3.2g unless you are using a 64bit operating system.
This motherboard has some quirks, you can read about it at
http://www.intel.com/support/motherboards/desktop/d865glc/sb/CS-027110.htm
I think your best bet is to buy something like this
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145440&cm_re=ddr400-_-20-145-440-_-Product
If your new RAM is 'faster" than what you have, it will automatically match the speed of your older/slower ram.
Posted on Jul 06, 2010
  • Gummy D Milo Jul 06, 2010
    Add a few things..
    Run CPUID on your computer, small little software that will tell you about the details without having to open the case or go into the BIOS.
    And as putercare said matched pairs are better, but you have to install them in the same channel (A/B) - this won't be an issue for you unless you remove RAM and then mix them up while they are on your desk.
    Novelist:
    Champion:
  • 226 Answers
If you goto www.crucial.com and use their memory checker tool you can find out which RAM you need as well as the maximum your motherboard can handle.
Next open your desktop or the section on the base of your laptop where the RAM resides to make sure you have a spare slot and how many slots you have.
It is recommended if installing more than one memory module that you used a matched pair. This is to ensure compatibility. A matched pair is when you buy two of the exact same modules (same spec and manufacturer, model etc.).
Hope this helps,
www.PuterCare.com
What is the fastest compatible CPU for upgrade Asus X50GL series laptop
changing chips most time requires a mother board up date to cater for the extra chip pins
best advice here is to take it to a computer repair shop and they will be able to tell you right off if what you want to do is possible with that board
point of interest here
chips are only as fast as the hard drive and rams will work
if your unit has a disc type hard drive consider upgrading that to a solid state hard drive which handles data much much faster than a disc type
just a bit of info when you are talking to the computer geek
Oct 05, 2016 | ASUS Computers & Internet
Which RAM is suitable for Intel presscott 533 motherboard for upgradation
The Mother board only supports DDR1 333mhz or 400mhz
Maximum size of memory the board can read is 2gb in total
I would suggest upgrading to at least a DDR2 Motherboard
May 27, 2011 | Intel Motherboard
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
Added 1G memory, for a total of 2GB. the system still only sees 1G
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Microsoft Windows 32-bit version operating systems.
If you install Windows 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met: 1. The memory controller which supports memory swap functionality is used. Chipsets later than Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture support memory swap function. 2. Windows 64-bit OS which can address more than 4GB memory. You can check below URLs for reference:
http://dlsvr.asus.com/pub/ASUS/mb/4GB_Rev1.pdf
hope this helps
Apr 18, 2011 | ASUS P5RD2-VM Motherboard
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
Compaq Presario Notebook V3000T I replaced the 2-256mb memory cards with 2-1g memory cards. System boots up but only reads 1024mb?
Thanks to Microsoft Knowledge Base for help with my answer:
First, find out what the maximum amount of memory is. This is generally listed by most of the manufacturers. This will let you know what upgrade potential the system has. Next, determine how the memory configuration is when you buy the system. For example, a laptop that has 2GB of memory can be configured as either a single 2GB module or two 1GB modules. The single memory module allows for better upgrade potential because by adding another module you are gaining more memory without sacrificing any current memory. Upgrading the two module situation with a 2GB upgrade would result in the loss of one 1GB module and a memory total of 3GB.
Jul 07, 2009 | HP Compaq Presario V3000T Notebook
How can i increase the memory of my dell optilplex sx260, with an intel 845 chip? i only have 8 mb graphic memory
You can't. The video card is integrated and there is no expansion slot available to upgrade it.
You can increase the total RAM on the computer by adding a larger piece or an additional piece, but this will not affect the graphic memory.
Feb 21, 2009 | Intel Motherboard
Can you add to much Ram for the processor to handle?
That additional RMA will be good for your computer so it will be much faster and don't worry everything should work fine there after adding new RAM to your computer....
Jan 13, 2009 | Intel Computers & Internet
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Intel Motherboard Logo
238 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
