Question about Epson LQ-1050 Matrix Printer
Pitch Settings How down I change the pitch settings on the Epson LX 1050
    President:
  • 2,692 Answers
Pitch control doesn't work
Make sure that the "Pitch" button is turned on (LED is lit) before trying to change the pitch. If it is, make sure that it's not disabled in the settings.
May 18, 2012 | Numark CD MIX 1 Integrated Dual CD Player...
Hello icant change settings of my button pitch and font..my printer is epson fx 2175..i had search that the problem is Font and Pitch lock mode..how to unlock it?
switch on the printer while u holding the pause button and leav it aftre 7 seconds it will print the default setting page.later on you can change it according to the paper setting.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 27, 2010 | Office Equipment & Supplies
How to change pitch from 10cpi to 12cpi in Epson lx300+II
A complete user manual can be downloaded HERE.
Follow the instructions starting from page 2-19.
Dec 23, 2010 | Epson LX-300+ II Matrix Printer
Gemini CDJ02 - Pitch Control Slider Stuck @ 0% The Pitch Control Slider will pitch down all the way but sometimes it will randomly change pitch and most the time wont pitch-up past 0.1-0%. This happens on...
Your pitch control is faulty or dry. Try spraying wd 40 into the pitch sliding hole form top to bottom. Dont over spray it. Just a bit from top to bottom will do. If issue still persists, then there's some capacitors are weak which controls this pitch.
Jan 15, 2010 | Philips Gemini CDJ-20 Top Loading...
How do you change the pitch or size of the type? The typewriter has 3 pitch settings, but we cannot figure out how to make the adjustment.
hold down "code" key and press 6 for 10 pitch. "code" key and press 7 for 12 pitch. "code" key and press 8 for 15 pitch. to change type size or style you have to replace the daisy wheel.
Nov 10, 2009 | Smith Corona Wordsmith 100 Typewriter
How to change the pitch?
Here ya go...
Margins and Tabs
Margins and tabs for both Type Mode and Mem Mode are set in Type
Mode, but can be changed in Mem Mode when text is recalled for
editing. Margins and tabs are set using the typing scale which appears
on the display in Type Mode. A blinking cursor indicates the typing
position. The letter “L” indicates your left margin setting. The letter “R”
indicates your right margin setting.
NOTE: In Mem Mode, the margins and tabs used when the text
is created will be saved with the text and recalled with it,
even if they have been changed.
Margins
In Type Mode, to signal that you are near the right margin, the
typewriter will beep 5 spaces before the margin. In Mem Mode, the text
will wrap automatically when you print.
Margins are preset depending on the pitch setting, which is the number
of characters per inch. They are:
10 Pitch 12 Pitch 15 Pitch
(Pica) (Elite) (Micro)
Left Margin 12 14 18
Right Margin 72 86 108
New margin settings remain until changed again.
1. Move the Mode Selector to Type. A typing scale appears on
the display.
2. Move the cursor using the Spacebar or Back Space to the desired left
margin setting on the scale.
3. Press Margin.
4. Move the cursor using the Spacebar to the desired right margin
setting on the typing scale.
5. Press Code + Margin. A beep confirms each new margin setting.
6. You can change to Mem Mode, if desired.
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
Jun 02, 2009 | Office Equipment & Supplies
Serial port settings Epson LX-300+
Make sure you have at least 10 sheets of paper loaded.
Turn the printer off for at least 5 seconds, hold down the Tear-Off button, turn it back on, then release the button when the language menu starts printing.
After the language menu prints, verify the left and right Font light are off and the Pause light is on (for English). If not, press the LF/FF button until the lights are lit in this order. Press the Tear-Off button to select English.
Once the current settings print, press the Tear-Off button to enter setup. Follow the directions to change the serial port settings.
Mar 13, 2009 | Epson LX-300 Matrix Printer
Changing Pitch
use Epson remote utility to change any configuration
Mar 13, 2008 | Epson LX-300 Matrix Printer
PITCH Changing
you must enter in set up mode to printer,press the lf/ff buton and turn on the printer-that is the case in one type of setup firmare ,if you not enter in set up mode to try the same way with other buttons.in the set up printer print you the small guide,then you must foolw his until you reach a change pitch.
Mar 08, 2008 | Epson LX-300 Matrix Printer
640 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
