Question about Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117
I need to change it from the foot contorl to strike arc welding. How do i change it oof hf?
I doubt I can tell you, if you got the machine and can't read the panel.
Posted on Jul 21, 2010
Tip
Prone to arc eyes from welding?
If you have a conventional flip lens welding helmet and are prone to getting arc eyes from "peeping" though a gap to strike your arc, try this.<br /> Replace the inside fixed clear lens in your helmet with a yellow perspex lens. The world will appear strange at first through the yellow lens, but the yellow cuts out the ultra violet rays that cause arc eyes. The yellow lens should not be considered a replacement for the dark glass, it is only to shield you from that inadvertant flash when making your strike.
on Jan 19, 2011 | Welding Tools
What polarity do I use for tig welding aluminum, and what color electrode for miller hf-p dial arc
Jackie, watch the linked videos on tigging aluminum. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 31, 2016 | Miller Welding Tools
When using foot pedal for tig welding,does foot control ,increase voltage,and control the argon valve
The flow of the gas will be initiated and terminated by the use of the pedal, but it does not change the flow rate, just on and off. You will adjust your desired flow rate at your flow meter or regulator. I prefer a flow meter as I find them to be more accurate and easier to use.
The foot pedal will initiate and terminate the arc when used on a HF start tig welder. It works like a gas pedal. For example, if you have your machine set to 100 amps, by pushing all the way down on your foot pedal you'll get 100 amps. Some guys will set their machine wide open and just control the amperage with the foot pedal. I don't do it like that, although there is nothing wrong with doing it that way. I like to have a bit more sensitive amperage control. I will set my machine a little higher than I think I need and feather the foot pedal from there. This allows me to start at a low amperage and also taper off a bit smoother at the end.
Jan 18, 2016 | Welding Tools
What electronic part is damaged?
Does the electrode stick to the metal? In which case your problem is with the elctrode or your method of striking the arc.
Jul 24, 2013 | Welding Tools
Welding rod sticking when striking arc
try striking the rod like a match. keep a good arc, not too long or short. try around 90 amps.
Apr 28, 2013 | Lincoln Electric K1170 AC-225 Stick Welder
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
I am getting holes appearing when I stop welding. There is nothing wrong with the gas (pressure/post/preflow checked) as i have checked it all out. I have put a new torch on and a new regulator but it has...
Wow what a great machine. You have so many options that you should be able to control the ending arc. Yes, you should be able to adjust the intensity of the HF. Also if you use the Sequencer Control, you should be able to finish the weld in a slope manner. I am including the owners manual. Operation starts on page 38. Miller has a team of welding engineer that will be able to help you set up your machine. Wish I had one.
Oct 04, 2017 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
My Lincoln SA 200 welder will not rev up when I strike an arc.
Need code number to be exact, but sounds like the wiring to the current transformer is incorrect.
Sep 17, 2009 | Lincoln Welding Tools
Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117 Logo
100 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
