Question about Symbol MC70
I have an mc70 and when I try to connect the wi-fi it appears an error: adapter unavailable. what's the reason and how can i fix this?
My ip adress says unavailable
Sounds like the computer you're trying to connect to your wi-fi router is set up with a static IP address that is being reserved by your router for DHCP. To resolve, make sure your router has "DHCP" (dynamic host configuration protocol) turned on. Make sure the computer you're trying to connect to your router is set up to allow the DHCP server in your router to set the computer's IP address and DNS server address. You can find instructions to enable DHCP in your router's user manual or by searching online. You can find instructions for setting your computer's wireless adapter to allow the DHCP server in your router to set the computer's IP and DNS addresses here:
http://www2.wolfson.cam.ac.uk/files/IT/Settings_for_DHCP_for_Windows.pdf
Jan 07, 2014 | Computers & Internet
Try to connect my huawei h866c to wi-fi and the connection comes up with error
IN ANY PLACE? SOME TIMES THE ROUTER HAVE PROBLEM WHEN DETECT DIFERENT WIFI ADAPTER (WIRELESS B,G,N)
MUST TRY ASSIGN IN NETWORKING ROUTER USE ONLY G IF YOUR ROUTER DONT ASSIGN IP REBOOT YOU ROUTHER
Dec 17, 2013 | Cell Phones
My wifi stop working,i dont know why???
Solutions to Common Android WI-Fi ProblemsFriends of mine who use an Android come over to me usually with problems related to their devices' Wi-Fi connectivity. Moreover, it's not a single isolated issue. There are all kinds of them they bring up. I usually fix their problem after few troubleshoots but today while I was fixing a problem on my device, I realized that it could happen to any one - even to my readers on Guiding Tech. Hence we are going to discuss four of the most common Android Wi-Fi problems and see the probable causes and solutions to them.
Android Cannot Scan a Wi-Fi Network Reason
There may be two reasons as to why your Android cannot scan a network automatically. The first reason may be that the network you are trying to connect to could be Ad-Hoc in nature. As most of the Android phones are not configured to work on Ad-Hoc networks but on access points, they don't scan them.
The second reason may be that the Wi-Fi network you are trying to connect to might be hidden for security reasons.
Solution
By default, Android does not support Ad-Hoc Wi-Fi network but many developers patch the wpa_supplicant file on Android in order for them to work. If you do a quick Google search you will be able to find if there's a fix available for your device but the fix can only be performed on a rooted phone. Furthermore, don't forget to back up your original wpa_supplicant file if at all your phones goes into foreclose or boot loops.
If the problem is with the hidden network, you can try to add the network manually. In Android Wi-Fi settings open menu and tap to add a network manually. You must enter the correct SSID and authentication type and password in order to connect to the network. If both the credentials are correct, the Android phone will be able to connect to the network.
Wi-Fi Keeps Disconnecting Frequently Reason
The most obvious reason for the problem may be with the Wi-Fi Sleep Policy which disconnects your Wi-Fi every time your Android goes to sleep to save your battery's juice.
Solution
To manage Wi-Fi Sleep Policy, open Advance Wi-Fi settings on Android and tap the option Keep Wi-Fi on during sleep. Here, check the option Always to enjoy an uninterrupted connectivity, but you will have to compensate it with your battery life.
If you are using any third-party app to save your battery, check if it's controlling your Wi-Fi and other radio services and configure accordingly.
Obtaining IP Address Infinite Loop Reason
I don't know the exact reason behind this, but it might be a bug in Android. I have seen many people getting this problem, and it gets kind of annoying when the problem does not gets fixed even after restarting the device.
Solution
First of all, you must restart your Wi-Fi router and see if that helps. Many people say that resetting the phone to factory state works but that's not an appropriate solution. Wi-Fi Fixer is an amazing Android app that can help you here. The app resets your Wi-Fi system files (same as when you reinstall the Wi-Fi drivers in Windows, or you disable and enable the Wi-Fi adapter) and services and helps you to connect to the network and obtain the IP address.
Solutions to Common Android Wi-Fi Problems
Ads by Google
    wifi-router.pngFriends of mine who use an Android come over to me usually with problems related to their devices' Wi-Fi connectivity. Moreover, it's not a single isolated issue. There are all kinds of them they bring up.
    Solution
    ad-network-manually.png If the problem is with the hidden network, you can try to add the network manually. In Android Wi-Fi settings open menu and tap to add a network manually. You must enter the correct SSID and authentication type and password in order to connect to the network. If both the credentials are correct, the Android phone will be able to connect to the network.
    Solution
    Ads by Google advanced-settings.pngkeep-wifi-on.png If you are using any third-party app to save your battery, check if it's controlling your Wi-Fi and other radio services and configure accordingly.
    Solution
    wifi-fixer.png If you know the range of IP address the router is broadcasting, you may configure your Android to use static IP address while connecting to the network.
    Can't Connect to Internet using Wi-Fi Reasons
    There may be several reasons as to why you are not able to connect to the internet even when you are connected to the Wi-Fi. The reasons may be:
    • The router is not broadcasting internet services.
    • The IP address or the gateway is wrong.
    • Problem with the DNS settings.
    Solutions
    You may use another device to check if the router is actually broadcasting internet. Also you can configure the IP address, the gateway and DNS manually to connect as their might be problems with DHCP.
    Conclusion These are pretty much most of the Android problems one might encounter on his device and the probable solution one can try to fix the problem. I don't guarantee that you will fix the problem but it's a good start nonetheless. And most of the solutions should work actually.
Thanks .
Sep 03, 2013 | Cell Phones
The router is blinking a yellow light
Here are some of the more common reasons that the status light may blink amber:
  • The Wi-Fi base station has not yet been configured because it is new.
  • The Wi-Fi base station has been reset.
  • A new firmware update is available for the Wi-Fi base station.
  • No IP address is available for the Wi-Fi base station.
  • A Wi-Fi base station in Extended Mode is out-of-network Wi-Fi range of a primary Wi-Fi base station.
  • The WAN Ethernet cable is unplugged from the Wi-Fi base station.
  • The Wi-Fi base station lacks a path to the Internet (or local router).
  • Internet access may be temporarily unavailable from your Internet Service Provider (ISP).
  • Your AirPort Time Capsule has detected that the internal hard drive has reported a SMART error, and is failing (This requires firmware 7.5.2, and AirPort Utility 5.5.2).
Feb 10, 2011 | Apple AirPort Extreme Router
I have a strong wi-fi connection. But when trying to get on the internet, I keep getting cannot find server or DNS error internet explorer
DNS Error Fix
In most cases, a DNS error just means that the computer is facing connectivity problems. This could be happening for a variety of reasons, especially if you are connecting to the Internet via a wireless connection. Since DNS transforms the website URL into a numerical IP address, without the DNS functioning properly, the Internet connection will be quite useless. There are a few solutions to this problem though, and none of them are too complicated in nature.
  • Locate the networking icon on your taskbar (or visit the networking tab from your 'Start' menu), and right click on it. Now select the 'Repair' option. This should be able to fix elementary DNS errors.
  • Go to the 'Start' menu and select the 'Run' option. Now type 'ipconfig/release' and hit 'OK'. This will release your old IP address. Now you need to type 'ipconfig/renew' and hit 'OK' in order to renew your current IP address.
  • You even have the option of entering your own DNS settings. If you are using a local wireless connection, you will be informed about the preferred DNS and the alternate DNS. You can alter this setting by going to the 'Properties' of your network connection.
  • You must also check if all the cables and wires are connected properly. If nothing works, then try using a different machine with the same connection.
Dec 30, 2010 | Sylvania G-Netbook
Ipod wi fi conection
Wi-Fi Functionality
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon (307189_1.jpg) next to them.
  3. Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon (307189_2.jpg) in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
  1. Turn Wi-Fi on or off.
    Choose Settings > Wi-Fi and turn Wi-Fi on or off.
  2. Set iPod touch to ask if you want to join a new Wi-Fi network.
    When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon (307189_1.jpg).
    If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
    Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
  3. Join a Wi-Fi network manually.
    Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
  4. Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wi-Fi and tap the arrow (307189_3.jpg) next to a network you've joined before. Then tap "Forget this Network."
  5. Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks).
    Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
  6. Adjust settings to connect to a Wi-Fi network
    Choose Wi-Fi, then tap the arrow (307189_3.jpg) next to a network.
Dec 27, 2010 | Cisco Linksys Wirelessn Router Black...
On my PDA MC70 it is showing WI-FI "unavailable"
This can get kind of complicated, and your wireless carrier may block this depending on the data plan. It's also different for the MC7095 (CDMA) and MC7094 (GSM/GPRS) models. You may also want to see if your device BSP release is up-to-date.
Here is some basic info for the MC7095 (Sprint):
Device was not connected to network to start.
Went to Start, Programs, Internet Sharing, tapped Connect, showed Status: Check USB connection. Internet Sharing drivers were installed on laptop computer, then device displayed Internet Sharing Status "Connected". We were able to browse the web on the laptop computer. Closed out of Internet Sharing (tap X on upper right hand corner). On device, tapped Start, Internet Explorer, attempted to browse to a webpage. Able to browse on both laptop computer and MC7095 device.
Note: Attempted to Disconnect the Internet Sharing session, unable to. The device does not appear to respond to the "Disconnect" option on bottom left of screen. When tapping "Disconnect" the option light up as if being tapped however the device itself shows no other changes and Status still displays :Connected.
***FYI*** In testing with a different MC7095 (BSP33) we experienced the same issues with not being able to "Disconnect" the Internet Sharing session.
Jan 29, 2009 | Symbol MC70
Wii wireless connction has error code 51040
rror Code: 51040 Please try the following troubleshooting for the Nintendo Wi-Fi USB Connector
  1. Verify that the Nintendo Wi-Fi USB Connector is installed correctly and that the PC is turned on (the USB Connector will not work while the PC is turned off).
  2. Try our interference troubleshooting steps.
  3. Are you using any security programs (firewall, anti-virus, anti-spyware, anti-adware, etc.)? If so, you may need to add the Nintendo USB Registration Tool software to a list of "allowed" programs or "exceptions." If this is unavailable, you may need to disable yousecurity program before the Nintendo Wi-Fi USB Connector can access our servers. See Nintendo Wi-Fi USB Connector "Firewall troubleshooting" for more information.
  4. Try uninstalling the Nintendo Wi-FI USB Connector software, and installing the newest version. To get uninstalling instructions and the latest version of the software, please click here.
Nov 29, 2008 | Nintendo Wii Console
Symbol MC70 Logo
597 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
