Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Maytag jetqueen door leak
Maytag jetclean dishwasher leaking at left side of door
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dfg
Posted on Sep 29, 2010
Maytag dishwasher leaks thru from door just installed testing with no dishes
check for shipping materials left inside , check for damaged door seals or bent door. check float switch operation
Jul 19, 2010 | Maytag MDB9600A Jetclean II Built-in...
The spongee seal at the bottom of the dishwasher door is leaking. How can I fix it?
Leaking Dishwasher
heatman101
retodfkjhgofd
Jul 11, 2010 | Maytag 24 in. MDB5600A Jetclean II...
My Maytag washer leaks at the door. It doesn't
f you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Rate the solution..
Jul 10, 2009 | Maytag 24 in. MDB5600A Jetclean II...
MAYTAG JETCLEAN QUIET PACK
hi Replacing the Door Gasket
If water leaks through the dishwasher door, the gasket is probably faulty. Open the door and examine the gasket. It should be soft and resilient. If it's worn, cracked, or hard, it should be replaced.
Once the gasket is in place, check it for fit against the door frame. It should fit tightly with no cracks or bulges between the gasket and the frame. If necessary, tighten or loosen the retaining screws, or refit the gasket in the clips or the door channel. Then run the machine through a washing sequence and check for leaks.
If you spot a leak, and the gasket seems to be properly in place, try adjusting the door latch. The trick is to position the gasket against the frame of the door without flattening the gasket or squeezing it too flat when the door is latched properly. Adjust the latch or the gasket until it fits snugly against the door frame.
Oct 10, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Leaking water
Try to touch the lower door seal, it sometimes jumps out of its place when you open the dishwasher door. You may consider replacing the seal with a new one, I have to push the seal on my dishwasher to its proper place before every cycle. It is quite annoying, but free :-)
Aug 20, 2008 | Maytag 24 in. MDB8600AWS Jetclean II...
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
589 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
