Question about Bush Televison & Video
I bnought a 32 inch bush A632N at the weekend for my bedroom and since it's been installed, I don't seem to be able to get Skt tv on it. I have Sky already installed in the bedroom but the connection that I used to use for the previous television does not appear to give me Sky on my new one. I have 2 inputs coming in to the room, one from the external aerial and the other from the sky dish that has a small connection on it that is what takes the signal from the remote control. I have used this connection and plugged it straight into the television. The other external aerial cable is therefore obsolete...any ideas as to what the solution is?
    Top Expert:
  • Bush Master
  • 23,707 Answers
That is because it is freeview, not satelite.
Posted on Apr 07, 2017
SOURCE: av 1 shows on the screen and wont go off when watching sky
yes select tv on sky r/c and press info, it will go.
Posted on Apr 11, 2008
SOURCE: Remote code required for UK Bush tv model WS6680SIL/C7
Found the correct code for my TV & Sky remote... I searched a fair bit more on google for... "WS6680SIL/C7 code" and found... http://www.sjstv.co.uk/skycodelistNEW.html which the correct code for my Bush TV - 0742. Others you may want to try are Bush 0157 246, 263, 377, 037, 064, 065, 310,300,383, 399, 391, 402, 339. or Beko 0125 514, 398. Further, Alba Group are the firm whom own Bush brand amongst others. Google Alba Group to get their site and links to Bush sites.
Posted on May 20, 2008
SOURCE: Sky remote control code for Bush TV
your code is 1239.
Posted on Sep 02, 2008
SOURCE: sky+ remote codes
I have a LCD15DVD014 Bush Television my code is 065 other codes are 064 246 263 377 310 300 383 399 391 402 339 547 292 239 389 good luck
Posted on Oct 05, 2008
SOURCE: bush btv180t- connections
Hi ,
Thanx for the reply.
managed to sort it second time around.
Just ran the coax from the rf socket downstairs to the back of the tv link ,which is attatched into the ariel socket in the back of upstairs tv.
the tv link comes with good instructions,but need reading carefully first.
Posted on Jan 20, 2009
Hi my Son has upgraded his old tv in bedroom to a Bush smart tv model no DLED32287HDCNTDFVP. I installed the channels first time. I have freeview channels except I cannot get the Sky channel to show?
When you say you have freeview channels, and then say you cannot get Sky channels this is not enough information that you have provided, but
I presuming in addition to freeview channels you also have a Sky Satalite receiver which is no longer connected to your Tv or your sons tv Either way Sky satalite have 2/4 lines which means you can have four viewings providing multi rooms is bought from sky, and additional boxes are fitted.
Or you can have 1 sky box main Tv and no the spare cable feed at the back of the sky box you can feed another cable to another tv from that same box but it will be same channels But you can now change channels using magic eye receivers etc, in any room.
But the question I believe is you had freeview but no long can receive sky channels the information is a little vague but hopefully I have helped a little
Sep 05, 2017 | Bush Televison & Video
I'm unable to get sky channels on my new Bush tv in my bedroom, It is connected by a magic eye,model:DLED32265HDDVDW,product:10103644.
hi make sure the RF 2 signal is turned on at the sky box, the light should be lit on the eye when the cable is connected,thanks
shaun
Feb 11, 2017 | Bush Televison & Video
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
I have a sky hd+ box in my lounge and wish to make the sky work in my bedroom, I am happy to only watch what is on the lounge tv in the bedroom (not have multi room) thanks Nigel
Run a coax cable from the sky hd+ box at the rear from the RF2 coax port, and into tv in bedroom.
If you want to change channels, buy a magic eye from eBay for a couple pounds, enter sky settings, and turn power on to the RF2 output. this will supply your coax to bedroom with 9v which will power your magic rye
Oct 23, 2013 | Neet Cooler Trunk Organizer
Sky remote codes for bush a632n
i have the code for bush a632 point remote at tv press tv then red and select till light flashes twice enter code 0145 press tv again press power press select all stored and ready
Sep 01, 2010 | Televison & Video
Sky wired up by a basic splitter in loft want to use red eye.
Your vocabulary is not helping I will make some assumptions.
1 you have an antenna setup and want to have three tvs use it.
2 I don't know what sky is so I am going to ignore it.
from the antenna you will run a short length of rfcoaxial to a splitter\booster witch is powered this will allow you to split the signal to 4 or two or three tvs your choice. all tvs will need coax or rf cable run to them and btw 300 ohm cable is not called rf
coaxial cable is preferred because of its signal insulating properties and its longer life expectancy and all tvs today have coaxial inputs on them not 300 ohm.
Jan 19, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Code for RUC/Sky
The following code: 253 will work on Sky remotes for the following tv:
Bush LT42M1CFA
Feb 01, 2009 | Televison & Video
Sky remote code
codes for bush are
107
031
codes for bush uk are
005
038
140
018
052
143
020
058
152
022
085
169
031
107
172
036
121
175
015
043
141
019
053
144
021
078
156
026
099
171
033
109
173
226
196
hope this helps
Dec 08, 2007 | Directed 434MHZ Remote Control
Televison & Video Logo
107 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
