Question about Kohler 12 kW Emergency Power System - 12RES-L
Hi i have a kohler confidant 5 5000 watt i replaced the starter and the fuel pump and plugs last week it has only 380 hours it ran like a champ and purred like a kitten for three days while getting the rv ready for a road trip but on the day to leave the generator was working but i shut it off and when i went back to start it i would not turn over only makes a buzzing noise the only thing that wasnot right before it wouldnt start was the choke had to keep being adjusted to find its sweet spot to start and run sometimes but it would still turn over now it just buzzez help me please any pointers or tips ?
4 Suggested Answers
  • 5603 Answers
SOURCE: scagg with kohler v command engine. ran out of
When fuel ran out, dirt in the bottom of the tank either plugged the fuel filter or the carbuerator.
Flush these out try again.
With the choke on, added vacuum helps pull fuel in through obstructions.
Posted on Mar 28, 2010
SOURCE: Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Posted on May 06, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Hello....i have several problems and
Hi and welcome to FixYa, I am Kelly.
I can not tell you how to get it out of it's current mounting position without seeing it. (Just being honest) And the wiring is different for each RV depending on what electrical system the ORIGINAL owner opted for. My experience with RV generator is that you can usually slide them out on rails just far enough to disconnect the wires. Just do yourself a HUGE favor and draw your own wiring diagram.
Number the wires 1 through 8 (
Ok.... here is the diagnostic and service manual:
http://www.kohlerpower.com/onlinecatalog/pdf/tp6196.pdf
See the troubleshooing steps on page 25 and also see sections 4-4 and 4-5 to determine why it is shutting down. First thing check the oil level! The engine has a Low Oil Level and low oil pressure Pressure Sensor. Either one will shut off fuel. Read in section 5 also....
The squalling noise your hearing is probably dry starter bearings. There is not a quick fix for this other than to disassemble the starter and lubricate it. If the bearings in fact dried out you will have to also wipe off the armature shaft area where the bearings are. If you just lubricate it without disassembly it will eventually lock up from the left over residue.
The fuel system is discussed on page 66 of the manual link. This appears to be an LPG powered unit. If it is not LPG powered find your engine number and I will get your engine service manual also so you can locate the fuel pump. (I think this is either the CH or CV740-0035 engine) If I remember correctly the fuel pump is vacuum powered on this engine if it a diesel or gas model. The diesel engine also has a fuel injection pump in addition to a fuel pump. (just depends on what sub model of the 12 RES-L you have. The L usually designates it as an LPG unit.)
The parts list is here:
http://www.kohler.com.sg/onlinecatalog/pdf/tp6399.pdf
Air Filter: (Page 17)
9 24 083 09-S Element, air filter ( or use this page to locate a Kohler dealer:
http://www.kohlerengines.com/wheretobuy/landing.htm
Thanks for choosing FixYa,
Kelly
Posted on Aug 09, 2011
Kohler kt735-3012 runs fine for a few mins then runs rough and burns rich
Ron, Try new plug/s first, sounds like the carburetor has dirt in it, you will probably have to remove carb. and clean/rebuild. From manual, other causes from your trouble shooting guide ,
? Faulty carburetor. ? Faulty cylinder head gasket. ? Faulty or misadjusted choke or throttle controls. ? Fuel pump malfunction-vacuum hose clogged or leaking. ? Intake system leak. ? Loose wires or connections that intermittently ground ignition kill circuit. ? Quality of fuel (dirt, water, stale, mixture). ? Restricted fuel tank cap vent. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.kohlerengines.com/onlinecatalog/pdf/32_690_03_EN.pdf
Kohler KT735 3013 24 Hp Engine Parts
Kohler carb rebuild
How To Rebuild Kohler Series Carburetor K161 K181 K241 etc
Jun 27, 2016 | Garden
Craftsman 42 in mower with kohler command 15.5hp no spark.
Hi, check your oil level incase it has the guardian system on it. If that is ok it may be the coil as kohlers have a habit of them failing, regards Phil.
Jun 25, 2012 | Craftsman Garden
My sidekick will just die or barely run it died
last year, OBD1 car (dumbb ECU)
no scan tools for it
if you run on the road with that hack , and wreck
expect a nice fire. fuel fire.
if you used a voltmeter and say 12vdc there, all hotwiring stuff
need not be done. (
it stalled (misfire)
and then would not what? start but cranks ok?
4wd?
3sp ,4sp auto or 5speed stick
16v engine or 8v, both are G16s but EFI radially different.
16v is MPI with 4 injectors, 8v is 1 injector TBI
try a new
cap,.rotor spark wires and spark plugs yet?
cant burn fuel with bad spark
i guess the cam bent did not slip as it run ok later, but is 60,000 mile belt. and will slip ignored.
next time it stalls
check headlamps they work, and all electric
then see if CEL glows key on, i must or ECU lost power
it has 3 fuse that can rust, IG coil, FI, and DOME.
the CEL must glow, is first checks.
Mar 21, 2017 | 1995 Suzuki Sidekick
95 honda accord turns over but wont start
Sometimes when a fuel filter is stopped up,and you change it,the fuel pump later,will go out,cause of the strain on the pump.
Apr 11, 2010 | 1995 Honda Accord
Yamaha 6600de generator dies 3 seconds after starting
When you pull the bowl off of your carb is it clean? If not you have some contamination possibly inside. You might want to remove the carb and blow compressed air through all the vents a ports.
Sep 24, 2009 | Reliable Yamaha YG4000D 4000 watts/33.0...
mike
Sep 24, 2009 | Kohler Electrical Supplies
Kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Aug 11, 2009 | Electrical Supplies
Rough idle and acceleration on 1998 Chevrolet Silverado 5.0
Bad EGR valve comes to mind here. Assuming the plugs are good, the EGR valve woiuld be what I'd look at.
Jul 26, 2009 | 1998 Chevrolet Blazer
Kohler 12 kW Emergency Power System - 12RES-L Logo
216 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
