Problem with Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
why is gas getting into my oil crankcase
Posted by avatar on Jul 06, 2010
Solutions (1)
Best Solution
Usually this is from the needle valve in the carburetor being stuck open. If you're comfortable taking apart and working on the carburetor, read this for details on what to do, otherwise take the mower to a repair shop. Good luck! Please rate my answer if helpful, thanks.
Suggested Solution (2)
hello mr p,well it is a simple fix,but a lot to correct problem, parts needed,1 new spark plug,1 new solenoid,1 quart of 30wt oil,1 pan to catch old oil in. tools needed,1 spark plug wrench,1,7/16 or 1/2 or 9/16 open wrench,pen&paper. ok, empty fuel tank or clamp off fuel line,make a drawing as how the wires are connected to the solenoid,white & black wires,unplug wire fittings,remove solenoid, in stall new solenoid,plug wires in. now drain oil & gas out of engine,remove old spark plug,important so follow directions,after oil is drained plug is out crank engine so to clean out cylender of excess oil & gas,it would be a good ideal to let oil drain for a while. add oil & spark plug,engine will smoke for a while but should clear up.when you go to the parts store you will need engine horse power,engine brand,mobel number,type number,parts should cost around 50.00. including everything you need,check oil often.hope this helps,good luck;MrFixIt. oh please don't forget to give rateing,thank you.
  • by Author image JERRY ABELL Over a year ago
    • By avatarJERRY ABELL Feb 11, 2009
    • hello! you took the time to ask question. i took the time to answer your question. could you take the time to rate the answer. thank you.
Source: my craftsman lt 1000 is getting oil in crankcase
Was this solution helpful?
No
Yes
hello sir check to see if the engine is over full on oil and gas in the engine .this will make starter drag eventually ruining starter.this is the only thing i can think of other than engine having high compression except valves not opening and the pressure relief valve not working,or engine low on oil 30 WT, is also important to keep good oil in engine and full. the solenoids under the carburetor will go bad, if you have one. make sure you keep battery charged. if it is follow these directions ,well it is a simple fix,but a lot to correct problem, parts needed,1 new spark plug,1 new solenoid,1 quart of 30wt oil,1 pan to catch old oil in. tools needed,1 spark plug wrench,1,7/16 or 1/2 or 9/16 open wrench,pen&paper. ok, empty fuel tank or clamp off fuel line,make a drawing as how the wires are connected to the solenoid,white & black wires,unplug wire fittings,remove solenoid, in stall new solenoid,plug wires in. now drain oil & gas out of engine,remove old spark plug,important so follow directions,after oil is drained plug is out crank engine so to clean out cylinder of excess oil & gas,it would be a good ideal to let oil drain for a while. add oil & spark plug,engine will smoke for a while but should clear up.when you go to the parts store you will need engine horse power,engine brand,model number,type number,parts should cost around 50.00. including everything you need,check oil often you can put a inline fuel shutoff in the fuel line about $5.00, or replace solenoids for $40.00.hope this helps,good luck;MrFixIt. oh please don't forget to give rating,thank you..
Source: gas leaks into crankcase
No
Yes
Add Your Solution
See all Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Problems
