Question about Bose Lifestyle 20 Shelf System
How do I get the buzz to stop in the bose lifestyle model 20? A cd got stuck so I finally got the top off removed the cd and the magazine and the buzz is still there. I do not care if the thing plays cd's. I was just testing a cd I had burned. The bose unit runs my 'house music'. So all I need it for is to run the house speakers... don't even use the radio!
  • 1 more comment
  • sunshineinri Jul 07, 2010
    The problem is in the Bose unit itself. There are no issues with the speakers. The Bose unit makes a buzzing sound with the magazine out. the cd is no longer stuck in the unit either. I had to remove the top of the case to get the cd and magazine out. Everything is in tact in the unit. When I plug it in with nothing else connected to the unit it buzzes like it is trying to eject the cd and the mechanism keep grinding away. Thank you.
    There is NO faulty speaker.
    The Bose unit is NOT connected to any speakers. It buzzes not connected to speakers.
    The problem is not the speakers.
    The problem is in the Bose unit.
    The bose unit makes the buzzing noise when connected to speakers. The speakers are properly connected.
    The bose unit started making the noise when the cd was stuck inside of it.
    It seems no one there understands what I am talking about and I am very disappointed in your service.
  • 343 Answers
I would check the ground wires and their connections. One of the connections may be loose, have a bad connector or even a break in the wires. If you are iside the Bose system already, check the ground connections for a clean contact surface.
Posted on Jul 07, 2010
  • sunshineinri Jul 08, 2010
    All of the connections seem to be fine. Is there any way to disconnect the motor? I just want the noise to stop. Don't need the cd function.
  • Greg W.
    Greg W. Jul 09, 2010
    You are going to have to open the case by removing the surrounding screws that secure the cover on. I DO NOT suggest you do this unless the system has been unplugged for at least 72 HOURS. The system can hold a charge that can put you at risk of electric shock. If you decide to open the case after the 72 wait period, there should be a connector plugged in the cd player that is wired to the electrical board. Remove the connector and it should disarm the cd player. If there is no connector, let me know and I will assist you further. Just a quick note, we are all here to help you. Nobody wants to make you feel as if we don't care about your problem. It is difficult for us to understand exactly what is being described because some of us use different terminology than others to describe sounds. Most of us are familiar with a buzzing noise from an electrical unit as being a bad ground. Please keep me updated. Thank you.
    President:
  • 1,070 Answers
Welcome to FixYa
Dear Sir
Follow this Guide and Read it Carefully to Solve your Problem...
This Guide can lead you to a Solution.....Click here[it may take few minutes to load]
Check page 14,8 and all ...
Thanks for Contacting FixYa
    President:
  • 567 Answers
Hi there the buzz that you are getting is cause by one of the speaker,this mean one the speakers is faulty.You can identify the faulty speaker by should connect the speakers one at a time and test them by playing a CD this will identify the faulty speaker.
  • 6 more comments
  • Hilton Bristol Jul 07, 2010
    It seem as if the CD drive is bad the grinding which you hear is coming from a small motor which spin the CD when playing music and that small motor seem to be faulty.
    How do I disconnect the small motor?
    Hi there thanks for replying i will do the best i can to find a solution the problem, as i mention earlier the tiny motor which cause the CD to spin when you are playing music,is faulty or damage,and need to be fix.You should take it to the nearest repair center.
    Thank you
  • Hilton Bristol Jul 08, 2010
    Hi usually when this kind of problem occur Bose technictions is best to handle it, because it is a very technical task you can contact them: US customers, for personal assistance with your product service questions please email support@bose.com or call us toll-free at 1-877-210-3782.
    For the best possible service, please have your product nearby when you call.
    Hours of operation:
    Monday Friday: 8:30 AM 8:00 PM ET
    I do not want to spend $300 to get the cd player working. All I want to do is stop the buzzing.
    So I am not pleased with the Fixya solution as I already knew I could call Bose directly. That does not take a genius or a fee to figure out!
    So I have wasted my time with fixya.com.
    I understand but unfortunately i am out of ideas so would leave your question open and another expert will assist you.
    Thank you
    I fixed it myself! It was the motor that ejects the magazine. There is a small black button in the back of the magazine chamber. It slides left to right and must be the "switch" for ejecting the magazine. the noise stopped and everything works!
    Ok i am please to know your problem solve
  • 677 Answers
Are you hearing a buzzing sound from the speakers on your home stereo system? Maybe the buzz is only when the music is turned up very loud. Maybe the buzzing sound only comes when there are deep bass notes, or maybe your speakers buzz all the time. In any case, here are a few simple steps to determining whether it is your speakers that are the problem, or another stereo component.
Things You'll Need:
  • Home stereo system
  • Any other head unit besides your primary one
  • RCA cable, stereo
  • Copper/silver speaker connector wire
Remove any covering over the paper or synthetic sound cone on the face of your speakers. Most stereo speakers will either have a screw-on metal grate or a cloth shield mounted on a frame with tabs that pop out with a screwdriver. To determine if the buzzing is coming from your speaker cones, you first need to expose them.
Wash your hands and inspect the face each of your speaker cones in turn by visually looking for rips or tears that could be the source of the buzzing. Run your finger along each seam of each speaker cone, looking for small gaps that are created when very light pressure is applied. The speaker cone is very delicate, and the smallest rip or gap will create that buzzing sound in your stereo speakers that makes you cringe.
Testing the speakers with another audio source will be necessary if the first steps have not solved the problem. Disconnect all cables that connect your home stereo speakers to the head unit. These will either be RCA cables or the twin-shielded slim silver-and-copper wire variety that plug into black and red pull tabs on the back of the speaker.
Use a friend's stereo head unit and plug in the RCA or connector wires. You need a home stereo system to test whether it is your head unit that is causing the buzzing, rather than the speakers. Make sure you use a head unit with a similar wattage and ohm rating as your own. If you aren't sure what this means, check the manual that came with your unit.
Fire up the speakers using the other stereo head unit and check for the buzzing. If there is no buzzing coming from the speakers, your head unit needs to be serviced. If the buzz persists and your speakers have no visible rips or tears, there is something wrong with the inner voice coils or amplifiers. Unless you are an audio expert, this is the point where you will need to take the speakers in for service or replace them.
Tips & Warnings
  • To avoid blowing your speakers in the first place, always use them with the stereo system they came with or one with the same or similar wattage and ohm rating.
  • Be extremely careful when exposing and touching the face of your speakers. You should have clean hands and use as little pressure as possible.
Hope it helps.
Posted on Jul 06, 2010
  • sunshineinri Jul 06, 2010
    I have the bose unit apart. So obviously it is not hooked up to my sound system! When the bose unit is plugged in it is buzzing all by itself. It has nothing to do with speakers. In fact if I hook up the unit to my sound system it will play music but the buzzing is still coming from the unit itself. The problem is in the Bose unit itself.
How do you open the base unit to remove the cd changer magazine
The top cover is held on with 4 clips (similar to those on a car door card) so needs to be gently prised off, this will expose screws etc to enable the bottom cover to be removed.
Ive done this with my system but it does not really help solve the problem, I still can't get to the jammed disc!!
Jul 07, 2014 | Bose Lifestyle 30 System
2001 ml 320 cd cartridge will not eject how do i get the cartridge out of changer
There could be a CD stuck between the player mechanism and the magazine in which case you will have to do some disassembly to fix it.
Jan 29, 2013 | Bose Lifestyle 20 System
How do I remove a stuck 6CD changer magazine?
Our Bose has a 5 CD player, So, I'm not sure if this is the same for your base unit, but here goes. You'll need: a bright light and a small screwdriver that reaches inside the chassis (or equivalent).
1. Disconnect the base unit from the system.
2. Turn the base unit upside down and find the access hole embossed with "Manual magazine release" on the CD player side.
3. Using a bright light, look inside the base unit at those access holes and find the fine spring and locate where it fastens to the sheet metal of the CD player.
4. When you find the spring you should see that it connects to the CD player chassis at the forward end and a piece of sheet metal that is on top (actually underneath when the base unit is right-wide up) of the CD player chassis at the rear end. This is the manual release mechanism.
5. Using the small screwdriver, push the release mechanism rearward to release the CD magazine from the player. The magazine should pop out.
If the magazine is not released, then the CD that is still in teh player has not been slid back fully into the magazine. In this case you'll need to plug the base unit back into power and hope that the CD is retracted, allowing you to push the release mechanism rearward. If not then you'll have to open the base unit to access the CD player.
Feb 19, 2011 | Bose Lifestyle 20 System
I can not get the Magazine to release. I see where it say's Manual Magazine realease, but can't tell what to do. Please help Darrell Mack
Hi
Thanks for using FixYa. First of all please check that the speaker cables are not damaged and the connections are secure. Reduce the output level from any external components connected to the music center. Make sure the audio input cable is firmly seated in the music center SPEAKER ZONE 1 jack and the multi-pin connector on the other end is firmly seated in the Accustoms module AUDIO INPUT jack. Check the cables connecting the Jewel Cube TM speakers to the Accustoms module. To restore communication between the music center and the speakers turn the music center off for ten seconds, then on again. Check the connections for any external components. Make sure to select the correct source for the desired input. Be sure the CD is placed correctly, label-side up, in the magazine, and the magazine is inserted properly in the music center. Increase the volume. Check to see if MUTE is lit on the display. If it is, press the MUTE button on the remote control to un-mute the sound. Disconnect any headphones. Connect the FM and AM antennae. Check to see if the play symbol in the display is lit. After pressing the CD key, wait a few seconds before pressing PLAY. Make sure the magazine is properly inserted. Check to see if there is a disc in the magazine, label-side up. Display shows a flashing box for a disc that is label-side down or cannot be read. There may be dirt or dust on the CD. If so, clean the CD. Eject the magazine and try loading the CD again. A display message “E01” indicates a mechanical error. Unplug the music center. Reconnect power and try again. If “E01” reappears, call customer service.
If the CD stuck again as you stated in your earlier comments, then you need to use a small and long screwdriver to reach the notch. Now turn the media center upside down so that the "Manual Magazine Release" is in your upper right hand. Locate the two small rectangular "Open Slots" on the side. You need to use the top slot. Use the screwdriver and push the little "U" or "Y" Shaped metal upward which is just below the manual release. The magazine will come out.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 16, 2009 | Bose Lifestyle 20 System
Bose Lifestyle CD not eject
There are some repair instructions available at www.AnyoneCanFixIt.com in the electronics section that will show you how to release the CD magazine and fix the problem where the unit will not play the CDs (you will hear a buzzing, buzzing, buzzing, and nothing will load or play).
Oct 11, 2008 | Bose Lifestyle 20 Shelf System
Cds in changer STUCK!
There is a Manual Magazine release on the bottom back right corner. Pushing the lever back will release the Magazine.
Aug 08, 2008 | Bose Lifestyle 20 System
How to open the case?
Hi- I had to also remove the CD cartridge. A Pain! You can easily remove the case cover. You need to carefully remove the LED lens from the front by using a small putty knife to depress the expansion pins on the right and left sides and pry the lens cover up. Then, use the putty knife to lightly pry up the aluminum top cover. There are 4 nylon pins affixed to the aluminum cover by double stick tape. They are approximately 1.5" from the corners. Lightly pry up each corner to remove the top cover and you are in. There are no screws. Don't gorrilla the thing or you will bend the aluminum. Cheers!
Apr 13, 2008 | Bose Lifestyle 20 System
Bose Lifestyle 30 6-cd changer magazine manual release?
hi, you can release the magazine by inserting a small flat head screwdriver in the slot and pushing the lever towards the back of the unit, this will release the cd but only if ther is not one stuck in the player as it will remain halfway between the mag and the cdplayer. don't force it to comae out. remember to obviously have the dorr to the player open before you try this.
Jul 29, 2007 | Bose Lifestyle 30 System
Bose Lifestyle 20 Shelf System Logo
536 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
