Question about Apple iPod nano
My I pod model no is A1320 14g.b how to restore my i pod
I have an I-Pod touch and all off a sudden CCS stopped sync with my facebook acc ,i have checked both fb + i-pod settings which both enable access for each other but it doesnt help , how can i fix this ?
try updating your I-pod on the iTunes software on your computer if that doesn't work back up your I-pod on the iTunes and then reset your I-pod to factory settings. now if you backed your I-pod up properly then log back into your I-pod with your iTunes account and plug it into your computer, it should automatically restore all your apps and music ect. then you should be able to sync what ever u want again the problembeing is u probanlypicked up a virus or something on your I-pod
Jul 31, 2013 | Audio Players & Recorders
How to erase or reset my i-pod touch. my i-pod
  1. Plug the iPod Touch into your computer.
  2. Step 3 Power on the iPod Touch.
  3. Step 4 Press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
  4. Step 5 Release the "Sleep/Wake" button but continue holding down the "Home" button. The iPod Touch should reboot, and iTunes will notice the iPod Touch in recovery mode.
  5. Select "Restore" and follow the instructions to finish restoring your iPod Touch.
May 25, 2010 | Apple Earphone Headphone for i Pod iPhone...
Hang-up
Hi, when a apple i pod freezes and refuse to function, it means that the i pod memory has stop working due to an application you installed in the i pod.
To rectify this problem, you will need to flash the i pod for the memory to start working properly.
Flashing an i pod helps you restore lost memory. After flashing the i pod, you can now start using it again as normal.
Take care.
Apr 14, 2010 | Apple iPod nano 3rd Generation
My i pod touch says "i pod is disabled- connect to itunes, had forgotten password and thought it was this and it was not and now thats what it says and can't do anything with it now
if you have forgotten your password, then the only solution is to restore it. this means that it will restore the ipod to its factory default settings, with all the music, vidoes, etc. deleted off of it. instructions are here http://support.apple.com/kb/HT1414 Hope that helps
Apr 07, 2010 | Apple iPod touch
Pod is disabled
Use the Five Rs to restore the iPod. You will lose the data that is currently on it if you restore but you can always re-sync the data to the iPod. http://www.apple.com/support/ipod/five_rs/
-=/ Daft Tech /=-
Oct 23, 2009 | Apple iPod touch
Ipod classic 120 g format problems
use my computer and right click and click format its a lot easier. then use itunes to restore it
Jan 24, 2009 | Apple iPod classic MP3 Player
I pod nano
open I tunes, plug the i pod into the computer, when the i pod shows up on the left hand side of the screen, right click it and you should get an option to rename it
Sep 19, 2008 | Apple Mini IPod
Restore
There are some programs available. I use iGadget from www.purpleghostsoftware.com.
Apr 18, 2008 | Apple iPod nano
I pod model A1199
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
If you need more asistance, let me know. Good luck.
Mar 14, 2008 | Apple iPod nano
Ipod nano problem
hello blair,I Have my own I-pod so I hope this will re asure you. First I think you should restore your I tunes as long as your brother has your songs too. Then ask him to create a CD of all your songs, which is not hard at all. then take the CD and open I-Tunes. Place the CD into your hard drive and I-Tunes should pick up the CD. Then download the content of the CD onto I-Tunes. You Will Now have all your songs on I-Tunes like before. Now plug in your I-Pod and continue like It's the first time you have pluged in your i-pod! hope this helps! Rosebetts xxx
Dec 29, 2007 | Audio Players & Recorders
Apple iPod nano Logo
443 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
