Question about Samsung RS2578BB Side by Side Refrigerator
Water pipe installation
Can i purchase longer piece of small white pipe connection from water source to fridge may need 3.5 metres
Yes from samsung direct
Posted on Jul 03, 2008
Tip
Fix / Repair Lay Z Spa Heater
1) Opening the shell and identifying the heater unit (its at the end of the metal pipe) You will have to unscrew the circuit board2_bing.gif and metal pipe to access the unit.
2) In the heater unit there are live (x2) neutral and earth wires.
3) The first live wire you need to identify is the one coming from the mains. It will be going into a water flow switch covered by a white cap. The wire is only clipped in, so pull on it with some force to remove it.
4) Next you should remove the other brown wire from the clips, so that you have a small section of brown live wire no longer attached to the clips. This piece of wire is no longer needed, but keep it in a safe place for if you need to reverse the process if this does not work (it should)
5) Now attach the original brown live wire that came from the mains into the clip which you just removed the small brown wire from. (not the part that was going into the white cap)
6) This should bypass the water flow switch and should allow the filament to heat. 7) Then reassemble the pod the way you disassembled it and the water should now heat up when attached to the spa.
on Jun 12, 2010 | Pool & Spa
Tbx21ji refridgerator has water inside the bottom of fridge. it keeps happening
Mine did the same thing. Pull refrigerator out so that you can access the back. Take off lower dust cover , it's black and has several small screws. Once removed, you can see a pvc pipe running from top to bottom. Remove screw from clamp that holds pvc pipe vertical. Remove pvc pipe from top of refrigerator, then remove the top piece that was attached to pvc pipe. You may need to turn 1/4 turn counter clockwise to remove. Once removed, clean these 2 pieces thoroughly to remove any blockages. Install in reverse order and hopefully this fixes your water problem. This pvc pipe runs to a pan that water pools in and evaporates. If the water can't get here, it has to go somewhere.
Jul 12, 2013 | GE J Series 20.6 cu. ft. Top Freezer...
Wse6070sb fridge. Leaks water down by the door hinge. How does the internal door lining come off so I can see where it is leaking from?
The problem is that the pipe that feeds the filtered water is broken. It is a common problem. If you are handy you can fix it. You buy an 8mm press fit elbow. Google it. If you want to see what these are you need to look under the fridge. The best way to do this is tilt the fridge to one side and then put a piece of wood under the gap. Tilt the other way and put wood under the other side. Keep doing this until you can see the white pipe under the corner of the door. Your will see a that the pipe is cracked at the bend. You need to fit the 8mm elbow onto the cracked pipe. This is not easy. Make sure that you wind the adjustable feet down so that the fridge does not crush the elbow. On my fridge the pipe was brittle and weak. I took a piece from the filler end.
If you look under you will see a clear pipe that is joined to the white pipe. That joiner is an 8mm push fit joiner. You need a 90degree version to join at the cracked bit. Once you have the joiner, carefully cut the crack through and push the joiner UP first, then fit the other piece in. Be careful to tuck the finished pipe away. When I did it the fridge crushed the joiner when I took away the timber.
Jul 14, 2011 | Westinghouse Refrigerators
How do i turn off the water supply to the fridge if its pipe is leaking?
There should be a small valve behind the fridge. Pull it out from the wall, and look behind it with a flashlight. They are usually near the floor at the wall. Turn clockwise to close it. In older homes, the water line can be run under cabinets to under the kitchen sink where water pipes are..
Old installations use 1/4 inch copper tubing. Newer ones use 1/4 inch nylon. Some use flexible white hoses.
If you close the valve and it still drips, then the entire water system will have to be closed off to replace the valve. These valves and new connection kits are available at sears, home depot and lowes.
Jan 08, 2011 | Maytag MZD2766GES Side by Side...
Plum in a Amana fridge freezer
hello. I am assumming that your model has the ice and water dispenser. Not all models do. On the rear of these models with the ice and water feature you will find a small [1/4 inch] line that has to be connected to a cold water supply source. If you go to most any hardware store you can get the little kit necessary to make this connection. The kit consists of a length of 1/4 inch tubing, the connector to attach to the tube at the rear of your appliance, a valve and a tapping kit to tap into your closest cold water source. If the fridge is near the kitchen sink, you may choose to connect under the sink. If not, make sure you purchase a kit with enough 1/4 inch tubing to reach your nearest cold water pipe. J.
Jul 20, 2010 | Amana 22.6 cu. ft. Side-By-Side...
How to install toilet macerator?
on your out put pipe make sure you put as few turns and bends in it as you can, this will help the pump out when it's grinding and pushing it up. also you will want to use schedule 80 pvc pipe if you can get it and make sure you prime and glue every fitting well because you do not want that to leak when it's started up. it's always good to put a check valve on it as well some where close to where it enters the tank and a shut off valve, the glued pvc valves are handy because you dont have to worry about them leaking
Jul 26, 2009 | Saniflo 002/005/007 Saniplus Toilet with...
Msd2756geb water tube coming out door not hooked up?
Check diameter of pipe. Suspect its quarter inch. You will then probably need to purchase e.g. from ebay etc a 1/4'' to 3/4'' adapter which will allow you to connect your fridge pipe to a typical water pipe connector (i.e. similar connecting a washing machine), assuming you already have an available water conenction in the lcoation of the fridge!
Jun 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
My fridge is not make water
I assume that you checked the water is coming out of the 1/4 inch copper /pvc piping that connects to the water line from the refrigerator' s water inlet pipe. In order for water & ice to come out 2 things have to be set correctly.
1. Make sure that a water filter is indeed installed and that it hasn't been there installed for more than 2 years as it could be clogged.
2. make sure that the small shut-off valve in the back of the fridge is turned on!
Good Luck!
Rich
Nov 26, 2008 | GE Americana A4425GDTWW Side by Side...
Samsung RS2578BB Side by Side Refrigerator Logo
91 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
