Question about Bosch Dishwashers
Dishwasher is not working. When swuitched on it makes gurgling sound and some water drains out and that is all. What to do? Bosch Dishwashe, Semi Integrated, model number is not clear!
  • 523 Answers
There is a leak under neath take kick plate and look for float switch
Posted on Jul 06, 2010
Bosch SL1501B dishwasher doesn't drain water after the washing cycle. Also with new drain pump. What else could it be?
Check the following.
1. The drain hose has to be discharging at a high enough point to prevent water flowing back into the machine.
2. Make sure your drain hose is not twisted or kinked.
3 . Make sure your drain line is not blocked push a flexible hose down it to dislodge any fat/debris
4.If your drain line discharges into a shared drain with another appliance i.e. garbage disposal make sure it is not blocked.
5. You may have a blockage at the inlet to the pump which would slow down the pumping rate,
Since you mentioned the mushroom shaped float allowing the washer to empty this may be defective.
See the link attached.
Hope this helps.
Crofter
Bosch Dishwasher Does Not Drain
Apr 30, 2015 | Bosch Dishwashers
Hello. have a sh43uc (not in recall range). just recently is hums and hums and never washes anything. Unit is getting hot water. cleaned filter, can pour a pitcher of water in the drain and the impeller...
poss main pump(sometimes called motor) is jammed or fillter in same area blocked dis assemble sump area(under bottom filter) from inside machine and look for foreighn bodies i.e bone etc.....i hope this helps kev
Nov 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch Classixx (about 10 years old) dishwasher won't fill The problem has only started since I pulled it out and cleaned! The programme sounds are as normal but no water enters the machine. I detected...
Check you dont have a small inline filter inside the inlet water pipe. Either at the "tap" end or can be on the machine itself. They look like a small sieve. Remove it and clean with a toothbrush. Then put back.
Apr 05, 2017 | Bosch SHU9915UC Dishwasher
Cycle time
yes its normal.bosch dishwashers use very little water and energy but,the cycles need to be longer to get the dishes clean. its perfectly OK.(ps use cascade powder if you can)
Jul 24, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Bosch SHV46C
Replace the fill valve that sound is it trying to open
Mar 12, 2009 | Bosch 24 in. SHV46C13UC Free-Standing...
I have started hearing a gurgling sound in my diswasher air vent when I run water in my sink. Why has this begun happening? I have an /estate dishwasher Model TUD7000Y-0
Sounds like your waste water drains could be backing up and pushing water back into the dishwasher.
Firstly try pouring Mr Muscle sink and plughole un-blocker down the sink and leave overnight next morning pour boiling water down the sink and your pipes should be squeaky clean. Hopefully this will improve the flow and prevent gurgling!
Feb 21, 2009 | Miele 24 in. G870 Built-in Dishwasher
Bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
thanks
Sep 25, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch built in dishwasher won't drain
1.
  1. Adjust the level of the washer to mitigate sound.
  2. The water backup is due to the low drain hose mounting position. Check the sink disposal position; the drain hose connection from the dishwasher to the disposal must be placed higher than the present drain hose passing the sink cabinet from your dishwasher.
Jun 24, 2008 | Bosch SHU3305 Dishwasher
Bosch dishwasher
is all the water draining from the tub? if not the pressure switch will not reset and it will continue to try and clear it self...check drainage system.
2. pressure switch is jammed on..build up in the sensing chamber..common..or switch faulty...rarely
3. if water is in the bottom panel most have a flood switch which automatically operates the pump in case its over filling
Dec 04, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
How to get build in out to be able to see what is wrong
You have to remove the water line /power supply/drain hose than it will be removable
Nov 30, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwashers Logo
380 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
