Question about PNY Optima Pro 2GB Secure Digital Memory Card
Have brand new PNY OPTIMA SD HC 8gb Have a HP camera Photosmart R927 Camera reads card is locked. How do I unlock the card?
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
Hi ppl....i have a problem with my PNY OPTIMA SDHC 8 gb memory card....i was using it in my sony camera......at the beginning it was working fine but recently this memory card is'nt working on my camera...when i insert the card it either says "FILE ERROR" or "ERROR FOMATTING MEMORY CARD"......i tried to re-format it using my camera but it did not work AND so i tried to use the usb cable and tried to format the card but the system is not able to do so....it says make sure your disk is not read only.... i'm not sure what to do so kindly help
Posted on May 20, 2011
PNY optima sdhchd 8gb won't read in my Kodak easy
What model Kodak EasyShare camera? Some of them only work with SD cards, not with SDHC cards. The same applies to kiosks. Make sure the slot is marked "SDHC' and not simply "SD".
Feb 05, 2012 | SanDisk Cameras
I have a Nikon S6000. I recently bought a card for it at a Big Lots store. Here is what is on the front of the card: "PNY Optima SD HC 120 min HD 8GB." The problem is that the card will not come...
"SD" cards larger than about 2GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
It sounds like your camera is able to understand SDHC, but your card reader is not. It won't cost much to buy a new card reader, but make sure the specs mention SDHC.
Jan 18, 2011 | Nikon Coolpix S3000 Digital Camera
PNY optima SD HC 4GB card will not read
Try putting a tiny piece of scotch tape over the lock slider. See if that works.
Dec 29, 2009 | PNY 4GB Secure Digital High Capacity...
WHAT KIND OF MEMORY CARD DO I NEED. WE PURCHASED A PNY OPTIMA SD HC CARD AND THE CAMERA READS THAT CARD IS LOCKED THANKS JOE
Check on the side of the card. There is usually a little switch that will force lock the card to prevent writing to it (similar to the lock on 3.5" floppy disks, if you remember those).
Dec 16, 2009 | Canon PowerShot A410 Digital Camera
My canon sd600 is not reading PNY sdhc memory card. msg says card is locked. it's clearly not locked
HC or High Capacity is not compatible with this camera. You have to buy a memory card which says only "SD" and NOT "SDHC". Cards of 2Gb and less are usually "SD". Cards of 8Gb and more are always "SDHC" for technical reasons. Cards of 4Gb can be either, but the SDHC kind are much more common, because they're cheaper and newer.
Jun 22, 2009 | Canon PowerShot SD600 Digital Camera
I have a Photosmart R927 HP digital camera...I have had this camera for several years. I have not used in a couple of weeks. Turned on camera today and my screen reads "CARD LOCKED". I have never...
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 20, 2009 | HP Photosmart R927 Digital Camera
PNY Optima SD HC 8GB isnt working on laptop
Youll have to get updates for your laptop card reader or get a new one which may have to be installed. Another method you may want to try would be to put the card back into the device you used it in and then hook the device up to the computer, most likely through the USB slot....good luck
Jun 05, 2009 | PNY Optima Pro 2GB Secure Digital Memory...
Can't unlock my camera card on hp photosmart M425
if we are talking about an sd card, on the opposite side to the 'cut' corner is a small piece that slides away from the contacts to lock, slide this away from where it says lock if this is the case, but make sure it wasn't protected to save something important before use, This may have caught on something as you slid the card in, and it's only tiny!
Mar 07, 2009 | HP Photosmart R927 Digital Camera
Using SD HC Memory Card with HP R927 camera
No. The R927 is limited to SD cards 2GB and smaller.
Aug 25, 2008 | HP Photosmart R927 Digital Camera
Take the card out of the camera, and on the card (I believe its an SD card) there should be a sliding tab on one side of the card. This tab will lock the card (much like a floppy disk or a VHS tape) and prevent it from being wrote too. Slide the tab opposite of the direction it is facing and you should be able to use the camera again as normal.
Dec 18, 2007 | HP Photosmart R927 Digital Camera
PNY Optima Pro 2GB Secure Digital Memory Card Logo
467 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
