Question about LG DLE2514 Electric Dryer
Only runs for 6 seconds at a time
Just purchased this DLE2514W, It only comes on for 6 seconds at a time, the "drying" light is blinking and the "cooling" light is on.
Please help.
Thanks
  • 489 Answers
It sounds like the motor has an issue and needs to be addressed by a qualified LG technician.
Posted on Apr 28, 2008
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
LG DLE 2514W DRYER MAKES RUMBLING NOISE WHILE RUNNING
Hi Willie Bolden
Sounds like your problem is drum rollers are in need of lubrication or replacement.
Go to the following webpage for a schematic of your dryer and parts.
Please take time to rate me
Bud
http://www.appliancepartspros.com/parts-for-lg-dle2514w-abweeus.html
Oct 11, 2012 | LG DLE2514 Electric Dryer
Timer stops at 6 minutes but continues to tumble.
You will need to replace the auto dry sensor on your dryer.
Mar 11, 2012 | LG DLE2516 Electric Dryer
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Light is on for heat dry but won't allow me to run a cyle or turn on
Hi
Daniel
Apr 17, 2011 | Frigidaire Professional Series 24 in....
Normal light blinks
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry,Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Daniel
Apr 17, 2011 | Whirlpool Dishwashers
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
My DLE2514W LG dryer keeps running with 6 Min. Left
There is a humidity sensor (Hence the words Sensor Dry) inside the machine which trips out when it sees a lack of moisture in the air going past it.
It is not adjustable without special equipment
That sensor has failed and will need replaceing
Jun 07, 2009 | LG DLE2514 Electric Dryer
CL code on screen and can not use sensor dry options
For model 2514; from LG manual:
Child Lock: Press and hold DRY LEVEL for 3 seconds. A single BEEP Tone is heard, and CL is displayed. To unlock, press and hold DRY LEVEL for 3 seconds. The indicator light turns off.
May 23, 2009 | LG DLE2514 Electric Dryer
LG DLE2514 Electric Dryer Logo
338 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
