Question about Janome Thread Banger TB12 Sewing Machine
Needle keeps getting stuck / hitting bobbin casing
Hi, My needle keeps getting stuck in the down position. The only way to get it free is to take the bobbin and it's housing out. Or, the needle breaks. I just bought this machine and am concerned that it is a dud. :(
I'm trying to sew four layers of fabric.
It seems likethe housing only goes in one way, is is possible that I'm putting it in wrong.
bargainbox
  • 1388 Answers
SOURCE: tangle in bobbin area, stuck needle
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on Nov 13, 2008
  • 22 Answers
SOURCE: thread jams & wheel axel cannot turn
there are a couple of things that come to mind.
Bobbin:   wound with uneven tension.  Try taking the bobbin, rewind that thread onto another bobbin and wind slowly.  make sure the thread feeds onto the new bobbin evenly.
upper thread:  catching on something or not flowing off the spool easily.
you're doing well, sounds like you consulted the manual and used your noggin, hang in there and let me know if this doesn't help.  we can troubleshoot some more!
Posted on Jan 12, 2009
kent581
  • 87 Answers
SOURCE: needle hits needle plate with heavy fabric
that is your problem, your needle bar is centered too far to the back. There are 2 little bolts (Below the presser foot lift on the back of the machine) that must be loosened while the needle bar is repositioned aligning the needle bar assembly.
Posted on Mar 24, 2009
  • 43 Answers
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
Posted on May 07, 2009
Zenqi
  • 208 Answers
SOURCE: needle not picking up bottom thread
Remove the needle plate and the bobbin case.
Ensure that the needle is inserted all the way up into the needle clamp.
Set the machine for straight stitch, center needle position.
Slowly turn the handwheel in the normal sewing direction and observe the following hook timing setting:
When the needle reaches it's lowest point and travels up 3.5mm, the point of the hook should be directly behind the needle, or at least within 1 or 2mm.
Another view is as the hook passes the needle, it should pass the needle slightly above the eye of the needle.
If the timing looks good, use some alcohol on a bit of cloth to clean the hook, careful around the tip of the hook as it is very sharp.
If the hook timing is off, you will need to take it to a knowledgeable service person as there are several possible solutions and several other related adjustments which will need to be made.
Posted on Jan 16, 2010
Machine locked up with needle down in the machine
If you can, try to remove the needleplate and the bobbin case from the machine. Once the bobbin case is removed, the needle should be free.
Embroidery Problems Brother Sewing Machine
Dec 05, 2015 | Brother PE-500 Embroidery Machine
I have gone through 3 needles and I've never had an issue before. The machine ate my fabric and I pulled it out (big mistake) and now my needles keep breaking.
1. Put one drop of oil on race. The bobbin case has two screws to adjust to keep it from moving either clockwise or counter clockwise. You will need to adjust these. It is tricky but once in the right position it will only move slightly. Give just enough free movement to allow thread to fit through.
2. Adjust the bobbin tension. The screw on the bobbin will need to be adjusted so it has a tension which equals four on the upper tension. This is a little tricky but if you're off a little you can adjust the upper tension to correct this. NOTE: You are trying to adjust the upper tension and the bobbin tension to be equal. This is similar to a tug of war.
3. Try to turn the hand wheel. Watch to see if the needle thread will ride across the top of the bobbin. It should do this without the thread getting stuck. If it gets stuck you will need to adjust the bobbin case screws to allow a little more movement allowance.
4. Replace the needle.
5. If you still notice the needle striking something under the throat plate you will need to have your machine timed.
Jun 28, 2015 | Brother CS6000i Computerized Sewing...
Automatic needle threader stuck
You may have a thread stuck in your bobbin area. Remove your bobbin, brush gently with a clean soft brush to remove dust and/or thread bits, then gently wiggle your hand wheel back and forth, and brush again. This should free up your machine.
Jul 09, 2014 | Janome Sewist 500 Sewing Machine
I have an eXplore 220-240
Try to rotate the hand wheel towards yourself with the bobbin removed. If it still hits it is time to have it timed. Also, check carefully to make sure the hook (underneath bobbin) assembly is put together with the parts setting in their positions correctly and not cocked.
Jan 23, 2018 | Elna Sewing Machines
Needle Jams In Bobbin Case Area pfaff 1540
First, make sure there is no debris and scraps of thread in the bobbin area. I'm sure you did that already. I assume you also tried it with another thread just to be sure. I would suspect that the timing went out of whack. The machines depend on a synchronization between the needle motion and the bobbin action underneath. I once had a Singer that slipped and I had to reset the timing. If it is the timing synch problem then it would happen consistently and not work sometimes and then not work other times. G
Jan 27, 2014 | PfaFF Sewing Machines
Messages about safe device activated & press the needle position button
The noise is because the machine is trying to raise or lower a needle and can't move. Several things to check. Did the needle break and jam in the bottom thread? Is the needle bent or jam? Did the thread jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom carefully cut the threads until you can free the hoop and material. Then check to make sure all pieces of thread and fuzz has been removed in the bobbin case. If it happens again check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping.
Nov 27, 2013 | Brother PE770 Computerized Sewing Machine
Husqvarna #1+ sewing machine, is breaking needles under throat plate
This could be bad timing, or the needle is not in properly.
Make sure that the needle is pushed up all the way, and in the correct position. If the needle is too low, it will break.
Also, keep the bobbin case door open to see where the needle is catching.
Apr 10, 2013 | Husqvarna Sewing Machines
I have singer 6212 that will not pick up the bobbin thread, also I was trying to adjust the needle ans can't seem to get it back to the right position to keep it from breaking the needle. Does an
The housing of the bobbin was loose. Just tighten the screw then problem was fixed for the problem "needle won't pick up bobbin thread" with my Singer 6212.
Nov 24, 2012 | Simplicity Sewing Machines
How do I get Singer zigzag 457 to stop hitting the needle on the bobbin housing?
the sewing machine is out of time & needs to be retimed at a
sewing machine repair shop.
here's a link for a free manual
http://www.singerco.com/uploads/download/5d6ce627c00cb91c477d4703f1b704aab08a72c8.pdf
Sep 11, 2012 | Singer Sewing Machines
Janome Thread Banger TB12 Sewing Machine Logo
1,548 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
