Question about LG LSC26905TT Side by Side Refrigerator
I have an LG refrigerator, model # LSC26905TT, and one of the handles is loose and I can't figure out how to tighten it. I've tried taking the plastic caps off of the end of the handle to get into it that way, but I'm afraid I'll break the caps while trying to get them off. Is that what I'll need to do? Also, the refrigerator is level, but the doors swing open if you don't hold on to them, and won't close by themselves.
    New Friend:
    Problem Solver:
  • 12 Answers
Handles has a small allen screw in the inside part , and to make doors close it has to be higher at front , someof them youcan adjust front legs
Posted on Jul 16, 2017
SOURCE: Door Handles Loose
Pry off the covers carefully and tighten the screws. The covers will come off. You can even place a thin piece of cardboard between the screw drive and the refrigerators surface so you wont scratch it. Hope this helps
Posted on Aug 09, 2007
thanks....I solved the problem with your help
Posted on Sep 03, 2007
SOURCE: Freezer Door handle came off after 1 yr.
I had this problem with the bottom freezer door of my Amana.
What I did was slide off the entire door handle by applying pressure pushing toward the right to get the handle off. Once the handle was off, I slid the clip (which was still clipped on to the door) off and screwed it back on to the handle. Once the clip was tightly secured to the back side of the handle, I carefully slid the handle bar back on to the door by sliding it to the left back on to the door clips until it clicked securely back into place.
Posted on Mar 28, 2008
  • 489 Answers
SOURCE: Loose Door Handle
There is no adjustment for the door handles.  The brackets are metal pressed and if they become loose, it is recommended that they be replaced.
Posted on Jun 11, 2008
SOURCE: loose handle on door
for GE profile french-door freezer door, pull right...
Posted on Oct 19, 2008
Loose door handle thermador refrigerator
I'd appreciate thoughts on how to tighten THERMADOR not another brand refrigerator door handles. Model: KBUDT4860 A02 which is a stainless steel side by side 2 door freezer / refrigerator. Thanks.
tried the other suggestions above and damaged the surface.
Jan 16, 2013 | Thermador Refrigerators
I need to know how to fix the water valve and the ice maker line om my LG Refrigerator Model # LSC26905tt
The plastic water hose hanging in the back outside of my LG refrigerator that connects to the main water pipe has many little, tiny holes. I tried to change the hose but I couldn't find a way to take the old hose out to switch it with a new one. Will you please give me some directions how to do it. Thanks.
Jun 04, 2011 | LG LSC26905TT Side by Side Refrigerator
DOOR HANDLE LOOSE MODEL#gs5shaxnq00 Whirlpool sxs Ref side
Ther is nothong wrong with the ice Dispensing unit the screws in the door handle are loose and we can not figure how to tighten them.
the model# is GS5SHAXNQ00
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Loose door handles.
There was a plastic card the size of a credit card that came with the refigerator that helps release the handles. If you don have this you can use any stiff plastic card ie: blockbuster card, store card etc...
Pull the handle away from you while inserting the card in the top or bottom of the handle based on your model. I believe the Admiral model LSD2615HEB required the card be inserted 11/16 of an inch. This should release the handle. Once released there are 4 hex screws located on the handle that may require tightening.
To reinstall: Match the hardware up just above the final location and then slide down, this should lock the handle back into place.
Feb 24, 2009 | Admiral 26 cu. ft. Side-By-Side...
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
LG LSC26905TT
You must remove the doors.. There are instructions in the manual on how to do it.
Aug 08, 2008 | LG LSC26905TT Side by Side Refrigerator
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Door Handles Loose
Aug 09, 2007 | LG LSC26905TT Side by Side Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
111 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
