Question about Lexmark T630 Laser Printer
241 Paper Jam, missing spring?
241 Paper Jam, it looks as if a spring has come off from somewhere leaving a sensor useless but i can not fifure out where the spring goes!
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Lexmark Expert
  • 217 Answers
Mostly the "bellcranck spring" comes of because of a defective "bellcrank". Partnumber 56P1228. This "bellcranck" is possitioned on the right side of the paperpickup assy.
Posted on Jul 07, 2010
How do i fix paper jam
Look for small torn off paper @ the sensor, 2 ) clean the sensor 3) check the actuator it might be deformed 4) check proper position of tension spring of the actuator. Some Printer & copier has reset procedure after removing the paper jam.
Jan 05, 2015 | Office Equipment & Supplies
Error P00
A few easy things to try. First off, have you power cycled the unit since checking for a paper jam? Often that will clear false errors. If not, look for the sensors. They should be somewhere along the paper path, and consist of a plastic lever that will be pushed down as the paper moves past them. Usually these levers have springs attached - if the spring comes off, it will register a paper jam. You'll probably have to take off some of the housing to get to them. I'm not sure this will help much, but since I found it I'll post it. The user's manual: http://edocutek.com/Manuals/DR6080_9080C_UG.pdf If the sensor needs replaced (most often due to something simple like a piece of plastic breaking on it), you can order new sensor PCB assemblies (sensor and its small control board) here: http://www.precisionroller.com/manufacturers/canon-dr6080.html They also sell a parts manual, but it's a bit pricey.
Sep 08, 2007 | Canon DR-9080C Path-Through Scanner
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
241 paper jam message
Lexmark T630 241 paper jam message - Indicates a paper jam from the pull down manual feed tray.
If you check to make sure and small fragments of paper are not hindering the operation of the switch. The switch is located on the left side of the tray and will be spring loaded. The switch should move freely without binding. Make sure no toner or dust is on the optical sensor assembly. See Diagram for location.
If the switch seems OK and the printer still reports an error, the printer will require professional care.
Jan 15, 2011 | Lexmark T630 Laser Printer
Sharp al-1631 misfeed light will not go out
This usually happens when a sensor that detected a paper jam has not reset itself after removing the paper. Make sure that when the jam was removed - all the paper came out and there is/was not a small piece missing that could have been left behind in the copier and is hiding somewhere. If you are sure the paper has all been removed then what could have happened is when the jam was being removed it could have caught on one of the paper sensors. This could pull the little flag that activates the sensor out of place - giving a false paper jam message. there are only a handfull of sensors in the paper path. remove the paper tray and make sure there is no paper stuck behind the tray or in the cavity where the tray goes. look and follow very closely the path the paper takes - look for any sensors/flags the paper would avtivate and make sure the flag moves freely and is not lopsided.
Make sure you also try unplugging and replugging the copier from the wall.
Hope this helps
May 19, 2009 | Sharp AL 1631 Copier
241 paper jam
Check the paper tray guides, check the the paper feed roller (remove the tray and look up in the printer) it is possibly worn and needs replacing, you can try to clean it (hand soap is as good as anything)
Apr 15, 2009 | Lexmark C510 Laser Printer
Optra 2450 error 241
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Lexmark Optra S 2450 Laser Printer
A "P" shows on the screen but no paper jam at all
You probably have a piece of paper in there some where, your not seeing it? get a flash light look real close. This is a paper tray code, take the trays out, all the way look in there, Open the side door to the left look in there..
Or it could be a bad sensor. but I would guess there is a piece of paper there. (happens all the time)
and remmber " if you rip a piece of paper out, look at the sheet, if there is a piece ripped / missing from the paper, that piece is in the machine somewhere"
This is a link to your manual..
http://www.sharpusa.com/files/cop_man_soho_AL1642CS.pdf
Oct 29, 2008 | Sharp AL-1642CS Copier
IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Aug 19, 2008 | IBM Infoprint 1332 Laser Printer
Paper jam won't clear
Look for a small piece of paper remaining in the machine.
Also there may be a jam switch actuator that has fallen off.
Dec 07, 2007 | Panasonic Workio DP-2310 All-In-One Laser...
Lexmark T630 Laser Printer Logo
456 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
