Question about Whirlpool Dryers
Dryer will not heat up. Where do I start?It has power,and will run but no heat.
    Problem Solver:
  • 16 Answers
There are a few fuses in the back of the dryer. All of them should have continuity. To get to them you need to remove the back of the unit. It should have 1/4 inch screws. UNPLUG the unit. disconnect the leads to each thermostat and check to make sure they are not open. While you are back there, check the heating element for continuity also. Once you find the bad one, replace and you're done.
Posted on Jul 06, 2010
LEC6646
follow this steps and fix it. Merry Christmas
. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Dec 18, 2013 | Whirlpool Dryers
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
Dryer runs but does not heat. Replaced the fuse, thermostat, and the heating element. Still runs but no heat. If you ground the top blade on the thermostat. The dryer will start to heat
you need to check and make sure that you have enough power to the unit.
if you can check the continuity on all the thermal fuses and find one that does not have any continuity then it needs to be replaced.
Dec 24, 2010 | Kenmore 62602 Electric Dryer
Kenmore Elite electric dryer, no heat, runs if holding start ****
with this combination of problems it sounds like a power problem on the control board being you have more than one problem,it sounds as though you arn't getting a latch voltage at the relay energizing coils that latch the relays to power the motor and element
Apr 16, 2010 | Dryers
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
2. Heating element
3. Thermal fuse
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How do you check voltage to dryer?
The first thing you should check on a electric dryer when it does not heat or run is the voltage at the cord.
If you do not have the correct voltage your dryer will not heat and may not even start.
The dryer needs 240 volts for the heater to work. It gets 240 volts by using two 120 volt lines. If one of these 120 volt lines is dead it will not heat. It may or may not still run as the dryer only needs 120 volts for the motor to run.
If you have one 120 volt line missing power and it is the same 120 volt line that runs to the motor then the dryer will not run or heat.
May 30, 2009 | Dryers
Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
Dec 15, 2008 | Whirlpool LGR7646E Dryer
Dryer is running but it's not hot
If the electronic start is not working, it may need to be replaced. Call an appliance parts store and ask some specific questions to them about how you can test that component and if they carry a replacement for your specific make and model. Good Luck!
Jul 05, 2008 | Whirlpool LGR7646E Dryer
Dryer heating element
There is a fuse in the dryer for the heat.
Before tearing into the dryer, make sure the power getting to the dryer is absolutely correct. (check power with the dryer running) Even with incorrect power to the dryer. the drum will still turn but there will be no heat.
Many a person has paid for expensive service calls for the problem you are having only to discover by the servicer that there was nothing wrong with the dryer but had bad power to the dryer......
Jun 15, 2008 | Whirlpool Dryers
Open Questions:
Dryers Logo
41 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
