Question about Apex Digital AVL2076 20 in. EDTV-Ready LCD Television
AVL 2026... Is there a fuse in this tv? It just went out while watching. No problem with the power outlet. Thanks in advance.
Yes, there is a small circut board mounted fuse on the main board. Its looks like a resistor but its glass and has a filament inside.
Posted on Apr 05, 2009
  • Anonymous Mar 03, 2010
    is the filament broken.
What could be the problem? do i need to replace power board?
check internal fuse, power cord, power of outlet where cord is plug into.
Oct 06, 2015 | Sony BRAVIA KDL-46EX400 46" LCD TV
No power
Did you try connecting the TV on a different power outlet? just to check if its a prioblem with the outlet... IF still no power this is a problem with the power supply of the TV that may needs replacement..
Hope that helps........
Sep 02, 2008 | iLO 3200 32 in. LCD Television
Was watching my samsung LN55C630 TV and all of a sudden it just went dead. nlo picture and no sound,also the power light went out thats normally on when the tv is off.
Check the circuit breaker first for power to the outlet it is plugged into. If it is in a power strip then make sure that the reset is hit on that. I sounds like you had a line surge for some reason. If all else fails there is a fuse on the power board in the TV. Check to see if that is blown. If not check for black burn marks on the power supply board. Could have blown that altogether.
Mar 05, 2014 | Samsung Televison & Video
I have flat pannl Vizio 42" ..Watching TV...a loud crack came from TV and set went blank and will not come on...tryied reboot...still unresponsive..
I'm sorry that the TV has produced a loud crack and not turning ON. Please check the following troubleshooting steps and check the operation:
  1. Please make sure that the connections are secure and proper.
  2. Connect the TV to a different wall outlet and check the operation. (Connect it directly without using Surge Protector)
  3. Perform a power resetting and check the operation. To perform the power resetting, unplug the TV from wall outlet for more than 2 minutes and then reconnect it.
  4. If the issue persists, please open the cover of the TV and check the Power board for any burned fuse.
  5. Use a multi-meter and check whether the Power board is outputting +5V.
  6. Replace the fuses if necessary. Most Vizio TVs using fuse 0185-1302-0073(Part #).
If the issue persists, physical evaluation is required to find the exact issue. You can click hear to locate your nearest service facility to get the TV evaluated.
Thanks for understanding.
Sep 11, 2011 | Vizio 42 in. LCD TV
Hi,Iwas watching TV and the screen went black.No lights on,I unplugged and plugged again but anything happened. My TV is a Toshiba Regza model 42RV530U. Can you help me? Thanks
If there was a popping noise of any kind when the tv screen went black there's a high possibility that one of the fuses in the tv popped and there is no power to the tv. It could also just be the outlet itself and try plugging the tv to different working outlets.
May 24, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
We have a Sony KV-35V36 TV. Will watching TV and the power just went off. We get no power all all anymore. How do you ge the the fuse on this TV.
The fuse is inside the chassis and likely soldered. Unplug the TV, press and hold the power button for 30 seconds, repeat. Plug it back in and see if that has reset it.
Is the outlet good, or did the power outage trip the breaker?
Apr 22, 2011 | Sony KV-35V36 35" TV
We were watching our brand new TV, we set it up 2 days ago, when the power for the TV went out. We tried using another outlet to make sure the the outlet wasn't bad but we still have no power on the TV....
Try a lamp in the outlet and since the outlet has power, the problem is in the tv set.
This new set is under warranty and you should return it to get it fix/replace.
This sound like the power supply board has failed. Probably the fuse on it has blown.
Feb 14, 2011 | Vizio 42 in. LCD TV
Digimate 26inch widescreen LCD HD ready TV My mom (92yrs) was watching her TV last night when it just went black. She thought there was a local power outage but there wasn't one. I've tried everything,...
Hi Fix Ya; Well, to be honest, I went to DIY dot com and posted my problem there and the moderator came back and told me how to fix it. But thanks anyway for your offer.
Aug 11, 2008 | Televison & Video
Not Powering Up...Please Help Me!!!
This may sound silly but check your circut breaker or if you have a GFCI on your outlet because maybe you have too many things plugged into it. Plug a lamp or something into the outlet. If you are sure it is the TV check the owners manual for common troubleshooting. After that I would pursue the warranty; it should be 1 year with this model.
May 15, 2007 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Apex Digital AVL2076 20 in. EDTV-Ready LCD Television Logo
104 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
