Question about Linksys Wireless-G WRT54G Router
My internet delivers less than 2 mps when I connect my Linksys it does't work
  • 506 Answers
This speed is actually too small. That may be the reason Linksys can't relay the connection to your laptop. Try and get an improved link speed and make sure the linksys picks the IP address of the service provider (ISP) because it needs the IP address to be able to connect connected systems.
Posted on Jul 06, 2010
My new HP Omni all-in-one has a Ralink Tech 802.11n wireless card with driver up-to-date that connects to my D-link 655 wi-fi at 36-54 mps. My other devices, including my Dell Vostro noteboook,which is...
Welcome to Fixya. The 130Mbps is the connection speed to the router. Not to the Internet.
You will get a reported 130Mbps, But, you arent really getting 130Mbps. of connection speed, its false. Try to check the package of your internet connection and run a speed test on both computer using Speedtest.net to test the real speed of your internet connection.
If you have question please let me know. Thanks using Fixya.
Jun 04, 2011 | HP OmniBook 6100 Notebook
Unable to connect to the internet with my linksys wrt120n router through my at&T modem. The AT&T router works fine by itself. But will not communicate with the Linksys router
If you connect the computer directly to the AT&T modem , it work. That means the modem is working properly.
AT&T is DSL connection type. the DSL connection works on 2 different modes. 1) DHCP 2) PPPOE.
Now you will need to connect the modem and the computer to the router. open the set up page of the rotuer.
The set up page is the page where you can change the settings of the router.
According to the type of internet connection you can change the settings of the router
Click Here for step by step by instructions
Feb 16, 2010 | Linksys WRT120N Router
Linksys speed cut off
First, are you connected via Ethernet cable or are you linking via Wi-Fi? If Wi-Fi the speed is alway slower (up to 54 Mps) If connected by Ethernet, your connection speed should read 100 Mbps. Once you have determined the connection mode and speed.unplug the wireless router and connect the computer directly to the modem. Now test the speed and see if the speed lag is still ther. If not, you have a routing /networking issue but, it it is still the same speed, it could very well be heavy traffic ( a lot of people drawing from the same local area signal., usually at specific times of the day).
Nov 24, 2009 | Linksys Wireless-G WRT54GL Router
Linksys Wireless WRT54G Router Won't Connect
Here's something you can do.
First, power off the modem and the linksys.  Then swap the yellow cable with the blue cable (this time, connect yellow cable to port 2 of Linksys)
Now, turn on the Modem first... wait about 1 minute, then turn on the Linksys.
1. Log into the router and go to "Status" tab.
2. You should see something called Internet and under it Configuration type.  If all you see is 0.0.0.0 without a gateway address, it didn't work
3. You can also see 2 buttons at the bottom of the screen.  Click on "DHCP Release", then "DHCP renew"
4. look at the configuration type and see if it is no longer 0.0.0.0 Then try connecting to the internet to a website you have not visited (do not try the same websites as before when you initially tested).
Jun 29, 2009 | Linksys Wireless-G Broadband Router
Not all ports working
Sounds like you may have some wires cross between your switch and your router. And if someone worked on your pc, there probably something wrong with it too. Most places dont know how to fix a computer they just reinstall the OS and hand it back to you, less the unique drivers from your computer mfg for hardware such as network adapter drivers. Connect dirctly to the modem and got to dell support or whomever and check drivers
Aug 27, 2017 | Linksys SD208 8-Port Ethernet Switch...
Somehow my own wireless connection is not being recognized. I noticed my speed is at 54mps and not 100%. I am hooked up to another Linksys and my computer is running very slow. When I see my own connection...
HI,
Thanks for responding. To me, my router was running before at 100 mps. I took a better look and someone, somehow has tapped into my computer. My computer tends to stop working in browsers and I keep getting notifications to block access. My own router is showing, however I cannot access it. I will have to refresh my network, and reenter my own network and get that creep off my system.
Thanks for your help.
Dec 02, 2008 | Computers & Internet
Slow Speed on Wireless Connection
As you said , try upgrading your routers firmware, but the better fix would be for a n router with a n card you will have a proper synchronisation and good speed.. or else the speed will vary, for a g router and n card..
Oct 23, 2008 | Linksys Wireless-G WRT54G Router
Linksys SPA2102 conflicts with my Router
I have the same problem and I configure my router in PPPoe with my username and password provided by my ISP and now my router is working...
Sep 04, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
How To Set Up PPPoE DSL Connections with a Linksys Router
This article describes how to manually configure a Linksys Router for broadband DSL that uses PPPoE (Point-to-Point Protocol over Ethernet) for authentication. For automatic configuration options, please try: 1. Linksys Easy Connect (see Answer ID 1650 for more information), or 2. The Linksys Setup Wizard CD-ROM software that came with your Linksys Router. Simply insert this CD-ROM into an online computer before connecting your Linksys Router, and the Wizard will provide step-by-step instructions on how to install and configure your router. If you are unable to set up your Linksys Router by using one of the above options, use the steps below to manually configure your router. NOTE: It is recommended that you print this article for offline reference. STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
