Question about GE Refrigerators
Where is timer for tbx14smdr refrigerator - GE Refrigerators
In there a defrost timer
Great Majority Combo: Refrigerators Freezer Have Defrost Timers. .IF Has a FREEZER Will Have Defrost Timer ! .Many have defrost timer Below on LH or RH Walls at Bottom by Compressor Compartment..Others Have Timer on upper Partition Wall/Ceiling of refrigerator between Refrigerator & Freezer By Thermostat Long Protuding Cover.( .IF Provide Brand Model # & Serial # Of Refrigerator Most likely will get more accurate Location of Defrost Timer
Dec 20, 2015 | Kenmore Refrigerators
Tip
How to Replace a Defrost Timer in a refrigerator?
What is timer?
Timer is a small motorized unit that controls the function of defrosts cycle in a refrigerator. The defrost timer tells the refrigerator when to cool and when to defrost any ice frost collected on/in the evaporator coil.
Now the procedure to replace the timer is as follows:--
1) First of all for proper safety please unplug the unit from power outlet.
2) Then to locate the timer. It is located behind the refrigerator beside the compressor of the refrigerator. You will have to remove the metal kick plate on the bottom of the refrigerator. In older models refrigerator it is built into the icemaker unit.
3) In some models timer is fitted by the screws on the side wall of the refrigerator unit. so if screws are seen remove the screws holding the timer to the refrigerator wall.
4) Then slowly/carefully remove the timer out of the unit so you can disconnect the wiring from the connectors. For easy access of connectors try wiggling the connectors back and forth it will be disconnected.
5) Before removing the connectors please take a note of which connector was connected where and in what position.
6) Then take a new timer and plug the connectors in same position and at same spot in the new timer.
7) The refit the screws if you removed while removing the old defrost timer, replace the kick plate cover and plug in refrigerator and check out.
This will help. Thanks.
on Mar 10, 2010 | Refrigerators
Refrigerator part of coil freezing up, what would be the problem?
2) Some refrigerators contain timers that control the self-defrosting heaters. Unfortunately, it can be hard to find the timer, depending on the model of your refrigerator. In most cases, side-by-side refrigerators that have temperature control knobs at the top of the fridge compartment often have the defrost timer located near the thermostat behind the control knobs. It looks like a small, round object with one flat end that has four electrical prongs. It is also often located in the control panel, behind the fridge or behind the foot kick panel at the base of the appliance. Use a flathead screwdriver to advance the timer until you hear a click. This should start the defrost heater. If it doesn't, the timer probably needs to be replaced. Continue to turn it clockwise and a second click will be heard, which turns off the defrost heater. If the timer isn't clicking, simply pull it out and "plug in" a new timer.refrigerators that don't have timers have control panels that control the self-defrosting unit instead. The control panel can sometimes be tested using the controls on the water dispenser or by removing the rear of the front panel to access the controls. A simple press of the button will run several diagnostics that will test your defrost timer, thermostat and heater. The specific instructions vary depending on the model of your Kenmore refrigerator. Consult your owner's manual to run the diagnostics if you have a control panel in your refrigerator.
Read more: http://www.ehow.com/info_12180665_repair-kenmore-refrigerators-coil-freezing-up.html#ixzz2a25eGLEL
tests this steps and fix it. God bless you
Jul 25, 2013 | Refrigerators
Defrot timer biometal
Kenmore Model Numbers Look Like 795.513012
Turn the timer slowly clockwise until the compressor and fans stop. Leave the timer alone in that position that turned the compressor and fans off for up to 35 minutes. In the first few minutes after the timer turned fans and compressor off you should be getting defrost. If timer comes on by itself and you have defrost results the timer and defrost heater are good. If the timer does not turn the refrigerator back on but the defrost took place then replace the timer. Every different refrigerator or freezer has a different amount of time on for cooling and time off for defrost so it is important to know what the model number is to answer the part number and time off/on ratio. What is the model number of the refrigerator that the timer is on? Sea Breeze
Jun 30, 2013 | Refrigerators
Defrost is stuck in one all time it not cooling or freezing
A DEFROST TIMER is a cycling device, it times the frequency and duration that the defrost heater coils melt the ice that builds up around the evaporator coils. If ice is allowed to build up, air will not be able to freely flow past them - resulting in reduced efficiency and sometimes a drastic warming of the cooling unit.
Most of the time, the defrost timer is in the cooling mode, allowing the compressor to activate when the thermostat signals it to. The remaining part of the cycle (usually less than 30 minutes)the timer is in defrost mode. In this mode, it signals the defrost heaters to melt the ice build up on the coils. This defrost action is limited by the defrost thermostat. If your DETROST TIMER go to bad, one symptom would be if your refrigerator is not cooling. Although there are many causes of this symptom, A stuck defrost timer can be one of them. The timer can get stuck in cooling (compressor activated) or defrost mode (defrost heaters activated) for usually two reasons:
- The timer motor can fail for one.
- The gears can also become locked up.
No matter what the reason is or which mode the defrost timer gets stuck in, the refrigerator can stop cooling. When the refrigerator is stuck in defrost mode, the compressor no longer comes on to cool the unit. If the timer gets stuck in cooling mode, the evaporator coils never get a chance to defrost, causing ice build-up to the point where there is a complete blockage of airflow past the coils.
The defrost timer can also cause the refrigerator to stop cooling due to failure of the internal switch which activates either the compressor or heater coils. Finally, when doing any repair on a refrigerator, check the condenser coils for dust buildup and clean accordingly.
According woth yur brand and model, look the part replacement in this link: partselect.com/refrigerator+test-defrost-timer+repair.
Good luck.
Jul 16, 2011 | Refrigerators
Where is the defrost timer located
The timer is located in the fresh food section. Open the refrigerator door and look up, its in the control housing.
You can purchase the defrost timer at the link below.
GE Defrost Timer Link
Mar 08, 2011 | GE GTS22WCP Top Freezer Refrigerator
Replacing defrost timer,needs manuel
I check there is no free manual for Kenmore, I find. Better follow these steps to replace defrost timer.
Unplug the refrigerator. Locate the defrost timer. The timershould have four metal terminals coming from the bottom of the unit. It isusually situated behind the refrigerator, in the refrigerator's control panel,the freezer compartment toward the front of the cabinet or behind a metal kickplate on the bottom of the refrigerator. Older Kenmore models may have it builtinto the ice maker. Remove the defrost timer by takingoff the kick plate (if there is one) and removing any screws attaching it tothe refrigerator or freezer. Carefully pull the timer out from the wall of theunit so you can disconnect the wiring from the connectors. If removal isdifficult, try wiggling the connectors back and forth to help loosen them andpull on them firmly. Plug the wire connectors into thenew defrost timer and replace the timer in the refrigerator. Secure with screws, replace coverand plug in refrigerator.
Thanks and helpful?
Jan 23, 2011 | Kenmore Side by Side Refrigerator
Everything in ref freezing up
1)check the temperature setting.it should be set on normal mode. 2) check if the ventilation in the fridge are blocked .there are two possibilities you will have to check 1)the defrost timer 2)the evaporator coil. How a common frost free defrost cycle works and the main parts. When the refrigerator is running ( cooling mode ) the defrost timer contacts prevents any power from getting to the defrost heater. When the defrost timer turns off the power to the compressor and fan motor(s) the power is then redirected to the defrost system. The defrost timer motor. Defrost timers:
The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
*Some defrost timers are a constant or continuous run timer, which means when ever the refrigerator is plugged in the defrost timer is powered up and running. Some defrost timers are an accumulative run timer, which means when the refrigerator is off the defrost timer is off and not running, when the refrigerator is running the defrost timer is running. This is also sometimes called a demand defrost. The power for the defrost timer goes through the cold control first on an accumulative defrost system. The timers are often the same but will be wired differently to get the different operations.
the evaporator coils are located at the inner side of the freezer section.if the ice gets collected in the coil and the evaporator fan stops running then the inner system of refrigerator will get over cool and this problem happens.
now to solve the issue .if to check evaporator coil is faulty or not there is a system.just unplug the unit from main power outlet then wait for 24 hours.then replug the power cord in the main power outlet.in 24 hours all the ice collected in between the coil and anywhere will get melted and then check out.if it works properly the problem was ice in coils.but if same problem then defrost timer needs replacement,you can get new timer friom
--- www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 10, 2009 | Frigidaire ATF6000ES Front Load Washer
WHERE IS THE DEFROST TIMER LOCATED ?
Hi
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 31, 2009 | Refrigerators
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
