Question about Timex Ironman 30 Lap 53952 Wrist Watch
How to set the time
How do I set the correct time
    Genius:
  • 1,970 Answers
Mcdevito75 here, In most cases you"d press MODE and see the display blinking, then press set to change each function, pessing MODE again after each function change to move onto the next, When all functions are set press MODE again for a steady display.
Posted on Jul 07, 2010
How to set the day of the week
here is your manual (I think)
http://cdn.invictawatch.com/invictawatch/website2014/webroot//uploads/manuals/2-8040n-pdf
If not, their site is pretty good.
http://invictawatch.com/service/view-the-instruction-manuals
nice video but as good as a chocolate teapot!
https://youtu.be/iv0aXQNH4yY
anyway, here is your info
Invicta Watch Setting Instructions By Ashley Brown eHow Contributor Found This Helpful A watch is only useful if it displays the correct time. Over time, your watch may display the incorrect time as the battery wears down. After installing a new battery, you will also need to reset the time. All Invicta watches have similar instructions for setting the time. Setting the time does not require any tools or equipment.
Other People Are Reading
Watches with Time Only
  1. Pull out the crown. The hour and minute hands will stop.
  2. Turn the crown until the hour and minute hands are positioned on the correct time.
  3. Push in the crown to start the watch.
Watches with Time and Date
  1. Pull out the crown to the first position. The crown can be pulled out to two different positions. Pull gently once to reach the first position.
  2. Turn the crown until it reaches the correct numerical date.
  3. Pull out the crown to the second position.
  4. Turn the crown until the hour and minute hands correspond to the correct time.
  5. Push in the crown twice. It should now be resting firmly against the watch, in its original position.
Watches with Time, Day and Date
  2. Turn the crown to reach the correct day.
  3. Turn the crown clockwise to reach the correct date.
  4. Pull out the crown again to the second position.
  5. Turn the crown until the hour and minute hands display the correct time.
  6. Push in the crown twice so it rests against the watch. The crown should be back in its original position.
Read more : http://www.ehow.com/how_7352591_invicta-watch-setting-instructions.html
Sep 13, 2015 | Invicta Watches
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Jul 13, 2015 | Geneva Watches
To adjust the analog time for ga-110hc-1a
Analog time follows digital time.Correctly set your local time and analog time will come up correctly as well.If not, try to run the hands alignment procedure (H-SET) following manual instructions.
Mar 02, 2013 | Casio G-Shock GW500A-1V Wrist Watch
I just purchased a Heritage Mint Ltd Timepiece Quartz Regulator wall clock but it chimes two hours slower than the actual time. Need to know how to correct it. There is a red push button on the back of...
I have the same clock. Here's what I did to re-set it after changing batteries: After replacing batteries, use the turn dial to set the correct time. Press the RED button 6 times, wait for it to go through that series of chimes, then press the button again to set the time.
Example: Press RED button 6 times. Wait for it to chime. Press RED button the correct number of times for the hour to be set. For 5:00, press the button 5 times, etc.
I lost the directions to my clock, and I am posting this from memory and also just had to re-set mine and it works OK now.
Hope this helps!
Feb 07, 2011 | Watches
I have an OCW-M 800. I have downloaded the manual from mfg. website and cannot seem to get it to set the time for EST correctly. THis watch cost me over $500.00 and is so complicated that I fear I have...
I am not American, so I am not familiar with the definition of "EST" or which of the four "city" settings is correct for you.
Having read the instructions I see that for America you have to select "USA" first and then the appropriate city, have you done this?. The list of four options covers 4 time zones, so you should be able to get the correct time for your area.
When I bought an atomic watch recently, I had to leave it overnight to catch the timekeeping signals. I see that you posted your question only 14 hours ago. How long have you had it. GIve your watch a day or so for it to latch on to the correct time.
Check that the "autoreceive" is "on".
Check that the daylight saving time (DST) is correctly set. The manuals indicate that some areas may not be using it?
Keep trying - it is nice to have a watch that is always correct!
Oct 04, 2010 | Casio OC500 Oceanus watch
I have lost the instructions and cant set the time
Try Googling (pod)(548)(manual) without parens.
Aug 04, 2017 | Watches
Setting the correct time on Seth Thomas clock.
Correct technique definitely is CLOCKWISE ONLY. You are unbelievably lucky person if did not damage striking mechanism within 25 years while adjusting hands anti clockwise. If I'd have such a luck, I'd try to play lottery. :))
Feb 04, 2010 | Timex Watches
I have an ESQ Aerodyne and the time set by the
this watch needs to be taken in as this is not proper time telling. has the johnson rod been used yet. if not, do so. if so have it taken in and checked with a caver device.
Jan 01, 2010 | ESQ 07301132 Aerodyne watch
Casio Wave Captor Watch wont set to correct time.
You need to manually adjust or set the hands to the home position as they are not where the watch thinks they should be. This can happen when you bring your watch close to a strong magnetic field. Look in the manual to do this. Afterwards your watch should set to the correct time.
Apr 21, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Tozai digital watch-setting correct time/date
I need to correct the time/date setting on a tozai digital watch.
Apr 05, 2009 | Watches
Timex Ironman 30 Lap 53952 Wrist Watch Logo
90 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
