Question about GE Washing Machines
Drum vane is broken. Have a new one. How do I remove it?
  • laurentwebb Jul 07, 2010
    Solution was spot on. Job finished in three minutes or less. Many thanks.
  • 6,784 Answers
Hi. I have posted a guide below to help with your repair. Follow carefully.
Posted on Jul 06, 2010
  • Michael Masters
    Michael Masters Jul 06, 2010
    For Kenmore brands, Click here and Here
  • Michael Masters
    • Maytag brands will essentially need to be unscrewed and moved forward towards the door to be release. You will need a hex screw driver to release the mounting screws in the Maytag models. The first post will concern all GE front loaders.
HOW TO CHANGE THE DRUM BAFFLE VANE
It does on some machines but not on others but you do not specify what machine you are enquiring about
Sep 04, 2014 | Washing Machines
How to remove Frigidaire water vane?
Good Morning Friend,
I understand you want to know how to remove the water vane on your Frigidaire Affinity washer, model# FAFW3801LW. I see that there is possibly a penny inside the vane that you can hear an feel as the drum rotates. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance, and should be able to take the vane off and remove the penny with ease. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Frigidaire Affinity FAFW3801LW 27"...
Gltf530dso frigidaire washer
http://www.appliancepartspros.com/frigidaire-vane-131274600-ap2106479.html
This is the part. You have to remove all the panels, The drum counter weights and finally the drum. Then you have to remove the inner drum from the plastic outer drum. Once removed you can get to the screws that hold the paddles in place. Then put it all back together. It may be easier to call a repair man in your area.
May 23, 2014 | Washing Machines
How to replace drum vane
I believe the vane needs to move forward to remove from tub, needs a lot of pressure to get it out. sometimes if you tap it with a hammer it will release. new one slides in pretty easy.
Jan 18, 2011 | Frigidaire GLTF2940ES Front Load Washer
Need directions to remove broken drum vane in a Frigidaire Gallery Front loader washer (GLTF2940FS1).
Open the top of the machine (look behind the top for several screws to remove) and slide it back to release from the cabinet. This should give you access to the screws that hold the vane in place. Hope this helps!
Jun 28, 2010 | Frigidaire ATF6000ES Front Load Washer
One of the vanes inside my gas dryer is loose and makes a loud banging sound when the dryer runs. How can I tighten it?
depending on style dryer,you need to access drum.usually top will pop up and hinge back.rotate the drum by hand counter clockwise till your loose vane is on top,you should see screws or maybe a missing one .add flat washers to secure better.If the plastic threads are broken/stripped replace vane. Hope this helps ,Please rate my solution. :)
Jun 25, 2009 | Dryers
Removing drum vane
No! Remove the screw holding the vane and slide it towards you. It will then come out.
May 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Money (change) caught inside interior drum plastic pieces.
Remove the top lid.
Rotate the drum until a vane is at the 12 o'clock position.
Remove the screws from the drum holding the vane in place.
May 10, 2009 | Kenmore 63942 Dryer
Kenmore Elite Dryer with loose paddle- can I glue?
Unplug the dryer.
Remove the lint filter.
Remove the screws at the lint filter opening.
Pop the lid clips on the left and right front corners of the cabinet.
Rotate the drum counterclockwise until a tumble vane(paddle) is at the 12 o'clock position.
Tighten the screws going through the drum.
Repeat this for the other 2 vanes.
Re-assemble the dryer.
May 10, 2009 | Whirlpool LEB6300 Electric Dryer
Removing top from Whirlpool Gold Ultimate Care Model GEQ8858KQ0 Dryer
Here is the answer to my own question and for anyone else who may have a similar noise problem with coins , metal objects, etc getting under the vanes or fins in the dryer drum. DISCONNECT OR UNPLUG DRYER-Remove 4 screws from the back edge of the control panel on the back of the dryer. Then lift up on the backside of the cover that also has the control unit attached to it. Slide the top cover towards the front of the dryer and then lift up on front and lay the entire cover and control panel towards the back of the dryer. A wall works great to hold this out of your way. The control panel remains on the cover and the drum will stay intact. Rotate the drum to locate which fin or vane the object is located. Move this vane to top and then remove three screws that is holding the vane. These are course threaded screws that screw into the plastic vanes. a nu6t driver was required. After removing the vane I found a quarter, and a few lint balls, There are only three vanes in the drum, so take about 10 more minutes and remove all three vanes to clean out the lint.To reinstall cover slide the cover back onto the two clips(one on each side) push towards back, checking to make sure front is held down by the clips, then replace the 4 screws on backside of dryer. If the lady of the house is around, it would now be a good time to clean out from behind and under the dryer to get up the rest of the dust, lint, and whatever remains or was lost.
Sep 01, 2008 | Dryers
Washing Machines Logo
49 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
