Question about Bryant 463AAC008BA Air Conditioner
AC unit Fan on unit not turning
  • Alexander  Figueroa
    Alexander Figueroa May 11, 2010
    fan on condenser of indoor unit?
  • bj Klark Sep 02, 2013
    no, outdoor unit
Fan on outside unit not turning. Fuses checked.
Posted on Jun 10, 2008
  • 149 Answers
If its a a window unit suspect a faulty fan capacitor or bad fan motor same with outside, if it ain't moving or turning on the fan is faulty or the capacitor is faulty
Posted on May 06, 2008
    Alexander Figueroa Jul 22, 2008
    defective condenser fan and capacitor
Temperature sendin unit needs replaced it sends a signal to the dash for temp and also to the fan switch. The ac is turning on the fan because, when ac is on the car would run warmer, so the ac switch is also connected to the fan. Are you saying that the ac kicks on when iddling or that's the only time you can turn it on
Jun 19, 2012 | 1996 Cadillac DeVille
Replacing a condenser fan in centralized A/C
On of the common problem with centralized A/C unit is a bad condenser fan. I have known people who called an ac technician to fix their ac because of a bad condenser fan and suggested replacing the whole unit! Costing them a lot of money when all it needed was a 50 dollars condenser fan! If the condenser fan do not run or it runs only when you give it a push, it'sbad. You will also notice that it is vey hot. When replacing a condenser fan you may want to replace the starting capacitor too. Replacing a condenser fan is not very hard, just make sure that the power to the ac unit is turned off at the breaker box. Confirm that the wires are not live by using a meter or an ac tester. The fan motor are held with brakets sometimes just screws. Most fan you can buy that has reversible rotation by just reversing the plug. Make sure it is blowing upwards. If not reverse the rotation. So if you notice that the unit is not putting out cold enough air and you went outside and noticed the compressor running but not the fan, turn off the AC right away and do not use it untill the fan is replaced. Running the unit with a defective fan can damage the compressor caused by overheating.
on Jul 10, 2010 | Heating & Cooling
8 blinks on unit shutoff,no continuous run
Indoor unit Fan problem. This is caused by the Indoor fan being locked. Check fan motor is plugged in correctly, Electrically & Mechanically sound.
Check the fan motor turns freely, check the AC Voltage supplied to the fan motor, this will vary from 120 V ac at low speed to 170V AC at high speed. If no
Voltage is present the the PCB is faulty, if Voltage is present the fan motor will be Fault.
Jan 19, 2011 | Heating & Cooling
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
AC compressor wiil not turn on
You will have to find the contactor which is located in the outside unit. And check the voltage at the contactor, 26 v as this is the thermostat calling for the compressor to come on. You can also push in the contactor and see if the fan and compressor start. There should be an outside fuse box close to your condensing unit. Good luck
Jul 23, 2010 | Samsung AW1203B Air Conditioner
We have a MS42WN Mr Slim air conditioner. Can you tell me if there is a mode that turns the fan off when the room temperature is reached by the air conditioner? Right now if the AC temp is set for 78 for...
Most units the fan will stay on all the time,if you hit the fan button it will cycle through the speeds. The only way to turn it off is to power off the unit.
Jun 29, 2010 | Heating & Cooling
Portable ac blows warm air even after i cleaned filter
Make sure that the coils are all clean, Vacume cleaner with the brush attachment on the end works well.
Sounds like your fan is only working and not the Compresser that makes the unit an "air conditioner" and not a gloryfied fan.
Check and make sure that the butten is on Cold and that the small water drawer is in correctly so the shut off switch is making good contacts. Important Make sure that it is getting enough electricity at the wall plug, Because when the ac compresser 1st turns on it uses 3-5 times the power for the intial startup, not enough juice means no AC.
The fan only uses a little to blow but AC needs alot to start.
Unit should sound diffrent when AC compreser turns on compared to fan only on mode.
Sep 03, 2009 | Everstar Portable Heater/Fan
Ac inside unit problem
sounds like you have a bad evap fan motor, fan relay, or capapcitor. It's also possible your unit is froze up.
Apr 25, 2009 | Heating & Cooling
Outside unit come on for ac but inside won't come on for ac or heat
Turn Tsat to fan to see if inside unit will come on. If it does Tstat needs replaced. If not it is fan motor or fan relay. Possible cap. Do you here the fan relay come in. If it is a Good man unit it is time delay and you wont here it. Need to know your make of unit. Rusty
Fan will not shut off, but compressor does
hi! there, continous fan motor when unit was shutt off,since supply source was already cut off specially on fan condenser motor,the supply of your motor was came from relay mounted on your circuit board control panel,there a holding coil to hold the connection between your fan and ac source,shut off breaker for ac unit first before diagnosing ac unit, try to check this out the relay is still activated giving ac source when shut off,the contactor on relay holding your ac supply was shorted,try to check the connection the circuit activating condenser fan relay,eliminate the short circuit,using multi tester test rod,use manual diagram for circuit control board to lessen complicated diagnosing,focus on fan relay ac source then isolate checking the short circuit replace defective relay,contact point of relay are not repairable.take necessary precaution on checking to avoid shock,this a hard task i would suggest that certified ac technician w/ full knowledge of instrumentation should do this.thank's for selecting fixya and have a nice day.
Mar 30, 2009 | Intertherm P3RA-036K Air Conditioner
Heating & Cooling Logo
280 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
