Question about Home
This is a new toilet for me. The bowl has a water level that seems low - 2 inches below the D-shaped bowl opening. The tank water level is a little over half full. This toilet always clogs with solids. If I add a pitcher full of water before I flush, it works better. If it clogs, the D-shaped bowl opening is not friendly with the usual round toilet plunger so it takes me all day trying sporadically to unclog it. There is a Geberit mechanism inside the tank. I can't see how to adjust it. I received no manual. Could the problem be below the toilet. Is it time to call the plumber?
  • aforsman145 Jul 06, 2010
    Duravit Series 1930 2-piece floor standing toilet. one month old. The bowl has a water level that seems low - 2 inches below the D-shaped bowl opening. The tank water level is a little over half full. This toilet always clogs with solids. If I add a pitcher full of water before I flush, it works better. If it clogs, the D-shaped bowl opening is not friendly with the usual round toilet plunger so it takes me all day trying sporadically to unclog it. There is a Geberit mechanism inside the tank. I can?t see how to adjust it. I received no manual. Could the problem be below the toilet. Is it time to call the plumber? Previous fixya expert recommended checking for a leaky ubend. I don't know how to do that but wouldn't I see evidence of a leak somewhere? Do you know if this brand is known for problems?
    thank you. I will call him or another plumber.
  • 1,284 Answers
Hi, if the toilet is really new as you have said, that means you have a problem (with 2 inches below the D-shaped bowl opening. The tank water level is a little over half full which is unusual), please call in the plumber to check below the toilet.
Take care
Posted on Jul 06, 2010
  • 19,396 Answers
Hi.
Water level low and toilet clogging quite easily are often symptoms of a leak in the u bent. The water level is determined by the shape of the u-bent below the toilet. If there is a leak in there the effects will be low level, and less draining power.
Drain the toilet completely, find the leak and use epoxy filler paste to fix the leak.
  • 1 more comment
    Sorry but your answer is above my level of toilet knowledge. I don't know what a u-bent is. Where is the ubent? If it's leaking, wouldn't I see water somewhere? The toilet is above a basement. I know the plumber used an adjustable flange to get the toilet to work in the existing opening and he had to replace the pipe leading down into the basement.
    You didn't address the amount of water in the tank and toilet.
  • Ginko
    Ginko Jul 06, 2010
    U bent was a typo. I was referring to the U bend.
    This is the U bend. Click and read pls.
    Regarding the filler, the level of the water in the tank is adjusted regulating a wheel, usually there is a wheel mechanism. If water level stays low it can also be the geberit mechanism itself. Low water level in tank, and water level in toilet should not be related.
    Since I cannot see your toilet I will need details on model and manufacturer , or on toilet type. I have seen whirlpool listed in title.
    Sorry I neglected to mention the toilet : Duravit Series 1930 2-piece floor standing toilet. one month old.
I have a 2yr old Kohler K4634 toilet. After flushing the water level drops about 1 inch in the bowl after the bowl filled. This causes a lower level in the bowl than is recommended. The main issue
check to see if waster continues to run into the bowl after the plunger has returned to stop water flowing. If it is a slow leak then replace the flush washer on the stopper plunger.
Oct 01, 2014 | Kohler K-4634-RA-0 Cimarron Toilet Tank...
Water level in bowl low
Turn knob on top of float ball to increase ball height which will increase water column. Up to 1" of overflow tube.
Nov 08, 2012 | American Standard Cadet 3 Right Height...
Just installed the cadet 3 and here is what is happening. First let me say that the toilet it replaced was working good. The water filled very slow and the bowl would not fill much. I messed with the...
The amount of water in any toilet bowl is determined by its construction and no tank adjustment will ever change that. American Standard has a history of having small water surface areas in their low or ultra low flush toilets. Take a large container of water and pour directly into the bowl. If the ending level remains the same, then that is the manufactured level for your toilet.
Not all tanks completely discharge all of the water when flushed. Measure 1.5 gallons of water into a container. Turn off your water supply to the toilet then flush normally. Replace the water in the tank with your premeasured amount and observe this new water level. You might be surprised to find it is at the same level it always is. Since water weighs more than 8 pounds per gallon, one concept used in todays toilets is to have more than 1.5 gallons of water in the tank and use the extra weight push the water past the flapper at a faster rate while designing the flapper to drop after only 1.5 gallons have passed through.
Sep 29, 2010 | American Standard Cadet 3 Right Height...
My kohler toilet is only about 1 year old. no problems with the flush but the bowl only fills up with about half the amount of the normal water. I looked inside an all seems to be connected. Thanks
You might follow this link to see if you can adjust the water level:
http://www.acmehowto.com/howto/homemaintenance/plumbing/toilet/filllevel.php
Hope that helps.
Aug 21, 2010 | Kohler Home
The water level in the toilet bowl is too low. Can I adjust the level, and if so, how?
Too little water in the toilet bowl to start with may be due to a lost or mis-connected fill tube that directs some water into the toilet tank standpipe (and thus into the bowl below), while the toilet tank is being re-filled. Check for that little tube.
Check the web site out below for more information on this topic.
http://www.inspectapedia.com/plumbing/Toilet_Slow_Flush.htm
May 23, 2010 | Jacuzzi Maxima DP55959 White Toilet Bowl...
Toilet Bowl Water Level Slowly Drops
Check the fill tube in your toilet one easy way to see if it's leaking is get food coloring and pour in your tank to color the water this makes it easier to see and squeeze the tube in the tank when it's full if you see the colored water running down the middle of it you have a winner! if not you can look around for it sometimes the plastic under the flapper gets cracked too
Aug 01, 2009 | Kohler Home
Replaced toilet fill valve - now bowl water level a bit lower
First off,If the air vent was clogged the toilet would back up and overflow and when it did flush, it would make a gurgling sound.
secondly the water level in the bowl is not important as long as it covers the opening,The water is only there to keep out sewer gases so they don't enter your home and the shape of the trap will always maintain the proper amount of water needed to prevent this.
The previous water level may have been due to a partial clog that has since been removed.
Jul 26, 2009 | Home
Water level drops in bowl after it fills
If very little water is used on initial flush, The bowl is functioning as a tank for second thorough flush. The high water level cannot stay high in the bowl while in motion or you would have a mess ion start and stops.
May 28, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Low water level in toilet bowl
Sorry, but there is no way to raise the water level in the bowl of a low-flow toilet. The water level is determined by the height of the internal trap, usually visible from the side of the toilet (that squiggly little bend). If the toilet is not flushing satisfactorily, you can make adjustments to the water level in the tank and adjust the closing of the flapper. If the problem is odors, flush half way through your business or turn on the bathroom exhaust fan. If you found this answer helpful, please don't forget to rate it.
Apr 09, 2009 | Bemis Home
No back flush pressure
increase the tank water level half inch at a time till you have the back flush pressure.
seems like the water in the bowl is too low to create any wirlpool.
Oct 30, 2008 | Eljer Aqua-Saver 12" Two-Piece...
Home Logo
108 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
