Question about Video Cameras
Manual ejection of cassette
I screwed up by plugging my Nokia phone charger into my camcorder and now nothing works. I need to eject the cassette but have no power. Can this be done mannually?
  • 3 more comments
  • desm24 Apr 18, 2008
    Canon MV920
    Canon MV920
    I have accepted that the motor is burnt. I just need to retrieve the cassette which has some valuable recording on it.
    I accidentally connected my Nokia phone charger to my Canon MV920 camcorder. Advice so far is that I have burnt the motor. I have the correct charger and battery but no power. I have accepted the camcorder is kaput but need to retrieve the cassette. Because there is no power it will not eject. How do I do this manually. I do not mind further damaging the camcorder as I have another one.
  • desm24 Apr 20, 2008
    Yes
    Guru:
  • 1,342 Answers
Did you try a different battery?
Posted on Apr 18, 2008
  • 4,234 Answers
DO NOT attempt to force this as you will cause all kinds of damage that will make the unit not worth repair. The unit can be released but it is not a simple task. Yes the unit needs to be partially dis-assembled. Any shop that deals with Sony cameras should be able to asist with this. I can try to walk you through this if you like. Post a way for me to contact you off-line and I'll try to assist. Again, DO NOT force it. You will need a small philips head screwdriver (jeweler's set will do).
Dan
  • ABRsvcs Apr 18, 2008
    I forgot to add. It is unlikly that the motor is damaged. There are both protection fuses as well as diodes in place to prevent internal damage to the circuits. You have blown the fuses or opened up the diodes. Both cases are easily repaired by an experienced servicer.
    Dan
  • 563 Answers
Hi desm24
Try using a nailfile , there is a very small clip that keeps the tape's door closed - push in the file and fiddle with it a bit - I have opened one like this once.
  • Marnus Jacobs
    Marnus Jacobs Apr 21, 2008
    Benimur
    Do you honestly want to tell me you have never used a nailfile in your life ?
    Brigadier General:
  • 6,966 Answers
Possibly, perhaps if you can post back the make and model of the camcorder, we can be more specific as to how to go about it.
Good luck and kind regards.
Thank you for using FixYa.
  • 1 more comment
  • Louie  Role
    Louie Role Apr 18, 2008
    Hi again desm24 and with the indulgence of ginko,
    If the objective is to simply remove the cassette irregardless of the consequence to the camera, then disassembly would be a matter of removing all screws anywhere and everywhere. The idea is to remove the side panels to expose the inside. Once the side panel is removed, the cassette can be ejected by manually turning either the loading motor or the gearing assembly that moves the cassette carriage.
  • Louie  Role
    You would need small screwdrivers similar to the ones used by jewelers as shown here. Since there is no need to be gentle on the casing you can even pry open the side where the cassette is loaded since the tape would be encase in a carriage
  • Louie  Role
    ...leave it to a feminine touch to suggest a nail file to unhook the latch. My compliments Marrie
  • Video Cameras Master
  • 19,396 Answers
Which is your camcorder model?
  • 6 more comments
  • Ginko
    Ginko Apr 18, 2008
    Try connecting the camcorder to the original power adapter, ot to an universal power adapter with same Amps and Volts, you can buy one in any electronics shop. If the camcorder does not start at all then ythe motor is burnt. At this point you may need to partially disassemble the camera to get tape out.
    If you do not want to risk to damage the camera furtherly, it may be better to take it to a repair shop, and have the motor replaced and tape estracted.
  • Ginko
    Ginko Apr 18, 2008
    On some camera (eg PAnasonic, which button is on the side) , the open/release tape button is completely mechanic , and works without power. We need make and model to be more precise.
  • Ginko
    Ginko Apr 18, 2008
    If it is A Canon camcorder try the open unlock button on the side, this should unlock the Mini DV door, to open it completely you can force it a bit with you fingernail.
    If it does not open, then probably there is tape rolled inside the video camera. In this case Camcorder should be disassembled taking it apart (at least the mini DV slot) and tape removed.
  • Ginko
    Ginko Apr 18, 2008
    Another thing you could do is going to your local retailer and ask to connect to a compatible power adapter. If the camcorder works, change just the power adapter and eject the tape, otherwise have it repaired from a service center, as suggested by Canon .
    For you reference here is the manual.
  • Ginko
    Ginko Apr 18, 2008
    You do not know for sure if motor is burnt, if the camera stopped when running the tape will be rolled inside. In this case you may need an expert opening the camera to ensure preservation of data inside the camera.
  • Ginko
    Ginko Apr 18, 2008
    I cannot understand why you refused our solutions while troubleshooting.
    This is not the way Fixya should be used.
    Good luck and goodbye.
  • Ginko
    Ginko Apr 18, 2008
    Sure you can take a chance using a screw driver, but you risk to break the tape, if you want to take the chance.
  • Ginko
    Ginko Apr 18, 2008
    Use a precision screwdriver on the bottom side, as suggested by Benimur instead, you have all possible rational solutions, unless you want to open a camcorder with a chainsaw.
    Use a screwdriver on the door only if you are sure the tape is free
    Use a precision screwdriver on bottom and back of camera. You will need to unscrew about 10 or 12 small screws.
Handy cam hi8 dcr
Try removing the battery and charging it. Then put the battery back on the camera. This will reset the cassette system. The cassette should open or close depending upon what status it is in. Once you get the camera to eject fully, clean your heads with a dry head cleaner cassette for Hi8 video. If your camera is still eating tape, could be a broken pin or damaged heads.
Aug 26, 2013 | Sony Handycam DCR-TRV280 Digital Camcorder
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and...
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and I've also tried it with power supply connected?
Oct 04, 2011 | Sharp VL-Z5 Mini DV Digital Camcorder
Handy cam video 8 XR keeps ejecting cassette any ideas please
thats is because the servo mechanism chip do not detect the cassette,
when its in the housing could be a sensor or the cassette in switch or mechanism its self (missalignement.)
hope that will help you
regards alan.
Oct 18, 2010 | Sony Handycam CCD-TRV37 Camcorder
Canon ZR-800 Mini DV Camcorder tape stuck
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
Feb 23, 2009 | JVC GR-DV800U Camcorder
Canon ZR900 cassette won't eject
you could hit like the method for if a canon won't let you put in a cassette but i don't know if that will work. just hit it on the non screen side a few times and in theory it should work.
if nothing it will get rid of stress
Dec 12, 2008 | Canon ZR900 Mini DV Camcorder
Canon md101 manula eject
yup there is sort of... you take a jewelers flathead screwdriver and push the spring back on the lens side of the cassette holder. and then on the other side there is a little hook that latches over a bump that locks it in place, you push that down and it will unlock... from there you might have to take the extremely small screw out at the top and remove the whole cassette tray...
Jun 09, 2008 | Canon ZR100 Mini DV Digital Camcorder
Jammed tape in Sony camcorder
There is no manual eject.
The only way is to disassemble the camera outer shell, then remove the drive mechanism and using a 4.5 V power supply power the eject mechanism.
It takes 30 min of work when you know how to do it. If you find the service manual (free somewhere in internet) it will tell you how to open the camera.
Hope this helps.
DocG4
Mar 30, 2008 | Video Cameras
Inserted cassete in wrong way in Sony camcorder CCDTRV68, not ejecting cassette Error codeC32:20
Sony camcorders C:31:23 error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Dec 24, 2007 | Sony Handycam CCD-TRV68 Camcorder
My Camcoder says eject the cassette
Use a Sony head cleaning tape they work perfectly and you let them run there 10 second corse. Then your sharp will run perfectly...
Dec 20, 2007 | Sharp Viewcam VL-Z7U Mini DV Digital...
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Video Cameras Logo
69 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
