Question about Intel DG31PR Motherboard
No beeps, No video but fans and lights come on...
I rescently bought an intel pearl creek clssic series DG31PR motherboard and after assembling it...nothing. The lights and fans went on but the BIOS didnt show because there was no video on top of that the regulatory BEEP was'nt produced by the motherboard speaker.
Oh and the LEDs come on when the power is turned on including the one's on the board and on the case as well. i've tried disconnecting and connecting numerous times....HELP!!!
  • 8 more comments
  • Anonymous May 01, 2008
    I too have the same issue! Have you had any luck?
    I have the same problem. Securing parts installation/connection did not help. If one of these parts is defective, is there a way to find which one is?
  • Katopc May 09, 2008
    Yeah I am having thew same problem
  • tlacua Jun 02, 2008
    I have the exact same problem...
  • aardvark2000 Jun 03, 2008
    I have the same problem. If I removed the memory DIMMs the board beeps 3 times (no memory POST error).
    It seems an incompatibility issue with q9300 ???
    I opened a case in Intel. Let's see what's the outcome.
  • Anonymous Jul 13, 2008
    i have the same problem, and i don't have a non-45nm processor to install (for bios upgrade).  i sent mine back hoping they will send me one with an updated bios...o well. how can they sell a board claiming full compatibility with 45nm, meanwhile it won't run any of them out of the box??!! thats just shady.
  • anandmisal Sep 24, 2008
    With this no display issue, i have another problem as my motherboard has no jumber available for BIOS. ( no pins soldered for jumber settings ). Is this a production issue ?
  • chpavankumar Nov 15, 2008
    HI,
    I have the same problem and have done all the things what u mention but i didnt get any result from my pc. can u please need full to me.
    thanks
    pavan
  • R0nJ0n Jan 18, 2009
    I'm having the same problem. Now I've tried removing both DIMM's and still no beeps. All lights, fans, an green LED on mobo are on. But absolutely nothing coming through the video. No idea what it could be.... possibly the power supply?? I'm at a complete lost as to why this is happening.... Mobo is BRAND new, just bought it today.
  • maliekafzal Jan 18, 2009
    i HAVE A INTEL D915PBL MOTHER BOARD
    A VISION TEK X300SEH 256 VIDEO CARD(OLD)
    AND A NEW NVDIA GFORCE 8400GS VIDEO CARD BOTH PCI X16 AWD1600 SATA HARD DRIVE.
    INTEL PENTIUM 4 3.0ghz/2m/800/04a
    1 KINGSTON 512R DDR2 - KVR5332d/512R
    I have the same problem the fans the led lights and the video card fans comes io but i have no video and i here no beep at all the hard drive starts up but nothing happens the light on the dvd/cd drive comes on to.
    i tried taking everything out and just leaving the ram/video card and thestill nothing i switched ram slots nothing remove battary cleared cmos and bios nothing help help i need help.
Its the DG31PR bios!
Put a non 45nm CPU on it, update the bios to the latest one , put back your 45nm processor and all should work just fine....this board is awesome.
Cheers!
Posted on Jul 05, 2008
  • antoniomax Jul 05, 2008
    Its the DG31PR bios! Remove your 45nm processor, plug another compatible CPU (non 45nm, like a core2duo) update the bios to the latest and put back your 45nm CPU...all should run just fine
  • 22 Answers
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
125
Posted on Mar 13, 2009
    New Friend:
I wished if someone had posted the answer, for I am having this problem.
When I switch on my dg31pr board (with c2d processor, 1 dimm on channel A, no other peripherals) I do not get any display. the processor fan starts led on the front panel indicate power - no beeps errors reported by BIOS. the display unit always stays in power saving mode (the display unit is fine).
How can I make the board send video output.
Posted on Feb 02, 2013
Try building the system out of the case, worked 4 me a few times (i used to be a techie)
Posted on Sep 15, 2008
Have same problem, dont have a non 45nm cpu to put in to flas bios, What do i do???
Posted on Jul 09, 2008
HA HA HA!!!! Finally my PC works i tried all your solutions hey map9966 and even went as far as disasembling the damn thing and taking it back to the shop. There i was told that it's absolutely fine and that these types of boards don't beep unless there is something wrong(imagine!!!!). So there i was looking like an idiot.....
Well i went back to my place assembled the damn thing, switched on the power and POP!!!! goes the PSU!! My blood went cold at the thought of me loosing all that money because i thought i'd fried everything. But luckly i had an old PC already assembled so i just switched parts with the new PC parts and connected my new parts(motherboard included) into the old case, crossed my fingers, switched on power and after a few seconds of nothing it came to life video and all, i went into bios and everything checked out.
So either i was connecting something wrong and the problem was with me or they switched the motherboard at the shop, so to save my ego i blame the shop lol.....thanx a mil tho'
Posted on Jun 10, 2008
I had a customer return a machine to me a week ago. Specs inc. this motherboard, a Dual-core p4 cpu, 2x512mb ddr2, a pcie video card. Problem - No Video on boot.
Removed video card, powered system up with VGA onboard connected to monitor... Simply sits there displaying the onboard display adapter info. Suspecting Mobo, remove the RAM from the board, but get error beeps (good). Replaced RAM, Reseated pcie card, can hear HDD booting, but no display. Removed the PCIe card again, plugged in on board VGA and system hangs when powered on, simply displaying the onboard adapter info. Tried jumpering the bios many times with no effect.
Given the error beeps when removing ram, I ordered a replacement PSU as motherboard has already been replaced in past. Replaced PSU and no different. System still hangs on the onboard display adapter info on power on. Sighed to myself, and reluctantly ordered a 3rd replacement motherboard, presuming there must be something faulty. Receive the new mobo and replace the old one. New PSU, New Mobo, same result. :(
Annoyed, I hope, that the CPU is fried. Order a new Processor. Replace the processor, same result. :(
Really annoyed, order more RAM, (We're now talking a COMPLETE new system in parts alone), and, same result.
I now have an existing customers hardware, completely useless. An entire 2nd set of hardware, brand new, just as completely useless as the customers hardware. Not to mention, $390 later.
Are these mobo's programmed to FRY THEMSELVES before June 2008?
I fail to understand what the problem is, or which part of these systems is even faulty!
At ONE, FLUKEY stage, I had the pcie card plugged into the customers original hardware, I could hear the HDD booting, so quickly pulled the monitor from the card, and plugged it into the on-board vga, and what do you know! DISPLAY! AND, ITS BOOTING! Amazed, do a rapid shutdown+restart.... only, back to the same ****.
PLEASE, someone, before I smash my skull through my workshop wall, tell me what the HELL is going on.
((And no, theres no HOPE of entering the bios at ANY stage.))
Posted on Jun 09, 2008
    President:
  • 2,351 Answers
Hi PWNED, here is the link to you're Intel DG31PR board.
http://www.intel.com/products/motherboard/DG31PR/index.htm
One of the most common reasons for a high end board not booting (yet fans run & leds light up) is the 12v 4pin ATX CPU power connector & main 24 pin power connector. Shown on pg. 51 of you're manual. These connectors must be secure, or system will not boot.
Check memory by removing one dimm if you are using two dimm's. With one dimm use only dimm slot channel A. (Nearest to CPU). Try booting. If no boot, swap dimm's & try boot again.
If you are using a PCI-E card instead of the Intel Graphics Media Accelerator 3100 onboard graphics subsystem, remove the PCI-E card. Unplug the power cord from the PC first.
Reset you're cmos/bios jumper to clear for 15 seconds, than move back jumper to default pins pg. 52. Try to enter you're bios? If you are not using a PCI-E card (which is preferred in order to receive display), still reset the bios. The Mfg. suggests to always clear the cmos/bios before assembly of board.
Go over these suggestions PWNED & get back to me if none of these have not helped.
As a first time user at FixYa the easiest way to repost information back into this post.
How to repost more questions for the same problem.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Ask more questions & answer questions from tech.
Luck!
Mike
Posted on Apr 18, 2008
The green LED light on the board is lighted. When I push on/off button the CPU fan moves for 1/2 a second .I tried a different power supply, but that did not work. I replaced the CPU fan, but that did not...
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+3+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG31PR
Any abnormal beeps at startup ???
http://www.computerhope.com/beep.htm
The problem could be a ram module failing, or the graphic card if installed on the mainboard.
Or a short circuit somewhere.
Look also here:
http://www.tomshardware.co.uk/forum/243625-13-turns-wont-boot
Try starting with only 1 stick of Ram, the monitor and the keyboard connected, no other USBs to be connected.
Look also for bad caps on the mainboard:
If they look like this, the mainboard is dead.
It does not pay, to let them be changed.
Good luck
Jan 28, 2013 | Intel DG31PR Motherboard
I have no video driver softwear
here u can choos ur os and download the driver...
Nov 25, 2012 | Intel DG31PR Motherboard
Intel dg31pr motherboard create some problems so that display is not available
The first step is to try video with a different video card.
If this does not work remove the ram and try to power on the motherboard. If the machine gives a series of long beeps when the ram is not installed, it is a good thing. This determines if the motherboard is posting.
If the beep code occurs, try using different ram, preferably that is known to be good.
If the beep code does not occur then the motherboard itself is bad, and short of using a multimeter to determine what component on the mobo is actually bad, a replacement would be in order.
//halfs
May 25, 2010 | Intel DG31PR Motherboard
SIR I M BAYING YOUR COMPANY MOMHER BOARD DG31 DT-11.01.10 I NO FOUND VGA DRIVER SO PLS HELP ME
go here my friend
and download this
Video: Intel® Graphics Media Accelerator Driver for 3 Series Chipset Based Intel Desktop Boards
Jan 11, 2010 | Intel DG31PR Motherboard
I have Intel DG31PR series motherboard with 2GB
The number of the beeps is a specific post
error code and should help diagnose. e.g.:
my computer has 3 beeps to indicate RAM
failure. Note the beeps and find in your manual
or from Intel support.
Here's some help to get started:
Beep Codes
Intel Support
Jul 12, 2009 | Intel DG31PR Motherboard
Intel dg31pr motherboad not booting.
Unhook everything except power and your monitor. Put one stick of memory in and attempt to boot. Post here with results, what power supply you're using, what memory, and what processor.
Jun 07, 2009 | Intel DG31PR Motherboard
Do you have a graphics card installed in the AGP or PCIE slot on *********** board?
If so take that out and test to see if the computer beeps. If it does it could be your graphics card.
Feb 25, 2009 | Soyo KT400 Chipset MotherboardAMD Socket A...
No boot, Intel Classic DG31PR, had been working ok
Do you get any beeps sounds when u start your computer? Try removing the memory card and insert it again or try another memory card slot.
Oct 12, 2008 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Logo
2,766 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
