Question about DOD SR231QXLR Home Equalizer
Very bad hum one is 60hz second is a loud buss would like the sch
DOD 231 60hz hum and loud buzz I would like the sch then I can scope the signal path this unit is used in a broadcast studio
  • 3 Answers
Hi.
I have a similar one of these, and am having some issues with it. I have previously repaired the power supply section which is on the back of the unit screwed to to the left of the I/O section (when looking from the front). The capacitors weren't too crash hot so I replaced them, though I am having an ongoing problem so was hoping you might be able to help me if you've learnt anything about the unit.
I'm getting a very low signal, ie: I can just hear the sound when the amp is maxed up. I noticed when I ran the system with the ground of the amp lead I got a good signal???
Anyway, cheers.
Robert.
dronno@live.com
Posted on Apr 02, 2011
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
I have kenwood amp m-a100 which has loud buzz / hum on all channels and distorts radio very badly can you help ?
The loud hum will be probably caused by the Large Electrolytic Capacitors in the Power Supply section. All of them will need to be replaced to be on the safe side. The buzz noise is caused by the fact they are letting in the 50/60hz mains. Hopefully that should clear everything up.
Sep 09, 2014 | Audio Players & Recorders
I get a loud buzz while playing games on my cyberpower sagitta how can I fix it?
Tinnitus is what this is. Could also be bad speaker system. The 60Hz hum from the power supply in your speakers is bleeding into your sound signal.
May 12, 2012 | CyberPower Computers & Internet
I get a loud intermitant buzz from one of my JBL eon 15-G2 speaker, no music signal just buzz. What is the problem do you think...? EQ circuit problem, speaker cones seem to be intact.
If you turn the unit on with no input and get a loud buzz, and when you put signal to it and you cannot hear the music but the buzz (Probably more like a hum). Then most likely the amp is blown.
Dec 13, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Sound cuts out
Hi Darren.
I suspect you may be right about the eq here, though you probably have had it sorted by now.
I came across this thread because I was searching for a fix to my R-231 and was hoping you might be able to help me if you found a fix. I'm persisting with this one as I can't really get another just now and it seems that it's not a major issue. I managed to get a good signal out of it when I ran it without the ground connected on output???
Anyway, any info I would greatly appreciate,
Thanks, Rob dronno@live.com.
May 20, 2010 | Digi-Tech DOD-Digitech 231 - 31 Band Per...
Input 60Hz hum
i had the same problem once and in my case i had accidentally used ground wire for signal. pls check ur connections again. one check u can do is set the high pass filter to 70Hz and see if that cuts out the low hum.
May 01, 2010 | Crown CTS600 2-Channel Amplifier
I recently bought the below record player; http://www.robertopiecollection.com/Application/Products/steepletone/record-players-GB.asp thinking buying a brand new player would mean having no problems with...
Sounds like a bad ground loop or open shield to the signal path, or feedback from its own speaker or motor. The output of the stylus is so tiny that any electromagnetic noise can easily loom large if it leaks into the signal path.
Be advised that turntables and speakers should never coexist on the same platform or speaker vibration will feed back into the stylus, get amplified again and eventually overdrive the electronics and maybe blow the speaker, which begs the question - how did they get away with it back then? One answer is that there was never any real bass from one of these things.
Try it with minimum volume and work your way up. With the tonearm lifted and the platter turning, listen for audible hum coming from the mechanism itself. If you can hear it, so will the stylus when it's on the platter.
Jan 19, 2010 | Audio Players & Recorders
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Makes a loud buzzing noise and does not get hot
Have seen this many times.
Sounds like a bad CAP since a bad diode would blow the fuse and a bad mag would likely do the same thing.
Since yours is making the loud 60hz buzz you need to replace the capacator that will likely fix the problem. A $10 fix
Jan 06, 2009 | Kenmore 62622 Microwave Oven
DOD SR231QXLR Home Equalizer Logo
140 people viewed this question
Top DOD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a DOD Audio Player and Recorder Expert? Answer questions, earn points and help others
