Question about Gateway Emachine Bestec ATX-250-12E PS 250w Replacement Power Supply Part Number P/N 100744 (PSATX25012E) Power Supply
Regarding 250W SMPS
I have an Acer 250 w 24 pin Atx Smps is it capable of carrying the load of Gigabyte motherboard, 80 gb hard disk, Dvd writer, 1 gb DDr 2 800 mhz Ram?
    Problem Solver:
  • 13 Answers
250 watt is low under any circumstances, I'd upgrade atleast to a 450 or higher, around 650watt to be extra safe.
Posted on Jul 11, 2010
Hi , my name is Nitin and the problem i am facing with my PC is that it gets restarted after every 10 to 15 minutes while playing games and it starts disk checking everytime it restarts. This happens even...
The following tip is not for the same model, but for the same kind of symptoms :
http://www.techsupportforum.com/hardware-support/motherboards-bios-cpu/183116-asus-p5p800-p4-3-0ghz-random-reboots.html
Dec 18, 2010 | ASUS P5QC Motherboard - Intel P45, Socket...
How to use ATX-250-12z SMPS with 24 pin
Chances are that 250w power supply is not going to power a motherboard with a 24 pin connector, but you can try.
You will need to purchase a 20 to 24 pin adapter cable.
Google Search Terms: 20 to 24 pin adapter
Oct 27, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Do not start
First remove smps power suply unit box from cpu.
Then ground pin and check is it on you have to ground 4-5 pin blck and green.
Then if it is on then smps is ok.then pull cmos cell from motherbord for 10 minutes make sure cmos cell give voltage.Remove pci cards from pci slot is any.
connect ATX power supply to motherbord then check.
But if smps is not turn on then it has some issue.
Change fuse of smps if still not on then you have repair it or change.
Let me know if you need further assistance.
Thanks.
Oct 26, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Power on is ok but when switch off not ok
They are lightly loaded and WILL take time to bleed off the charge on the caps.
Also switching power supplies MUST have a load on them or they MAY overvoltage.
Sep 07, 2009 | ASUS PSU | A-45GA 450W RT (A45GA) Power...
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
Smps problem circle 600 watts
id say stick with the highest power supply you have, try replaceing the CMOS battery. also if your video card requires a PCIe power cable and there isnt one you may want to try that. this may be as simple as a bad 24x ATX power jack or the 4 pin on your mobo....which of coarse means Get a new mobo or have it fix with the warranty.
Aug 18, 2009 | Color Graphics ATI FireMV 2250, PCI...
I have acer extensa 5630ez. turned it off on wednesday and it wont trun back on.
Is it getting any power to the pc? Are any lighs coming on or anything? If not, your power supply will need to be replaced
Aug 07, 2009 | E-Machines eMachines Desktop PC
HP DESKTOP COMPUTER
If computer is not powering on then open u r cpu and check the SMPS i.e Switch mode power supply which converts AC to DC it gives a output of 5v & 12v in that the 20 pin or 24 pin connector which is connected to the mother board remove that and short the wires Green and Black and make sure to remove all the power connectors i.e,hard disk,Cdrom or cd writer or DVD writer or any other device and one more connecto which is a four pin connector which is connected to the mother board please remove and test the 20 or 24 pin connector by shorting green and black and behind the smps u have a power cord of ac 220v just plug it and switch on if smps fan rotates that means it's fine then the problem willbe on the mother board just try this
Jul 30, 2008 | Computers & Internet
Gateway Emachine Bestec ATX-250-12E PS 250w Replacement Power Supply Part Number P/N 100744 (PSATX25012E) Power Supply Logo
226 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
