Question about Bosch 22 in. SKT5108 Free-standing Dishwasher
European Bosch SKT 5002/02. Was disconnected by our plumber to install new cabinets. Not used during winter, as it is never used in winters. Fills with water, makes no noises but does nothing else. Have been told on-line to try to turn the motor (blades, I suppose) but it looks like the whole unit is behind galvanized panels and I don't want to do what I shouldn't......
  • Bosch Master
  • 19,396 Answers
Hi.
Re:"Have been told on-line to try to turn the motor (blades, I suppose)"
Someone has probably told you to energize the impeller pump motor directly by jumping its contacts to find out if the motor is working. That is a delicate test that for safety reasons must be done by a a technician. Moreover before energizing the pump more parts must be tested.
Ensure that the machine is filling properly. Double check inlet(s). It is important to check hot and cold if machine has dual inlet. If the hot inlet is not filling, then the machine will only fill cold first, and will not progress as temperature is not reached. Ensure that both hoses are connected, that they have pressure, that they are not bent or clogged. Eventually do a test swapping the two inlets. If the machine does not fill at all, then the hot inlet was the problem, you may need to replace the valve.
The inlet valve is tested in full by reading Ohms and Volts at valve solenoid contacts.
Check the water level float switch. If it stuck on high, or if the switch stays open (read Ohms after disconnecting power), then the switch must be replaced.
Check again water temperature. If the water is warm , machine fills at right level, but motor does not start, then other possible cause may be the thermostat. Thermostat is tested reading Ohms at temp, after removing thermostat from circuit. If the thermostat is Ok it will read zero or low impedance at room, if it is bad, it will return infinity (open).
If water is cold, then check either dual inlet valve (hot), or if machine is single inlet and self heating, test the heating element. If the heating element has no continuity (circuit open), then the element must be replaced.
Posted on Jul 06, 2010
Is there a lubricant I can use to unstick frozen pressure washer pump?
If pressure washer got frozen over the winter, the pump is bad. replace! Use winter pump protector during winter storage!
Mar 29, 2016 | Honda 2500 PSI Gas Pressure Washer
Tip
Winter Makeup Tips
For winters, regular skin care and cosmetics products are necessary for heavy makeover. In the winter season, everybody wants to polish properly and look very glamorous.<br />One can use smoky shades for eye makeup, matte understated shades like chocolate, coffee and to Protect Your Lips use berry tones during wear winter makeup.
on Nov 22, 2010 | Health & Beauty
How do i winterize a primo water dispenser #601118
get a gallon of RV antifreeze (it is not toxic)
put it in cabinet where the water bottle goes, connect the intake hose to the antifreeze bottle.. Then use the dispenser as normal till the antifreeze comes out both dispensors. When you go use it next time take the antifreeze bottle out, put in a regular water bottle and run the water till the antifreeze is gone.
Jan 16, 2016 | Cars & Trucks
Closing inground pool
Question:
How do I close my pool for the season?
by Osko Pool n Spa Information
By following the provided instructions, you will be able to professionally close your pool for the winter season. Additionally, you will protect it from winters abuse and make opening it next season...simple.
Required Tools
a) Standard Screw Driver
b) Phillips Screw Driver
c) Ratchet Set
e) Plumber Pliers
f) Sump Pump
g) Extension Cord
h) Garden Hose
i) Five Gallon Bucket
j) Air Pump or Shop Vac
k) Pool Vac & Accessories
Required Chemicals
a) Pool Shock
b) Algecide
c) Chlorinating Tablets
Required Accessories
a) Winter Cover
b) Pool Pillows or Inner-tubes
c) Chlorine Float Dispenser
d) Water Bags (for ingrounds only)
Step One - Debris & Chemicals
Remove any debris from pool water by use of a leaf rake attachment.
Add the appropriate amount of shock treatment to the pool water, as prescribed on the packaging.
Add the appropriate amount of algecide to the pool water, as prescribed on the packaging.
Run your filter for the appropriate time to circulate all water once.
(see your filter documentation for your size pool)
Install your floating Dispenser and winterizing tablets.
Step Two - Vacuum & Water Level
Vacuum your pool while setting your filter to the "back wash" or "waste" setting.
(this will help lower your water level)
After vacuuming, install the sump pump and drain pool to about 6 inches below your thru-the-wall skimmer.
Step Three - Parts Dissassembly & Cleaning
Disconnect all ladders, filter systems, hoses, solar reels and/or other accessories.
Using standard household cleansers, thoroughly clean all ladders, solar reels and/or other accessories.
Dissassemble filtration system.
Remove sand, cartridge or DE powder from your filtration tank.
Thoroughly clean all filter system parts.
Allow all items to dry.
Store all items in an area that will not be subject to freezing temperatures.
Step Four - Pillow & Cover Installation
Inflate all pool pillows or inner-tubes.
Install one pillow for every 15' of linear water surface.
(example: a 15' x 30' would require at least two pillows)
Tie pillows to pool area via nylon rope and place equally with respects to pool walls and each other.
(this is extremely important! This prevents freeze damage)
Install winter cover as prescribed by the covers manufacturer.
Step Five - Winter Tips
During the winter months, remove any excess snow from the winter cover.
(If you have a solid cover, this will prevent excessive weight form tearing you cover)
(If you have a mesh cover, this will prevent excessive water build up)
Hey, Your Finished! Congratulations, you just saved money while doing a professional job
Nov 11, 2013 | Hayward SAND FILTER, PRO SERIES
The automatic transmission of my mitsubishi mini pajero turbo 660 cc model 1995 works perfectly during the hot summers days, but as the winter approaches it stick to 3rd gear until the car warms up and...
sorry jhbkane. ur solution doesnt work..i hav change my this ECU several times but still it dont work in winters...
And alibaba69: i hear this taka taka sound n my pajero mini sometimes when the gear shifts..i have placed a new fuel pump but still its there...Wots this..?? any suggestion plx
Feb 12, 2013 | Cars & Trucks
How to replace window blades?
It depends on which style of wiper arm you have. Most auto parts stores will install new wiper blades free - just ask them when you go in to buy.Don't buy the cheapest blades - you get what you pay for! I personally buy Bosch blades - being winter, I get the winter blades. Wiper blades are meant to last only 3 months and the life will be greatly shortened if you have tree sap or chemicals on the glass. Scrape the glass with a razor blade then clean with an alcohol based window cleaner and make sure you wipe the new blades with the alcohol wipe they come with, as most all blades have a chemical coating to delay rubber decay during shipping and pre - sale storage and this coating can cause streaking on your window. You may want to clean your existing blades with alcohol if they wipe good but streak or cause hazing on the windshield. Hope this helps and please rate my solution!!
Nov 22, 2010 | 2003 Buick Century
I am a builder. I installed my Bosch dishwasher.
Hello Gerry, There are two (2) ways to accomplish this. The easiest is to get some RV anti-freeze (enviromentally safe version) and put that into the bottom of the dishwasher as per the instructions. Then when you return in the Spring, just run an empty rinse cycle to purge the dishwasher of the anti-freeze solution.
The other method will require you to remove (pull out from under the cabinet) the dishwasher and (with power turned off!) disconnect the sump pump boot to drain the residual water out of the unit. In some models, there is a small drain plug that you can remove to drain the water out of the bottom sump (pump) section of the dishwasher.
Good that you thought of this, as many folks forget that leaving water in their appliances in freezing conditions can cause some major headaches from burst pipes, pumps, etc. if they aren't properly winterized for the freezing temperatures they'll get in an unheated building.
Hope you find this Very Helpful and best regards!
Nov 17, 2009 | Bosch Dishwashers
Power cuts & tankless water heaters
A tankless water heater, by definition, has no storage capacity. It doesn't heat the water until you turn on the tap. When the power is off, you will have no hot water.
Feb 02, 2009 | Audiovox Bosch 718 World Cellular Phone
B&D battery lawn mower - winter care
Hi, it depends on the age of the battery. if it's new no ploblem depending on the age you may have to give it a trickle charge in jan.
If this doesn’t work for you please write back. Thanks,
Nov 19, 2008 | Black & Decker 19" Electric Lawnhog...
Proceedure to winterize washer
HI thanks for your question. the easiest way is to. pour plumbers anti freeze in it 1 gallon should do it . thanks the appliance doc. oh, start it up in the wash cycle for a few minutes, to cycle the water.
Oct 01, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch 22 in. SKT5108 Free-standing Dishwasher Logo
327 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
