Question about Samsung SGH-a737 Cellular Phone
My battery gets low really fast - Samsung SGH-a737 Cellular Phone
  • 43 Answers
Ur phone model ?
Posted on Jul 09, 2010
My Vivicam is always showing low battery, even I replaced the batteries as per specification.
i am not sure if you are using recharchable batteries but if you are that is the problem those go out really fast in these types of cameras try using fresh batteries.
Dec 22, 2012 | Vivitar ViviCam 7024 Digital Camera
Tip
Iphone home key
If your battery or memory is low on your iphone click on the home key really fast twice and you will see all the apps which are running in the backround.<br /> <br /> Press any applicaton till an, ( x ) shows up and delete.
on Jun 27, 2011 | Cell Phones
When I try to start my f 150 all I get is a fast clicking noise and it will not start.
this sounds like a really low battery. What happens is there is enough power to fire off the solenoid, but then not enough to run starter motor....voltage drops, solenoid disengauges....voltage then available again (low voltage), then process repeats. Fully charge battery then find out why it got low.
It is also possible that and corrosion at ANY connection will cause this. Clean battery terminals very well.
Aug 01, 2010 | 1991 Ford F150
I have an spl 1440 watt amp model st2-1440 that i cant get to turn on without 15 volts to the remote wire and then it gets really hot really fast. Any ideas why or how to fix it?
Generally a battery puts out 14.1 volts to the amplifier. The only way your amp would get really hot really fast is if the amp was configured to run at to low of an ohm load.
That amps spec is to run at 2 ohm stereo. But I do see an option to get 1400 watts with 2 ohm mono, but that would require 2 dual 2 ohm subs using only one voice coil bridged to the amp. If you run both subs with both voice coils in parallel you'll get a 1 ohm load and that will overheat your amp.
Reference: http://www.sweetwater.com/forums/archive/index.php/t-2193.html
Ohms are the units that impedance is measured with. You can kind of think of impedance as the measure of how hard the amp has to push to get current to flow. The lower the impedance, the more power will be output from your amp. Unfortunately, the amplifier circuit wants to push against something, so that if the impedance is too low, the amp can perform badly, and even overheat and burn out.
Hope this helps!
Aug 01, 2010 | Car Audio & Video
Ford f150 starting problem
A low battery or loose cable connection could be your problem. If the starter is not getting enough amps to crank the solenoid will click in and out.
Jul 13, 2009 | 1985 Ford F150
Battery dies really fast
change power setting or get a new battery
May 29, 2009 | LG Vu CU920 Cellular Phone
Battery low
battery can low after attending 4 to 6 calls per day after full charging
Jan 02, 2009 | Nokia 6681 Cellular Phone
Cant fast-forward through a song
that will happen to my if my battery is low, did you try changing the batteries?
Jul 12, 2007 | SanDisk Sansa m240 MP3 Player
Samsung SGH-a737 Cellular Phone Logo
32 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
