Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Cannot hook up xbox to versalink 7500 router. Have read everything I can find. Also Nat settings are moderate and can't get live xbox. I am very frustrated at this point. Any help would be much appreciated. Thank you.
2 Suggested Answers
Tom Marvolo
  • 708 Answers
SOURCE: I have a Westell Versalink 327W with a strict NAT ...
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Posted on Sep 30, 2010
My xbox is telling me that my router's NAT setup is on moderate. what does that mean? and how can i fix it?
Here is Microsoft's definition of a moderate NAT and their suggested fixes.
http://support.xbox.com/en-US/xbox-live/connecting/nat-type-strict
Dec 24, 2011 | Microsoft Xbox 360 Console
Hello. I need to change my NAT type on my Xbox 360 from moderate to open using a Westell Versalink 7500 router.
Hello
Your router does not have moderate or open nat options.
Options that it does have are Public Lan - nat type and Private Lan -nat type.
Your router also has a DMZ feature and port forwarding options.
User manual for your router is available at http://www22.verizon.com/ResidentialHelp/HighSpeed/Networking/User+Guides/User+Guides.htm
To get your xbox live working properly, you can try using the public nat type, if that does not solve the problem, turn on DMZ for the address of the Xbox360. Now if that still does not solve the problem, then you would need to set up port forwarding for all the ports that xbox live uses.
I would personally recommend that you enable port forwarding for the required ports.
Ports that need to be open are
TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Together with the user manual and xbox360 portforwarding guides that are available here http://portforward.com/english/applications/port_forwarding/Xbox_Live_360/Xbox_Live_360index.htm
You will be able to get it working.
But since that is a lot of information for anyone that has not used port forwarding before I'll write down step by step how to get started.
First get on your computer, You need to connect to the routers own configuration page. By default this is http://192.168.1.1
So, open your internet browser and write HTTP://192.168.1.1 and press enter.
Now you get a a user and password prompt. the username is admin and the password is password. all lower case.
Now on the top menu, click on Firewall settings.
Now select Port forwarding. more information and pictures on the user manual page 98 and forward. You need to create a new rule or rules that forward the above ports - allow them to be open to the internet for the xbox 360.
Looking at page 112. You would create a new port forwarding service, you need to add all the ports one by one. And the host device would be the IP address of the xbox.
Now the DMZ option will be simpler, that is on page 118. You just need to find the xbox ip address from its network options and put it there, and turn on the DMZ. That will allow all traffic for that machine.
Let me know how far you get. I'll help if you get stuck, sorry if this post is a bit unclear, this is a very small box to write in, I can't easily see everything I've already written here.
Sep 27, 2010 | Computers & Internet
My router is on, and is hooked up to my verizon modem. My xbox 360 and my computer are both hooked up to the router and all the lights are on but only my computer is working for the internet where my 360...
with verizon, you need to set the modem to full bridged mode so that the connection from your modem will be opened. This certain firewall is called NAT. Your modem and your router has this feature. To disable NAT on your modem, you need to set it to full bridged mode. To disable the NAT on your router, you need to open ports on your router.
You need to open this port on the router for Xbox live to work
TCP: 80, 3074, 53
UDP: 88, 3074
forward it to the ip of your Xbox.
this should set the NAT on your xbox to open, not moderate.
Sep 18, 2010 | Dell TrueMobile 2300 Wireless Broadband...
I have a Westell Versalink 327W with a strict nat and I want to open it up for Xbox Live. I have tried port forwarding but that only bumps it down to moderate not open. What should I do?
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
May 19, 2010 | Westell Wirespeed VersaLink...
Xbox needs NAT settings to be ''open'' not ''moderate'' How do I do this?
You need to go into your routers configuration page and Change the NAT, Network Address Translation, to "OPEN" or in other words, ALL traffic can pass through, as opposed to the "Moderate" or Allowing ONLY certain sorts of traffic to pass through to your PC. You need to look in your manual as to how to do this. basically you type the "Address" of the "Router" into the address bar of a browser, and login with login & password, then go to the NAT section and change it there.
Mar 02, 2010 | Westell Wirespeed VersaLink...
NAT on xbox live is moderate! i need it to be open, for best results. What do i need to do?
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
Jan 28, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How can i make my NAT open from moderate??? (xbox live)
TO opennthe NAT in your router. you willl need to make some changes on your router.
You will need to reduce the MTU on the router to 1365.
you will need to disable the firewalls on the router.
There are some port numbers that you will also need to open on the router.
For this you will need to open the set up page of the router.
Click Here for more info
Oct 17, 2009 | Zyxel P660HW-D1 Router
Switching from moderate NAT connection to an open NAT connection
yo tengo problema co el asistente de conexion del linksys
Feb 10, 2009 | Linksys WRT160N Wireless Router
How do i change my NAT connection from moderate to open
This one is simple. Find the IP address that your Xbox is assigned by your router, then put it into the DMZ. This also goes for PS3 users who are having trouble with internet access.
Change NAT to open
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Feb 09, 2009 | Linksys WRT160N Wireless Router
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
448 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
