Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
Verbatim Store n Go USB Flash Drive not working
When I plug my Verbatim Store n Go into my computer it won't work. It does not appear in 'my computer' and the light is no longer flashing on the USB key
5 Suggested Answers
SOURCE: My flash drive verbatim 8 gb store and go is not recognized
I have the same issue with a 4GB Store N Go, works fine on my Vista PC at home but after copying a 3.5GB file to it and then later trying to copy that file to my XP machine at work, it keeps disconnecting and failing with, "The volume for a file has been externally altered so that the opened file is no longer valid". I really wanted the file off the drive, so what I tried was using "Robocopy.exe" (in restartable mode, waiting 5 seconds between each retry) from the Microsoft Windows Server 2003 Resource Kit. Once you have a copy of this, you need to open a Command Prompt, change into a directory (CD\<foldername>) where you want to copy the file to, then swap to the USB drive and use the following command;
Robocopy Drive1 Drive2 /Z /W:5
E.g.: If the USB drive is D: and your hard drive is C: with a folder on it called "Backup" (where you want to copy the files to).. do the following;
Start - Run: CMD <Enter>
C: <Enter>
MD Backup <Enter> (If the folder doesn't already exist)
CD Backup <Enter>
(Note: Assumes robocopy.exe is in your PATH or the same folder)Robocopy D: C: /Z /W:5
This will probably take quite some time, depending on the number of files/size... but it did work for me (eventually).
Posted on Jul 16, 2009
  • 20 Answers
SOURCE: My laptop does not recognize my verbatim 8gb flash drive
go to Control Panel, then to System Mgr and then Devices. Check to see if all are marked with +s. You probably have a - in that area. Click on the minus and see what it says. You may need to add a driver or reinistall the flash drive.
Posted on Oct 25, 2009
SOURCE: verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
Posted on Feb 23, 2010
  • 121 Answers
SOURCE: How do I format Verbatim 2gb store and Go
Scan it with your anti virus and format.
Posted on Apr 15, 2010
Verbatim store n go usb flash drive 8 gb device not recognized
My Verbatim Sto N Go 8GB USB Flash Drive does not work in any port, in any computer. When I plug it in, the "Device is not recognized" error comes up. When I click on it, and the Unknown Device Properties comes up, the device status reads: "Currently, this hardware device is not connected to the computer. (Code 45)
To fix this problem, reconnect this hardware device to the computer."
The driver details read:
Provider: Advanced Micro Devices
File Version: 1.0.11.82 built by: WinDDK
Digital Signer: Microsoft Windows Hardware Compatibility
This is the 2nd drive of this same brand that quit working within 6 months. I have MONTHS of work on files in this drive, and would hate to have to redo all that work! I was real careful after the first one went bad to use the eject button when removing it from my computer. But I am thinking the last time I clicked the eject button, it froze, so I just pulled it out without the message coming up. Hopefully there is someway to get the computer to recognize this drive again???
Sep 26, 2012 | Verbatim ® Store `n` Go USB Flash Drive,...
How to download pictures from computer to verbatim
1) PLUG THE USB INTO USB PORT
2) THE USB DRIVE WILL APPEAR IN MY COMPUTER
3) SELECT THE FILES THAT YOU WANT TO TRANSFER TO THE USB
4) RIGHT CLICK ON THE SELECTED FILES
5) SELECT "SEND TO" FROM THE LIST
6) SELECT "USB" FROM THE LIST
Jan 25, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
I plugged in my 32 GB Verbatim flash drive with the store n' go software. I than turned it off. When I turned the computer back on and plugged in the drive, no prompt appears to open the flash and it is...
No, windows is probably just not assigning a drive letter to the device.
check out this tutorial.
I come across this problem pretty often with pirated copies of Windows 7.
If the above doesn't work or if you get stuck just reply to this thread and I'll help :)
Jan 22, 2011 | Verbatim EACH Flash Drive, USB 2.0, 32GB,...
NOT RECONISING THE PEN DRIVE-Verbatim ® Store
try a usb port on the back of the computer, if not the drive could be faulty
Jan 03, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
Cant seem to remove the "write protection" error off my store and go micro flash
It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties.
Dec 29, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
My flash not open when i make click on the disk he is give to me do you wont to formit
It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties!
Dec 24, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
Verbatim tuff n tiny 4gb usb drive is write protected but has no slider. How do I unwrite protect it?
Dec 12, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
My verbatim USB 2 GB is write protected. I am not able to remove write protection. Please suggest to solve the problem.
Nov 12, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
Vibratim 4GB flash ram write protected not writable and i cant format it
Oct 15, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
366 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
