Question about Sanyo VPC-S7 Digital Camera
When i turn it on i notice the screen display looks fuzzy. the lens is clean and the pictures look fine. but just wondering why the screen is not clearer
  • 3,230 Answers
Well may be it's because of moisture goes inside your camera screen, you can use a hair dryer to dry it but please do not you the dryer on high heat use them as a blower only. Post comments if further you have the same problem.....
Good Luck!!
Thanks for using FixYa!!
Posted on Jul 06, 2010
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
Fuzzy Display in bottom 2/3 of screen
Power supply is probably going out. Not likely the video card in this case.
Nov 18, 2012 | Viore " 24"" Class - LED - 1080p - 60Hz -...
Camera screen is fuzzy
Try cleaning the lens with a camera cleaning kit, other than that it will need to be serviced by a professional.
Mar 10, 2012 | Panasonic Lumix DMC-FH2 / DMC-FS16 Digital...
Fuzzy picture...started when first turned on tv,after a few minutes picture be came clear.tv now is fuzzy all the time.model #50vx915 ser.#v4k000487
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV to clean it inside.
Thanks.
Mar 30, 2011 | Hitachi Televison & Video
Image looks fine on LCD screen before snapping pictures and then has streaks or over exposed on the final picture
your problem is lens shutter maybe broken or stuck up. If you notice once you take picture and check to the display it was fine but try to zoom to the maximum you will found out that there's a line in you image.the only way to solve your problem is bring to service center and ask for cleaning the lens shutter.
Jun 03, 2010 | Kodak EASYSHARE Z1285 Digital Camera
Fuzzy picture
have you taken off the screen and tried to clean the lens as well as the mirrors inside the set?
May 04, 2010 | Sony KP-53XBR200 53" Rear Projection...
Describe your Canon A95 Fuzzy line problem on images and display.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 19, 2010 | Canon PowerShot A95 Digital Camera
Pictures fuzzy when you look through the viewer.
The viewfinder and the picture lens are totally separate. If it looks fuzzy, and then comes out fuzzy, the capture screen inside needs cleaned. The main lens and viewfinder lenses should be cleaned too.
Get estimates before you say yes to the work. It might be cheaper to buy another camera, unless you can do the work yourself.
Aug 06, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
Camera lens might be broken
My friend droped my camera and the lens is sideways. i can look at my pictures, but when i want to take a picture it is black and says lens error. what should i do?
May 21, 2008 | Casio EXILIM EX-Z70 Digital Camera
Lines on screen
Hi, I have the same problem with my sony DSC-S700. I think someone drop it, and it took pictures with horizontal line specially outdoor. I noticed that the lens shutter does'nt open and close. All I did was to tap on the lens several times and everythings back to normal. I so happy my camera is working again. Thanks to your idea. Brenton
Sep 24, 2007 | Kodak EasyShare Z612 Digital Camera
Sanyo VPC-S7 Digital Camera Logo
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
