Question about Pitco Frialator SG14 Deep Fryer
Pitco Frialator SF14 pilot will light and the burners will light but within an hour it completely shuts off (pilot and burners). The high limit and thermostat have been changed 1 month ago.
  • starztruck4u Aug 17, 2010
    Have you checked the temperature of the oil when it shuts down ? Something sounds fishy.
    Tom
  • Pitco Frialator Expert
  • 683 Answers
Check the hi limit sensing bulb, it should not touch the fire tube, when it does, it will sense high temperature which will trip its mechanical contacts and will shut pilot and burner flames.
Make also sure that the thermopile is free of soot or any form of dirt and is properly heated by the pilot flame.
Posted on Jun 08, 2011
13 year old pitco frialator fryer pilot wont stay on. changed gas valve and thermopile.... pilot light wont stay lite
Hi there.
Check and tighten all wiring connections.
Check the hi limit for continuity across the terminals using an ohm meter, if it has no continuity, you have to replace the hi limit.
Regards.
Aug 21, 2011 | Pitco Frialator 35CS Deep Fryer
The burners will not light. The pilot does light. I had my staff try to hit anything that looked a reset, but I don't know if the high limit switch has a reset or if the switch itself is bad.
The high limit switch has nothing to do with the pilot light, but will shut down the main burners. It the pilot light will not stay lit, then it is most likely the thermocouple. If the pilot light will not light at all, then gas is not reaching the pilot. Most likely, the pilot light tube is clogged with grease. When you push on the button to light the pilot, you are overriding all safeties inside the unit and sending gas to the pilot. Also make sure that the unit itself is getting gas. New regulations require a shut off within the hose that feeds the appliance which will shut off due to a surge of gas through the hose. To reset it, disconnect/reconnect the hose at the intake end and when you turn the gas back on, turn it on slowly.
Jun 11, 2011 | Pitco Frialator 35CS Deep Fryer
Seems like it shuts off when its gets to a certane temp have to relight pilot
Check if the oil temp does not reach 450F because if it does, it will trip the high limit device that will shut off the burner flame as well as the pilot flame. But if high limit device trips off prematurely (at temperature less than 450F) you have to replace it. Just make sure that its sensing bulb does not touch the fire tube.
Apr 25, 2011 | Pitco Frialator 35C Deep Fryer
I have a 40c+ss pitco fryer.the pilot will go out at random times.Could be 1hr or 24 hrs after it is lit. The gas valve has been change, and the thermalpile has been replaced.
Check if your pilot flame sufficiently heats thermopile during operation and make sure also that it is free of soot or any form of dirt, thermopile generates small amount of electricity to energize pilot and main valve of the gas valve for pilot and main burner operation. This electricity passes through hi limit mechanical contacts. Hi limit on fryers act as safety device which will shut down pilot and burner flame when oil temperature reaches 450F.
If your fryer is set at 350F and over shoots up to 450F (which will trip hi limit and shut down pilot and burner flame), the thermostat is not good, but, if hi limit trips on temperature much lower than 450F, hi limit is bad.
Nov 12, 2010 | Pitco Frialator 40CNG Deep Fryer
A pitco frialator in a restaurant will operate for about 5-6 hours and then blow the pilot light and burner out. I have put a thermometer in the oil, watched it work and the oil temps wont exceed 375...
I assume that the thermometer you are using is calibrated. You have to check the continuity on the hi limit terminals once the pilot light shuts off. If it has no reading, the hi limit trips prematurely and it needs replacement.
Nov 05, 2010 | Pitco Frialator 45C Deep Fryer
550 degrees and shuting down
Replace the thermostat. If it's really getting to 550F without shutting off the pilot and main burner, or the electric in an electric fryer, by tripping the high limit, replace the high limit as well. The high limit should shut off all the gas or electric at about 425F.
Feb 25, 2010 | Pitco Frialator 35CS Deep Fryer
It heats to 550 no matter wat
Feb 24, 2010 | Pitco Frialator Kitchen Appliances -...
I put it on any temp and it heats to 550 degrees
Replace the thermostat, P5047588. If the fryer is not shutting off, both main burner and pilot, when it overheats, also replace the high limit PP10084. The high limit usually shuts the fryer off at about 425-450F. Check your thermometer. A fryer should never get up to 550F.
Feb 24, 2010 | Pitco Frialator 35CS Deep Fryer
Pitco Fryer
Sounds like the burners are dirty remove burners and run under cold water and replace propane gas burns dirty and might have blocked up burners creating a pop at the burners this will then blow out pilot light if this does not work give me a shout
Jul 27, 2007 | Pitco Frialator SG18S Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
251 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paulcarew
starztruck4u
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
