Fisher CA-885 Integrated Stereo Amplifier stuck in stand-by mode
I have a Fisher CA-885 Integrated Stereo Amplifier that is stuck in stand-by mode. It is a stereo system that I have stored for years out in my shed so it has been exposed to heat and cold. Prior to that it worked fine. Yesterday, I hooked up the rack system and it was working until I put it in standby mode and then tried to take it out of standby mode. When I put it in stand-by mode, all the lights on then system went out and the stand-by light was on. When I tried to take it out of stand-by mode, the system lights came back on but the stand-by light didn't go out and I can't get any sound out of it. How can I get it out of stand-by mode when pushing the stand-by button doesn't work and unplugging it and replugging it in doesn't work?
  • 4,234 Answers
Given the heat/cold cycles of the storage area along with humidity, I would first suspect poor solder connections. This is not unusual for units of this age. A general overhaul should restore this to operation. This should be a labor only repair unless the output STK is bad. These units are known for having poor connections at the voltage regulators which cause a DC voltage offset triggering the protection circuit. The overhaul should address this as well.
Keep us posted on your progress.
Dan
Posted on Jul 06, 2010
Testimonial: "Thanks for the suggestion. I'm not sure if I am going to have it serviced or not. I may take the cover off and see if it is something obvious that I can try to fix. I called around today and having it serviced isn't cheap. It might not be worth it. But I will look at the solder connection and fuses. Thanks"
2 Suggested Answers
SOURCE: HI I have fisher integrated
Hi, I came across this model amplifier in a Goodwill today - was checking online about specs (which is how i found your post) to see if it was worth purchasing and reselling. If you're still interested please drop me a note directly at jtimleck &&**##_at_%%$#@mac *&^ dawt calm
Posted on Jan 15, 2011
I just bought a standard studio by fisher fm-600, do i need an amplifier to hook it up?
According to the picture of one on eBay it appears to be an old school stand-alone tuner so, yes, you need an integrated amp to drive speakers.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&_trksid=p4340.l2557&item=110668824047&nma=true&rt=nc&si=DnF0oreD08pmu6sCzXTYLPJXs5Y%253D
The lack of speaker posts on the back and a volume control on the front are big clues that it has no amps.
Apr 23, 2011 | Audio Players & Recorders
I was given an old fisher 885 receiver, eq, and tuner. Dont know where all the wires plug in the back and cant get it to work. Any idea where the red and white input wires plug into where?
Do you mean the CA-885?
I couldn't find any free documentation but I did find pictures.
http://forums.audioholics.com/forums/showthread.php?p=227936
With the exception of PHONO, which is literal and for a turntable ONLY, any input will work with any standard analog stereo audio device output.
RCA Red and White connectors are interchangeable but usually consider Red to be the Right Channel and White to be the left Channel.
The two tape loops are for tape decks or external processors like equalizers. OUTs (RECord) go to INs (PlayBack).
Mar 22, 2011 | Audio Players & Recorders
I have a fisher ca-9335 integrated stereo amplifier thats hooked up to sanyo tp 1010 turn table and plays out of yamaha ns-70t speakers. a simple jvc cd player is also hooked up to the speakers but not to...
Something doesn't add up. You mention two connections to the speakers - CA-9335 and a "simple jvc cd player". Is that true? If so, you might want to UNconnect the CD from the speakers and run it into the receiver where it belongs. An amp isn't designed to share the load with another live device; or even have electrical contact with anything BUT speakers.
Did you actually find documentation that supports this hook-up? Or just winging it?
Feb 20, 2011 | Audio Players & Recorders
HI I have fisher integrated stereo amplifier model CA-885, it was totallydamaged.I would like to by new one will you please help me. gasim
Oct 15, 2010 | Audio Players & Recorders
Need to locate the microprocessor on the fisher ca-9025 stereo amplifier. Need to know where it is and what it looks like. This is so I can repair the problem of the stero not going off stand-by....
Yep, that is a likely problem, but it could be a blown diode in a relay switch, or etc. etc. If you're lucky, someone will possibly have a repair manual, and schematic. That way, you could reset it, but maybe ohm out a few components further up the on/stand-by circuit while you're in there. Sometimes you get lucky and it's easy, but it can be tricky. I would take digital pics or videos as I went, using macro when necessary. Makes things much easier for me, anyway. You can possibly purchase a schematic, but I couldn't find one online, so if you can get a current tech line, you could probably go that route, but I'm thinkin' big bucks. Here is a blog about your problem, and although there isn't a schematic that I saw, it does identify the components in "stand-by" circuit, as well as the microprocessor.
http://www.freelists.org/post/techassist/Fisher-AMP-CA9025DEADmore-info,3
Gutsy job, but that's the only way to keep them alive, from what I've seen! Good luck!
Mar 27, 2010 | Fisher Audio Players & Recorders
Fisher Stereo Intergrated Amplifier CA 9025 is stuck on standby
just bought a ca-275 that i cant seen to get any sound to come out of. but im also testing it with car speakers. is this my culprit
Oct 14, 2009 | Fisher Audio Players & Recorders
JVC AX-66 Integrated Amplifier seems to be muted?
You need to have a jumper between the 4 standalone jacks on the right side of the column of stereo connectors. A stereo RCA cable would work for this.
Oct 14, 2009 | JVC Audio Players & Recorders
How to connect the FISHER EQ-273 equalizer to the FISHER CA-885
It goes between whatever you are using to create the sound and the input to the amplifier.
e.g. for a standard HiFi.. HiFi aux out to equalizer input... equalizer output to amplifier aux input.
Trying to keep left and right channels the same through out. They are usually colour coded. Red = right Left = white.
Hope that helps.
We all start somewhere
Mar 18, 2009 | Audio Players & Recorders
Fisher ca 9025 amplifier
For those who accidently put thier CA-9025 in standby mode by hitting the timer button and no longer have the remote, I figured out how to turn them back on.
Turn on the power button and press and hold the Tuner button for at least 10 seconds. it should come back on :) Hope that helps.
May 08, 2007 | Fisher RS920
1,063 people viewed this question
 Grubhead
Grubhead
