Question about Smeg SUK81MFX5 Gas Kitchen Range
Smeg SUK81mfx5 fan oven problem
I have a Smeg SUK81mfx5 range cooker. We inherited the item when we moved into our new house, and the oven never heated up when the fan oven was selected. I ordered a new fan element, and having been advised it was a simple task, fitted it myself with no problems - took photos of where all the wires went etc and double checked everything before switching on. The problem is that now the fan oven heats up, but keeps heating up to maximum irrespective of the thermostat setting. The thermostat itself functions fine, as it does its job alright on the other types of oven setting - and you can hear the switch clicking on and off when you sweep the dial. Any ideas anyone?
3 Suggested Answers
ronaldo1
SOURCE: cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Posted on Feb 15, 2008
SOURCE: Hi i have inherited a Smeg range cooker when I
Unfortunately, I don't have a solution for you. That's because I have exactly the same problem. Did you ever discover how to fix this problem?
Posted on Nov 04, 2010
SUK81MFX5 oven light stays on permantly
Can be the micro switch. With mine, the oven door was put back incorrectly and part of the hinge pushed the metal lever that activates the switch upward, and jammed it there. You need to get a bit of wire and hook it down again so that it covers the switch.
Jun 05, 2012 | Smeg SUK81MFX5 Gas Kitchen Range
Hi, we have a se280x oven and its about 4-5 years old and inherited this when we moved in 2 years ago. But the oven seems to heat sometimes or not constantly and especially seems like e the upper and...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Apr 15, 2011 | Smeg SE280X Stainless Steel Electric...
SMEG A42 fan motor problem
check that the fan mounting screws or bolts are in place and tightened
Aug 02, 2010 | Smeg A42-5 Dual Fuel (Electric and Gas)...
Jul 14, 2010 | Ovens
Problems with the oven heating up on Smeg CC92 MFX5 range cooker
instalation wiring may be criss crossed if under warranty get them out to fix it.
Oct 13, 2009 | Kitchen Ranges
Smeg A1 cooker built in. Wish to remove top to access thermocouple. Cannot see the fixings for the top. Any pointers please?
my smeg oven has always never worked properly, the temperature is faulty etc i now want to remove this oven and have bought a new electrical oven but cannot seem to get the smeg oven out. How do i remove this smeg oven?
Mar 20, 2009 | Smeg A1A.1 Gas Kitchen Range
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Cooker not heating up
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smoke from oven
I am a recently retired appliance engineer of 20 years sounds like pure coincidence, check the fan for circuit at terminals, and / or check for movement of blades, that you have not got fan jammed, replace fan motor unit if needed, still cheaper than a call out if i have helped rate me work with safety all the time, unplug at all times when working on any item
Sep 09, 2007 | Kitchen Ranges
Smeg SUK81MFX5 Gas Kitchen Range Logo
89 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
