Question about GPX KCL8807DT TV/DVD Combo
I need a replacement built in dvd player for my magnavox tv/dvd flatscreen combo model id# 32MD251D/37, I pulled out the broken unit and it made by eastech and its model number is dp0001
Looking for an owner's manual for a Magnavox 28MD304V/F7 28-Inch 720p 60Hz LED TV-DVD Combo [ASIN: B00KVLZSTG]
Free Magnavox Flat Panel Television User Manuals ...
tv.manualsonline.com > ... > Magnavox > TV and Video Magnavox
Products 1 - 50 of 128 - Magnavox OWNER'S MANUAL LCD TV Monitor 15MF200V/37. Pages: 0 ... Magnavox User Guide LCD TV With DVD Player 17MD250V.
Jan 14, 2016 | Magnavox Televison & Video
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2293282/magnavox-loud-static.html
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help · Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
ask.metafilter.com/17525/What-is-that-TV-Buzzing-Noise
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
HOW TO FIX VCR & DVD PLAYERS REVIEW - YouTube
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help - ecoustics.com
Dec 30, 2015 | Magnavox Televison & Video
32MD251D/37 will not power on
Zack Corpier
Workup for repair
02/22/2013
Diagnosis for Magnavox 32MD251D/37
Symptoms:
Will not power on
Once on, if turned off power might not return
Does not respond to power cycling
Possible Culprits:
Overloaded fuse
Damaged/fried power board
Damaged/fried inverter board
Damage to wiring or related
Overloaded capacitors on power board - I identified this based on a visual inspection and a multi meter test
https://lh6.googleusercontent.com/-Mcf67G5l3l8/USgitModWZI/AAAAAAAACRo/PwjueC45Hjo/w333-h319-o-k/caps.png
Problems Identified:
Capacitor 2079 appears overloaded - 1200uf 35v
Capacitor 2080 appears overloaded - 1200uf 35v
Explanation:
The capacitors referenced regulate the voltage controlling the power. These caps have a limited lifetime in hours which is usually around 3000. The device was left on for an extended period of time overloading these essential components.
Resolution:
1. I will order a set of replacement capacitors
2. Discharge board prior to work
3. Remove and replace damaged capacitors
Required Parts (total cost $30):
(2) Vented axial 1200uF 35v Capacitors - $8
Variable wattage soldering iron (minimum 35w) - $22
Feb 10, 2013 | Magnavox 32MD251D/37 Tabletop Pedestal...
In the combo tv and vcr their is no pin hole near the dvd so how will I eject the cd
The best way, in my experience, is literally disassembly. Pull the back off of the television and be very aware of the different ribbons connecting PCB's. Note where everything was plugged in (take pictures if you must), and find where the built-in DVD player is mounted (should be attached to the back cover). Remove the player and disassemble. It's generally fairly intuitive. You should be able to reduce it into a pile of parts and get your DVD out!
Word to the wise: I'm an electronic service technician, and I have seen a good many of these built-in DVD players fail. Actually, they all tend to fail within a year. They are also 30.00 units. No 30.00 unit has ever been even close to a good piece of equipment. That said, don't replace the internal DVD drive. Just buy a component player.
May 14, 2011 | Magnavox 32MD359B 32 in. TV
Need to know if I can record from dvd to vcr on a magnavox ZV420MWB vcr/dvd combo
Magnavox ZV420MWB VCR/DVD Combo
The answer is YES YOU CAN! Take advantage of one-touch recording from videotapes to DVD+/-R and RW discs or from DVDs to VHS tapes. A variety of different inputs also let you record from compatible camcorders, external TV tuners or cable boxes.
CONSUMER ALERT: This model does not have a built-in tuner for recording TV programs and will not record copy-protected tapes or discs. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission's digital television website at: www.dtv.gov.
Feb 15, 2010 | Philips Magnavox DVD/VCR Dual Player
I need a firmware or software update to play a hddvd in my flatscreen/dvd combo. its an emerson 19inch flat screen model ld195em8
Sorry to say, but a firmware update will not reformat your DVD player into BluRay or HDDVD capabilities.
There is only one way to get your TV to display BluRay DVDs, that is to purchase a BluRay player and connect it to your TV with a HDMI cable, now this will also require your TV to have a HDMI port to connect to, and your TV must be able to display full
1080p resolution,with that said I don't know of a 19" TV that is full 1080p capable,especially not a combo unit.
Good luck !
Jan 11, 2010 | Televison & Video
Won't record..
try swapping the scart lead to the second AV port on the player sometimes 1 is input and the other output run your tv cable direct to the player and scart to tv hope this helps
May 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Vcr will not record
THE CABLE OR ANTENA NEED TO SCREW INTO THE INPUT OF YOUR UNIT THEN A SMALL WIRE OUT TO THE TV FROM YOUR UNIT PUSH RECORD WHEN SHOW IS ON TV !SO ITS CABLE INTO VCR INPUT THEN CABLE FROM OUTPUT OF VCR TO TV ....TV ON CHANNEL 3 AND VCR UNIT ON CHANNEL 3
Dec 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Sunia LTD-1720 17" Color LCD TV and DVD Player Combo with Remote
i have a sunia tv anddvd combo need a remote and programming instruction for it. the remote model is rc518n than you
Apr 26, 2008 | Televison & Video
Can I connect a dvd player to a dvd\vcr combo
I am not sure I understand why you would hook a dvd player to your combo.You should just hook your magnavox directly to your tv.
Sep 24, 2007 | Televison & Video
GPX KCL8807DT TV/DVD Combo Logo
116 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
