We have a Hi Def Samsung TV that has lost its picture. Can you walk me through the procedure to try to get it back?
  • 8,617 Answers
Thats something you would need the service manual for to be able to see which part is malfunctioning. I would recommend going to the following link as they will most likely have the service manual for your model which they sell very reasonable and it comes with free tech support so you acn go one on one with a repair tech that will help you get it going. If you dont see your model just leave them an email as they most certainly can get it. They email the manuals out instantly and support is handled my on line instant messaging. Its a good service I am one of their support techs. here's the link.
http://servicemanuals.vstore.ca/
Posted on Apr 18, 2008
No picture on Samsung HP-R5052
Just a couple of things to try:
You say you tried another cable box and a roku. Are you using the same cables? Are you using hdmi, component or coax cables? Could be a bad wire. True high def tv 1080 requires an hdmi cable for the best picture. The next best choice is the component cable. This is a triple cable with red, green, & blue and provides 720 resolution. The least quality is the coax wire which will only provide low def standard quality picture. Sometimes people hook up 1, 2, or all 3 of these choices not knowing what it all means. If thats the case with your tv it may just be a matter of selecting the correct input on your tv with your remote. On your samsung remote there should be a button for input. Try pushing that button and make sure it's set to hdmi or component, whichever your using. If none of this, is it possible the plasma tv itself is defective?
Apr 08, 2014 | Samsung HP-R5052 50 in. Plasma HDTV
Picture blacks, tv needs to be turned to bring picture back. wii games do not go black
This is caused by your QAM decoder on hi def Sharp sets. You need to rescan for channels, turn off your TV then turn it back on to set to save the channels.The problem lies in the Tuner board and some Hi-Def signals can change frequency slightly due to improperly shielded cables etc. Verify that all of your cables, especially the Cable TV wire are firmly seated on your set. An improperly grounded cable television wire can wreak all kinds of havoc on reception.
Oct 29, 2010 | Sharp Aquos LC32D41U 32 in. LCD TV
No picture - only sound
Ok, on a hi-def tv, you must have a converter box capable of receiving Hi-def. If you are using a converter box from a satalite or cable tv service, try getting a Hi-def box. Also try hooking a vcr or dvd player to the tv in the non high def ports to varify that this is the problem. If you have any question please let me know, I hope this helps, good luck.
Sep 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture blurry like 3 - D
Ur convergence is dead.U know how to solder?Tries this website. Tv Repair World.com buy the convergence kit,and replace it.
Sep 04, 2009 | Hitachi 57F500 57" Rear Projection...
No picture when cables connected
Go into menu on cable remote and open up 480p,480i,720 and 1080 . I think on some of those 1080HD only works on one of the two component inputs. The other is only rated for 720. Usually it has this info on set at input. Hope these suggestions are helpful.
Jun 09, 2008 | Samsung Televison & Video
Reccomended settings for Samsung 52 inch LCD tv
I have recently posted a question regarding my Samsung 52 inch LCD hi def television. After doing some research online and reading some others experiance I have adjusted my settings in the menue of the tv to provide the best picture.
May 30, 2008 | Televison & Video
NON- Hi Def channels loose thier blue? color....picture is all green
Some CATV hi-def receivers are known to have issues keeping up with the datastream. Symptoms from the picture going solid black to other unpredictable video have been seen. Ask your CATV provider if they can switch your brand to another manufacturer. If your cable box has component video jacks in addition to HDMI, try that too. Some boxes will output RGB perfectly but bomb out with HDMI.
May 03, 2008 | Sony KDF-E55A20 55 in. LCD Television
Picture problems
The pixelation is probably caused by MPEG2 compression on the DVD and Virgin media video streams, the blur is probably caused becasue you are displaying a standard definition signal on a high definition TV.
However if a high-def source still has these problems then you may have a faulty TV, your best bet is too hook up a high-def source such as a HD/Blu-ray player or PS3/360 games console.
Should a high-def source look ok, then you may have some look changing the display settings on the TV to try and improve picture sharpness and color balance.
Thanks.
Nov 08, 2007 | Televison & Video
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
