Question about Microwave Ovens
I have a NN-E255M microwave oven when I turn it on at the wall it does not bleep and will not let me set the clock. When trying to set the clock it scrolls through 10.00 20.00 30.00 I have also had the word pass appear in the display window? here`s hoping you can help Rick
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
SOURCE: microwave panasonic model nn 6358 about 10 years old
NO HEAT BUT OTHER WISE NOMAL OPERATION NO MICRO OUT PUT
Posted on Nov 07, 2008
EwingElect
  • 276 Answers
SOURCE: our microwave oven Panasonic NN-S252WF stops after
Our technician suggest that there may be a problem with the Inverter Board in this model, which is something that would need to be looked at by a Service Center.
In rare cases it could be the door switches.
Posted on Mar 27, 2009
SOURCE: Cannot change clock on Panasonic NN-E442W Microwave -
Microwave due for replacement shortly therefore we can live with the clock showing the incorrect time
Posted on Oct 28, 2009
How to set the clock Model NN-SA651S
To set the clock, press Timer/Clock twice when the microwave is not in use. The colon between the hour and minutes should start to blink. Type the current time (12-hour clock) with the appropriate number key pads. To save the time and exit the clock set mode, press Timer/Clock once more. Note: if you take too long to begin typing the time, the microwave may exit the time set mode. In that case, the colon will stop blinking. None of the other features of the microwave will work when the colon is blinking.
This is shown on page 11 of the manual which is available on the Panasonic NN-SA651S support page: http://shop.panasonic.com/support-only/NN-SA651S.html . The direct link to the manual is currently ftp://ftp.panasonic.com/microwaveoven/om/nn-sa631_nn-sa651_nn-sa661_en_om.pdf .
I hope this helps.
Mar 16, 2018 | Microwave Ovens
How to reset the clock on a Panasonic NN-SA651S microwave.
hi carol.
try this,if this does not work go to the link.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set. You are now ready to use your new Panasonic Microwave Oven. When you first turn on yourmicrowave oven and under normal operation the "CHILD LOCK" feature is off. If "LOCK" or "CHILD" appears on your display . . .
set-up guide - Panasonic
ftp://ftp.panasonic.com/microwaveoven/om/set-up_guide_en_om.pdf
How to reset the clock on Panasonic NN SA651S microwave Google Search
Nov 07, 2017 | Panasonic Microwave Ovens
I have a panasonic nn 2501, .You can set the time, hit start, the time will run , but the microwave does not run. What is up? Door safety switch? Thanks, VIC
you are setting the time on the microwave clock , your press the wrong button ,you can try just putting in the number of mins and press start, or theres cook then time and start. if helpful plz rate..
Jan 19, 2011 | Panasonic NN-S251 Microwave Oven
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Apr 03, 2009 | Panasonic NN-P794SF Microwave Oven
I have a panasonic range microwave oven model NN-H264/S254 clock cannot be set. (It use to work but no longer can be set)
Sounds like you disabled the clock function. If you do not have the user manual, you can get a copy at this website and use the function keys to reactivate and set the clock...
http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/NN-H264-_E
I belive the information you seek is on page 12 of the manual.
Hope that helps...
Aug 13, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
