Question about Copystar CS-1500 Copier
AP MESSAGE MESSAGE AP PUT IN NEW TONER
    President:
  • 3,085 Answers
Keep opening and closing the toner door to force toner feeding
Posted on Jul 06, 2010
Ok i have a copy machine is Kyocera km 1505 is appear code Ap i put new toner and is the same what can i do
try to put direct toner in the developing unit then restart the machine if problem still persist try to replaced your developer
Apr 11, 2011 | Kyocera KM-1505 Copier
We have a kyocera mita km-1505 photocopier. The error message coming up is AP. Can you tell me what we need to do with it?
just check the toner cartridge maybe the toner is empty if its empty just replace a new one
Dec 06, 2010 | Kyocera KM-1505 Copier
What is error code AP for this copier and how do I fix it?
ap means aging process or toner replenishment just check the toner if the toner cartridge is empty just fill a new toner
Nov 23, 2010 | OCE 3140 Copier
Code "ap"
means copier is adding toner. you maybe able to install new toner and message will go away. also may be bad developer or sensor. replace the toner firsrt. if it does not fix it call a tech
Dec 30, 2009 | Copystar CS-1530 Copier
MY 1810, i GET AN "ap" FLASH THAT changes to "OP' I find no paper jam in the trey nor the back..Mike
hi
the AP means that the copier needs more than one cycle to add toner.
This usually happens when the copier is used for a whiile after the add toner message comes on
Aug 22, 2009 | Copystar CS-1810 Copier
I already replace a new toner but there an error msg AP
Hi
The AP message indicates thet the dev is so low in toner that the machine has to go into a full cycle mode to get the toner levels up.
The error code is telling you that one cycle is not enough. you will have to turn the copier off/on and cycle it at least one more time....more if neccessary
Jun 15, 2009 | Kyocera Office Equipment & Supplies
The screen says AP -what does that mean
AP means that the copier is going thru a major toner cycle.
Sometimes when you drag a lot of toner out for dark copies, the normal toner cycle is not enough.
The spring that takes the toner from the cartridge to the dev unit mat also be faulty or broken.
Sometimes the AP message will go away but make sure you have plenty of toner.
Feb 09, 2009 | Kyocera Mita Kyocera-Mita SCANNER RACK...
AP message on KM-1810
AP = Ading Powder (toner) most of the times it means the toner is near it's end order a new one :)
Nov 14, 2008 | Kyocera KM-1510 Copier
Km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Oct 22, 2007 | Kyocera KM-1510 Copier
Copystar CS-1500 Copier Logo
67 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
