Question about Bushnell NorthStar 78-8846 (675 x 114mm) Telescope
Bought a used Bushnell NorthStar #78-8846 controller not working
Installed new battery, have to hold start button to faintly see red light, i think its the circuit board problem, if it were where could i get parts, so the controller does not come on at all.
  • 3,186 Answers
Contact Bushnell warranty and repair at this web site:
http://www.opticsplanet.net/bushnell-warranty.html
Posted on Jul 06, 2010
I just purchased a northstar, goto telescope, model 78-8876. I purchased it second hand. When I try to turn on the power on, I have to keep the power button pressed down to have power, I let go, the power...
Obviously either your hand controller is broken and or a circuit inside the scope.
Here is Bushnell's repair web site:
Apr 10, 2011 | Bushnell NorthStar 78-7880 (190 x 78.74mm)...
Hello, I have Bushnell Northstar 78-8831 telescope which I got from United States (New York) last year. Since the very first day, I am not able to get the option of "Align Start 1" After...
This can be caused by many things-- such as dirt or grease on the encoders inside or a slipping clutch. I know you just bought this telescope, but Bushnell is NOT KNOWN for having quality telescopes.
To get the goto to work everything must be according to the manual.
The tripod needs to be perfectly level-- time, date, and site must be accurate, and the alignment objects must each be centered in the eyepiece. Sounds like you also have electronic issues with the hand controller. Only Bushnell can repair this scope.
Apr 04, 2011 | Bushnell NorthStar 78-8831 (525 x 76mm)...
Replacing battery for red dot finderscope on Bushnell NorthStar 78-8846
It's usually a small watch style battery. Look around for a small compartment on the finder that holds the little battery.
Nov 27, 2010 | Bushnell NorthStar 78-8846 (675 x 114mm)...
The hand held unit lights up when turned on, and the telescope "homes" but the LED does not show anything. The voice speaks "Bushnell Northstar" but very quietly. The telescope can be moved by the bottom 4...
Can you reverse the cable end to the hand controller-- a bad cable can cause this. Also low power supply, depleted batteries can also cause this.
Return the hand controller for replacement if batteries and or a new cable do not fix this.
Dec 24, 2009 | Bushnell NorthStar 78-8846 (675 x 114mm)...
Bushnell 78-8890 Power On
If this is a new unit (or even if it is not), I'd call Bushnell for help!
UNITED STATES
Bushnell Corporation
9200 Cody
Overland Park, KS 66214-1734
Important Phone Numbers:
In Kansas City area - (913) 752-3400
Consumers - (800) 423-3537
Dealers - (800) 221-9035
Fax - (913) 752-3550
Mar 05, 2009 | Bushnell NorthStar 78-8890 (300 x 90mm)...
Motors dont work even with new batteries
I had the same problem. I removed the motor and drive assembly and used a pair of pilers to gently rotate the drive gear a few times in both directions. I re-installed it and it began to work again. I also noticed that the grease on the drive gear and shaft was very thick. Cleaned and up and re-applied a lithium based grease and it helped even more. Be sure to remove all old grease from the aluminium block that the drive gear shaft rest in. Good luck.
Nov 15, 2007 | Bushnell NorthStar 78-8831 (525 x 76mm)...
Open Questions:
Bushnell NorthStar 78-8846 (675 x 114mm) Telescope Logo
192 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
