Question about Pool & Spa
My hot tub seems to be running almost constantly. I have tried to reset heating mode and temp. Also lowered temo to try to get it stop running so much. Any ideas as to what the problem is?
2 Suggested Answers
  • 366 Answers
SOURCE: I have a 2004 great lakes hot tub with a balboa
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Posted on Feb 09, 2010
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
Jun 05, 2017 | Heating & Cooling
Just drained and refilled, plugged back in and hot tub is not heating. Three lights flashing at temp controls. Is there a reset
Most hot tubs have a freeze protection that will lock you out and run the pumps full blast with no heater if the temerature is under 50 degrees F.The circulating pumps create heat until the water temp is above 50 degrees, and then the heater will come on after that.
Hot tubs do this to protect themselves and it is normal operation.
Nov 22, 2010 | Qca Spas Pool & Spa
Hot tub stuck in 'SL' mode
Need to know what buttons your topside control has... depending on the model, some have a mode button which you press and release and then immediately press the temp up or down, to select SL for sleep (no heat), ST for standard (heat as needed) or EC for Economy (only heat during filtration). If the mode button is not present, and you have a single temp button and light button, try pressing and releasing temp and then immediately pressing light button, repeat until choice appears, then wait, it will hold last displayed mode.
Jul 09, 2010 | Jacuzzi Balboa R574 System for 1 2 Speed...
Hot tub heating is working but pump has stopped
you may have a system that uses a small circulating pump that circulates the water thru the heater to keep water temp at proper level (this is usually the case with hot springs spas and is because it is the most cost effective way to maintain constant water heat without using a full size pump or two speed pump just to push water past the heater core. therefore the issue is you have a problem with your jet pump and it has nothing to do with the circulating and heating portion of the spa. you can check to see if there are any reset buttons in or near the equipment as well as open enclosures to make sure everything is clean and dry also make use any contacts on spa skirting are secured propertly
Apr 24, 2010 | Pool & Spa
This is an old hot tub qca jewel spa that runs all the time
your ozonator may have condensation water in it, try unplugging it and using a hairdryer to dry it out, otherwise you will need a replacement ozonator (i know where to get these at dealer cost if you need one). When replacing ozonator, make sure you request the correct plug type depending on if you have the white plugs or gray plugs that plug into either the side of your spa pack or the circuit board.
Good job on isolating the problem by unplugging each component when a circuit breaker trips. Next, your filter cycle is most likely set on constant filtration, you will need to reset it to 2-4 hours per 12 hour cycle. Don't put it in standby, leave it run in standard mode. Hope this helps,
Spafixer
Mar 20, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Even thuogh I made sure it was not on economy mode my hot tub will not heat up and the message board keeps flashing the word cool, do you know what could cause this?
it may be a bad temperature sensor or a bad heating element. Sounds more like a heating element. The cool should just be a warning or depending on the model, could mean that it thinks the water is too hot and is in "cool" mode trying to cool the water. Have the temp sensor and the heating element checked.
Feb 05, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Hello! the pump on our qca majestic hot tub
If you live in cold weather and are not using it much lower your thermostat. If the freeze control kicks on (at about 38-40degrees) it will constantly try to heat the spa to where you have the heat set when the air temp is low. Hope this helps.
Oct 28, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Pump is running ever 5 minutes. The heat in the
Sounds as if the 'mode' for the tub is set to sense the temperature of the water. see if there is a setting on the control box to a 'timed' setting for filtering and heating instead of controlled by the temperature setting. the problem is the the control box is away from the water and when it calls for heat it is because the water is cooler there than in the hot tub. so when it calls for heat and the water starts to circulate it gets the hot water from the body of the hot tub and then shut down because it senses the 'hot water'. make sense?
Feb 23, 2009 | Blue Wave Aruba 15' Round 54" Resin Pool...
Pool & Spa Logo
273 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
