Question about Fellowes PS60C-2 Shredder
Both red & green lights light up simultaneously when I turn the PS60C-2 on, and it does not start up when paper is inserted. When I lift the head off the container I can hear and feel something heavy rolling around in the head. Both these symptoms appeared for the first time this morning. Can I dismantle and re-attach whatever has broken loose? Or is this likely to be a job for a professional?
  • pwgbrock Jul 07, 2010
    Yes, the solution encouraged me to working at it until the problem was resolved
If you are mechanically inclined you can repair this at home. You will need to order a new gear kit. Click on the link below to view
http://cgi.ebay.com/PS60C-2-Gear-Kit-Fellowes-Shredders-NEW-OEM-30192-/250579237092?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item3a57afb8e4
Posted on Jul 06, 2010
  • pwgbrock Jul 06, 2010
    Thank you, Mike.
    Update: I found the hidden screw; opened the head, and found that the mount on a heavy little black box (? a transformer) had broken. I glued and re-attached it.
    Both lights still lit up simultaneously -- until I jiggled the little chrome tab visible through the slot at the back. When I pressed up on this tab, it switched off the red light and the shredder worked.
    Might this be a safety switch intended to stop the shredder from running when it is not sitting on the bucket?
    Something is still misbehaving: I don't see what would normally press this switch. and Why?
    Am I potentially damaging something by pressing this switch to make the shredder work?
    Patrick
    Thank you, Mike for your response.
    But it provides only part of the answer.
    I found the eighth screw hidden behind one of the labels -- opened the head, and found that a heavy black box (?a transformer?) had a broken mount. I glued and re-attached it.
    The red and green lights both lit up simultaneously when I turned the shredder switch on, but the shredder did not start. I jiggled the little chrome tab that is visible through the slot at the back, and found that when I pressed up on that tab, the red light turned off, and the shredder worked. So I don't think the gears are damaged.
    Then I realized that a little rectangular rubber washer that I had found tangled in the shredder blades had a hole just the right size to fit over the chrome tab/lever/switch. When I installed it there, and re-assembled everything, the shredder worked properly.
    I suspect that when my daughter-in-law vaccuumed a little too vigorously, she knocked it over, and this broke the transformer mount. When I lifted the head off the bucket to empty it, the transformer rolled around and knocked the rubber washer off the chrome switch.
Red on print is coming out pink
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
  3. Verify that only KODAK branded ink cartridges are installed.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door, then make the same print.
If issue still continues:
  1. Verify that inkjet paper is loaded in the paper tray.
  2. Press and hold Cancel + Copy/Resume simultaneously until the On/Off light flashes green. The On/Off light continues to flash during the cleaning procedure.
  3. When the On/Off light glows a steady green, press and hold Scan + Copy/Resume simultaneously until the On/Off light flashes, then wait for the demo sheet to print.
the printhead for your printer is in need of replacement. Contact Kodak
Best of Luck
Nov 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Not all the colors print
Best of Luck
Nov 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Poor black print quality black prints greenish grey
Best of Luck
Nov 16, 2009 | Office Equipment & Supplies
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Fellowes PS60C-2 shredder doesn't shred
there are two switches under the cutter area. 1 for sensing when your basket is full, (sometimes these bin-full flaps get stuck in the up position, energizing the switch) and the other is a switch that detects if your basket is installed. fellowes has modified these shredders so many times, that there are alot of different configurations. look for something that resembles a flap under the head and make sure its in the down position. as for the basket sensor, some baskets had 2 projections on the left and right top of basket. one may be broke. if so, you can "cheat" the switch with a screwdriver to see if thats the problem.
hth,
razors
Apr 14, 2009 | Fellowes PS60C-2 Shredder
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Fellowes PS60C-2 Shredder Logo
142 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
