Question about Crown CE2000 2-Channel Amplifier
No power from circuit board to fan - Crown CE2000 2-Channel Amplifier
What does flashing red LF mean on freezer
Kenmore Refrigerator Error Code = Er 1F
Error Condition = The fan for the ice compartment failed
Repair or Check = Icing fan blocked - ice fan motor is defective - wiring in the circuit is defective - control board has failed
Parts Needed = Ice fan motor - Wiring harness - Power control board
Kenmore Refrigerator Error Code = Er IF
Jul 05, 2017 | Washing Machines
What does LF flashing red mean
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Hi, I ahve a Rheem Classic Plus Series SUper Quiet 80 Unit and no air is blowing thru the vents but the inside/outside units kick on? can you help?
Is the inside fan running? If it is then check your air filter. If it isn't, turn off power to the inside unit and see if the fan turns freely by hand. Next check the capacitor for the indoor fan. Does the fan on this unit connect to a circuit board? Set the thermostat to make the air come on and check for power where the fast speed wire connects to the circuit board and neutral. If it's not there, the circuit board is probably bad. You can look at the back side of the board to see if any traces are burnt off. Let me know what you find.
Aug 13, 2010 | Heating & Cooling
I have found this unit overheating multiple times. Each time the coils were not totally frosted, but defrosted them with hair dryer and restarted. Unit runs fine for weeks. Last time, discovered the fan in...
Next time the fan stops check to see if the fan is being powered, if not the circuit board is likely the problem, if it does have power the fan may be faulty.
Nov 01, 2017 | GE DSS25KGT Side by Side Refrigerator
Fan and light not responding to remote
The power surge has burnt out the circuit board in the fan. It will cost more to get a new board if you can... then the fan is worth.
Replace the fan...
Heatman101
Feb 25, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Installed new stat and fan won't come on in heat made or cool mode.
Turn the thermostat switch that says fan on------auto to on an see if the fan comes on ,if don,t then the problem was the circuit board or find power wires going to the fan motor and jump it out to see if the fan motor is good or bad. then if it starts, then you,ve know ,you,ve eleminated the fan motor and its the circuit board...
Dec 08, 2009 | Intertherm P3RA-024K Air Conditioner
Clicking noise in the circuit board and everything in the freezer is thawed
Hi. this will be a failed relay on that circuit board. This is called the PCB(main unit power control board). This board controls the compressor relay functions, and the compressor power current, as well. The evaporator fan, and condenser fan, receives their respective current from this power control board, also. When a circuit board of this nature begins to malfunction, it will cause the unit to not cool properly, due to limited, or no fan actions, or a failed compressor cycle. I would recommend to replace this damaged control board, asap.
Dec 04, 2009 | GE Freezers
Rca p61310 power up for 15 seconds and the power light turns off
Hi, this is a faulty power board. i would replace this damaged circuit board. this Will fix this issue you are having at this moment with your unit.The reason for the on/off cycling fans is due to the power board controllers inability to open the main fan circuit, which shuts off the fans once you power down the unit.
May 18, 2009 | RCA P61310 TV
Moter will not cut off
is the thermostat set on fan on? Be sure the thermostat fan switch is all the way in the auto position..If you have a circuit board with a g terminal that is a gas furnace. Turn power off remove and isolate the green wire then turn power on. Let me know if it still runs. If it does not the circuit board is the most reasonable problem
Nov 14, 2008 | Intertherm P3RA-048K Air Conditioner
Crown CE2000 2-Channel Amplifier Logo
144 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
