Question about Porter Cable C6110 150 PSI 25 Gal OilFree Induction Vertical Portable Compressor
Trips breakers sometimes
May work just fine when kicks on. next time will trip breaker.Have on deciated breaer.
  • 1,498 Answers
Hi Triplet,
I know I'm not the first to try to help you. The way this site works, Those that try to help you cannot see any dialogue between you and previous providers.
I apologize for any redundancy you may endure.
To business.
Questions.
  1. When it trips the breaker, has it restarted to top off?
  2. Does it ever trip the breaker when empty?
  3. On the initial run, does it seem to bog down?
  4. Do the wires get hot?
I'm guessing No 2 is No and the rest are Yes.
Wear I'm going is either the wire gauge is too high (Gauge goes up, thickness goes down.)
You didn't mention how its connected. My first step would be making sure the power cable is at least 10ga. S type Heavy Duty power cord.
If I was correct, The Capacitor on the motor that gives it that extra nudge at startup may be going bad. The thicker cable can help there too.
Before I get to deep. let me fire this off to you.
Then maybe you can fill me in on whats been done. and of course the questions
Best regards
Mike
Posted on Jul 06, 2010
  • 1 more comment
  • triplets3 Jul 07, 2010
    mike ,where is the capacitor located? This unit when you turn it on whether partly empty or not may come on and work just fine The next time it tries to come on ,hums a few sac. and trips the breaker .I have it pluged in to deciated breaker. ITS AT THE OFFICE IM AT HOME.
  • Justin Case
    Justin Case Jul 07, 2010
    It would be on the motor. It will be under a protrusion on the housing that looks out of place.
    The plate covering it is normally about as long as a roll of quarters and twice as wide, held on with a screw.
    The capacitor will look like a 'D' Cell battery with two terminals on the top.
    Precaution: These are dangerous, even unplugged, they can hold a charge
    I had a pancake compressor doing the same thing. Hum pop.
    I added a second capacitor. Gave it enough of a kick to start turning. No more trouble.
    Mike
    thanks mike for info i will try it
Why are my circuit breakers rapidly tripping?
circuit breakers working indicates an overload of the circuit probably from a short in the wires or relays . Circuit breakers are resettable fuses and if you had fuses instead by now you would be hunting the fault as replacing the fuses all the time becomes a bore.
Apr 26, 2014 | 1999 Dodge Ram 2500 4WD
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
The garbage disposal & overhead sink fixture run to the same Square D Qob120 1pole 15amp 120v Circuit Breaker . After a week of consistentlu tripping, the breaker won't allow itself to reset. ...
I would start by replacing the breaker. If a new one trips then check ground and wiring. If it still trips then there must be a problem with the garbage disposal. let us know
Sep 21, 2010 | Square D Qob120 1pole 20amp 120v Circuit...
Have a package unit that is tripping the circuit breaker early in the morning, around 5 a.m. each day for the past few days. The blower fan motor was recently replaced, but it seems to work fine, all day...
Excessive current draw when motor first starts could and most likely does cause this breaker trip. I would check wiring connections to motor, check cold motor start up amperage draw, also breaker may be the issue (weak bimetal spring).
Jul 19, 2017 | Goodman GPC1342H21A Air Conditioner
Our washing machine will kick the breaker after sometimes 2 minutes of washing, other times it will go completely through the cycle. Another time it went 13 minutes and then kicked the breaker. Not sure...
What value breaker are you using?
Its also worth noting whether it is a 'B' type breaker or 'C' type.
For example you should have a breaker that says B6 or C10..
This could be different as Im in the UK but my sockets run from a B32 breaker.. 'B' Rated 32 amperes (amps).
I've noticed that the washing machine is a steam washer, so I'm assuming it has quite a big element inside to create the steam.
Now I'm not sure if this is tripping your breaker because its going over the maximum load for your breaker or if its tripping to to the inrush current.
The letter that goes before the fuse rating of your breaker (B or C) signals what surge the breaker can take when the equipment or machinery is switched on. If the surge is greater than the rated breaker it will trip.
B types are most commonly used in houses but a C rated breaker could be used if it kept tripping from the inrush current (the sudden surge when machinery is switched on or a heating element kicks in).
If you know any electricians I would get their opinion and see what they say, uprated breakers are quite cheap approximatly £5 in the UK.
It could be a few things but it doesn't sound like a fault on your washing machine as it should blow the fuse in the plug first..
I hope that helps
Mike
Nov 28, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Everything works fine, except when the compressor kicks in the panel breaker trips.
Most likely a short in the compressor electrical components (relay, overload,capacitor) Supco makes a 3 in 1 that you could use. If this works fine, if not "bad compressor".
May 27, 2009 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Electric Furnace Trips Breakers
it is normal for a breaker that is run right on the edge (50 amp and your furnance to use 45) to get weak after a while . the first thing you should do is change the breaker with the same type and amp rateing . it should take care if it
Jan 16, 2009 | Heating & Cooling
LG LRM2060ST trips circuit breaker sometimes
needs to have circuit of its own rated @ 20 amps powered by # 12-2-wg wire , also very good idea to plug into a good surge protector to protect its control board, as any computer the boards are very susceptible to spike voltage caused by lightning and power problems , as to how it worked before , breakers vary a little in the amount of current it takes to trip them with age , the number of time they have to be reset and heat they have been subjected to over a period of time so it is not unusual for say one 20 amp breaker to trip @ 16 and another @19 for example also the length of wire between the breaker and the appliance can effect the trip range
Jan 13, 2009 | LG Microwave Ovens
Porter Cable C6110 150 PSI 25 Gal OilFree Induction Vertical Portable Compressor Logo
73 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
