Question about Electronics - Others
What causes the prong on my RV electric plug to turn dark? Have replaced the plug because it looked damages but the new plug is starting to turn too.
  • 283 Answers
The plug is turning dark because of the heat generated by the electrical current running through it. This is common and nothing to be concerned about. However, if the plug is getting too warm, it is an indication that the wire size isn't adequate for the amperage and you may consider using a larger gauge wire.
Posted on Jul 07, 2010
I have a Kenmore Elite electric dryer model # 11063932102 that will not start. It was in storage for five months and it had some superficial mice issues on the body, which cleaned up nicely, but now it...
Did you replace just the plug end of the existing cord or the entire cord/plug cable at the dryer connection? You cannot just replace the plug end since the 4th connection is not made it won't work. The easiest solutiuon is to use a 3 to 4 prong adapter. See this video that explains it.
http://www.youtube.com/watch?v=ZBJhkyHSCmo
Nov 02, 2014 | Dryers
Why is New Samsung computer battery not detected?
Step 1:
Computer Won't Recognize a Battery While desktop computers are plugged directly into an electrical outlet to obtain power, laptops rely on a battery and power cord in order to be charged. If your laptop suddenly stops recognizing this battery pack, however, it could jeopardize your ability to charge your computer and ultimately work on it at all.
Inspect the Battery With the battery unplugged, carefully examine your laptop's battery, both the battery unit itself and any cords or plugs attached to it. Make sure the battery's case is not cracked or damaged. Look for fraying cords and bent prongs on the plug. Any of these issues could cause internal damage to the battery itself, the cable or the plug, which could interrupt the flow of electricity between the battery or electrical outlet and your laptop. If your laptop is still under warranty, you may be able to get a free replacement for a damaged battery or cable. b> Check The Port b> Damage to the port on the back of your laptop the one into which you insert the power cord could cause your laptop not to recognize your battery or any cables attached to it. Turn off your laptop and turn it around so you have a clear view of this port. Using a flashlight to illuminate the port, inspect it for any dirt or debris that may have become jammed inside; gently remove any debris with a small cotton swab. A bent prong could also interrupt the circuit, making it difficult for the battery to transfer energy from the power cord to the laptop; straighten a bent prong using needle nose pliers. Avoid making invasive repairs, especially if your product is under warranty; any damage you do to the laptop in an effort to fix it could nullify the terms of your warranty. b> Wrong Kind Of Battery b> Some brands of laptops, such as Dell, will not recognize a battery that wasn't manufactured by the same company. To make sure that your battery is compatible with your laptop, consult your laptop's user guide for battery specifications (these will vary based on make and model of your laptop). b> Dead Battery b> Laptop batteries have a limited lifespan. After so many charges, they may be unable to transfer enough power from your electrical outlet to your laptop. When your battery reaches this point, a replacement may be your best option. b> Laptop Update b> Updating the "BIOS" on your laptop can help the unit better detect and recognize external hardware such as a battery. BIOS which stands for Basic Input/Output System assists in booting up your laptop, and helps run every function until you turn it off. Computer manufacturers release BIOS updates for their products routinely; these updates can be downloaded from the company's website as ".exe" files. Run and save this update on your laptop, then restart it to see if your laptop now recognizes the battery. Mac users can reset the laptop's System Management Controller (SMC). Apple reports that sometimes, otherwise unexplained errors pop up in the laptop's system, including problems with the battery's ability to charge. To reset the SMC, turn off the laptop and remove the battery. Hold down the "Power" button for five seconds and release before plugging the battery back in and turning the laptop on.
b>
Feb 07, 2013 | Samsung N210JA02 Netbook
Power problem "New TV"
If totally dead (both wall current and voltage from RV---someone has to open it to see if fuse/s bad---it will have one for wall voltage (AC) and another for RV voltage (DC) and sometimes also a third in the 12 volt lighter plug if using one.
Another possible reason would be the set has been damaged---the circuit board may have been damaged/cracked and needs repair.
Mar 19, 2012 | Initial DTV-172 17 in. TV/DVD Combo
I have a 1999 F250 Super Duty Lariat Super Cab 7.3L diesel.The wiring for the tow hitch is 4 prong flat with 3 extra wires.What was included from the factory and\r\nwhat do I need to pul camper with rv...
With 4 prong and 3 extra, that will give you what you need for 7 prong for towing RV. If your not too experienced in that area, a mechanic at any trailer place, or hitch installation place or who knows RV wiring, should be able to do it for you in about 1/2 hr. or less. Testing the wires from your truck for what they do as in right , left, stop, running/taillights, etc is about the hardest part, and the 7 prong usually comes with what terminal does what.48e2ffb.jpg
Jun 10, 2010 | 2002 Ford F250 Super Duty SuperCab
Dryer stops
Unplug your dryer plug. Go to your house electric panel, turn off your 30 amp dryer breaker, and then turn it back on. This resets the breaker. So before opening up the dryer to look for fuses, make sure you have power at the receptacle. Don't plug anything into the receptacle until you have wired it correctly. If you want to run it by me when you're wiring it, that's fine with me. . I hope this helps. Good Luck! Jim
Mar 16, 2010 | GE DBSR453EBWW Electric Dryer
Intermittently Drying Problems, Electrical?
It could possibly be electrical, check for 240V at the supply side. The only other possibility could be plugged dryer venting, although it would be unusual for it to cause only intermittent problems. The reason the timer would stop turning (mechanical timer) or counting down (digital display), is because on any Auto-dry, (ones that use the moisture sensor) the dryness of the clothing dictates when the timer should count down or advance. Check for good airflow from the outside exhaust point, if that's ok, I would be possibly looking at the outlet for possible loose contact, look at the dryer cord prongs and see if there are dark marks on them, as this may point to a sloppy outlet causing arcing.
Nov 28, 2009 | Frigidaire Electric Dryer
The electric burner elements on my whirlpool Super Capacity 365 stove often won't heat. They seem corroded on one tip and the socket they go into looks dark. Can I simply replace them?
YES YOU CAN . FIRST TURN OFF THE POWER TO RANGE , THEN LOCATE THE SCREWS ALONG THE SIDES OF THE TOP REMOVE AND YOU SHOULD BE ABLE TO SEE THE ELEMENTS AT THE END OF EACH ONE THERE IS A TWO PRONGED CONNECTION REMOVE ELEMENTS FROM THESE PULL OUT TAKE ALL THE ELEMENTS TO AN ELECTRICAL AND PLUMMERS SUPPYLY STORE FOR REPLACEMENTS, REFIT NEW ELEMENTS AND YOUR COOKER SHOULD WORK FINE , GOOD COOKING .
Nov 17, 2009 | Whirlpool RF364 Electric Kitchen Range
I have a delta dc-380 planer that has a 3-prong plug (looks to be modified by last owner) and I have a 4-prong plug where my dryer is. Can you help me to re-wire the planer for a 4-prong plug? thanks in...
Is it a single phase motor model 22-680, or a three phase motor model 22-681. The single phase motor will have a 3 prong outlet where the blades are in tandem and the ground is longer than the blades so it is grounded before electricity gets to the planer. A three phase motor will have to be wired directly to your house electricity without a power cord. You will have to get an electrician to hook that up so you are within the building codes of your area.
You can get a 4 prong dryer plug from home depot and wire it. I think they cost about $15 or so. Just remove the old cord and wire the new one the same way that the old cord had been wired, black to black, white to white, and red to red. Ground the green wire to a grounded screw inside your switch box. Turn your breaker off before you plug in the new cord just in case you wired it incorrectly. Then turn the breaker back on. This way the breaker will trip immediately and you will not damage anything, MAINLY YOURSELF. 220v is nothing to sneeze at. And if you feel at all uncomfortable doing this you should probably get someone qualified to rewire it. Be safe.
Oct 15, 2009 | Delta Tools & Hardware - Others
Compresser tries to kick on but wont
You have a bad start capacitor and the three prong device san be replaced by buying on line or going to a RV dealer and buying the three prong compressor start switch, it pulls out has three holes in it the shape of a triangle if it has a bad start capacitor you can buy one that will replace it without taking out the old capacitor. If you want a web site where they sell these post on this answer and I will send you the address of the parts store that sells them.
Jul 15, 2009 | Dometic Rooftop RV Air Conditioner
Elkectric dryer won't start
to put it kindly depending on way you connected wires unit could be damaged,replace pigtail with three wire and outlet to original.outlet wires should be black,red and white. turn breaker off attach white to middle and red,black to sides,"either side is fine".Attach dryer pigtail in same manner with white on white and if plug in and turn breaker on.If there is no operation at this point dryer possibly damaged from previous wiring.Just remember be safe when working with electrical and ask before trying to change things that aren't the same.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
Electronics - Others Logo
142 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
