Question about Craftsman 14.4 volt Cordless Drill/Driver with Work Light
Need to replace 14.4 powe drill
Need to replace 14.4 power drill
    Novelist:
  • 145 Answers
I recommend replacing your drill and light with an 18V Ryobi "One+" Drill and light from from the home depot. It outperforms any battery powered drill I have ever used. You can also get it with lithium batteries that will last twice as long.
Posted on Jul 06, 2010
I need to replace the transformer inside my 12 volt charger. I can not find who makes the ES -66-287rev5 transformer. Need help.
If you have the skill to determine the transformer input is open, I would expect you have the skill to replace a transformer. Based on this assumption: determine the input voltage (120 vac?), determine the output voltage (14 vac?), determine the power requirements (output voltage times the charging current), find a transformer at www.digikey.com or www.mouser.com or www.newark.com.
Sep 15, 2014 | Drills
My spindle slide out of the drill press. I remove spindle to clean , what did I do wrong.?
Please look at this site:
http://www.ebay.com/itm/DELTA-MILWAUKEE-14-Drill-Press-DP-220-Instructions-Parts-Manual-0239-/310388408599
This site has pictures that might help:
http://www.ebay.com/sch/sis.html?_kw=Vintage+Delta+14%22+Drill+Press+DP220+%22Triple+Duty%22+Bench+Model+Tilt+Table
Jan 23, 2013 | Delta Woodworking Vintage Delta Dp 220 14"...
NEED SERVICE MANUAL FOR MilwaukeeDD2160XE
You can get a parts drawing from http://www.milwaukee-et.com/int%5Cint_opmanual.nsf/vwSparePartsSearchResults?OpenView&ExpandView=1&nav1=ps&Count=30&StartKey=DD2-160XE# Brushes are aboout 14-15 a pair 4931392581
Nov 30, 2012 | Drills
No turn on
pow pow pow pow
check all 4
power circuit breaker at panel power cord power outlet on wall
power switch on unit
Jul 11, 2012 | Amcor KF 9000 BTU Silver Portable Air...
What are the benefit of use drill EY6409 12V
THE NUMBER ARE FOR PUT THE DRILL IN A MODE TAHT CAN HANDLE LOW POWER SPIN ENDS OR HIGH.LET SAY YOU WANT TO DRILL A TAP-CON YOU WILL NEED LIKE SAY 14 IN THE SCALE OR IF THE SCREW IS FOR A PIC HANDLING THEN A 6 WILL DO THE JOB.JUST TRY DIFFERENT NUMBERS TO GET THE FILL.
Mar 19, 2012 | Panasonic Ey6409 12v 12" Cordless Drill...
Dc925 drill just stopped working no powe
i would imagine its the trigger or battery conections on the drill. How much for it lol
Mar 28, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
I have an old Delta D-220 drill press. While the chuck spins true, even at high speed, a drill bit will have a slight wobble towards the end of the bit. I tried many bits so its not a bent bit. Solutions? ...
You are right,but if the wobble is not too big to do drill jobs it can be used.Sometimes drill jobs need to be precise,so the you will need it just aligned.
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams or go direct to this link.
Good price and service.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 15, 2010 | Delta Woodworking Vintage Delta Dp 220 14"...
How do i de restrict my kmx125
i am led to beleev that restricting a kmx is simply taking off the earth wire for the power valve if you could find a diagram of the pow val system or if you have the haynes manual then earth the pow val if the pow val is working then i cnt help gd luck m8
Apr 08, 2010 | 2000 kawasaki KMX 125
My new Black Max 24v drill charger will not charge the battery
You indicate that the drill is new. I'd suggest you return it for a replacement. Seems to be a defective or wrong charger. If you have problems and If you paid by credit card call the card company and have them stop payment on that charge.
Feb 21, 2010 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
Makita 18volt 6347 cordless drill
then you need transmision assy. item 14 in breakdown
see toolpartsdirect.com for further info on your drill
Mar 28, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Craftsman 14.4 volt Cordless Drill/Driver with Work Light Logo
93 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
