Question about Creative Labs Creative Technology Zen MP3 Player
Locks up while playing
It has locked up 4 times while playing the last couple of days and it is new. What could be causing this.
  • 178 Answers
Try to update the firmware, creative has a recovery tool to do this.
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp?
Install the recovery tool on your pc and connect the player to your
computer and run the recovery tool.
Posted on Jul 08, 2010
Installed 4 locks two lock work smoothly, two locks whenthe key is inserted it will not turn unless yo pull the key out a hair then it works fine.
David, this sounds like a tolerance issue. Some less expensive locks can exhibit what you are experiencing.
Your description sounds like a key/pin issue. A key maker could alter a new key to eat up that "hair", but the may not work in the other two locks.
You could always return the locksets for another set. I would not want to modify or do "stuff" to new locks.........
A Schlage lock, for example, is tighter tolerance and that means tougher to pick, and (usually) much better performance day in and day out.
Oct 28, 2016 | Kwikset Locks & Locksmithing
Chev impala sometimes while driving the auto. door locks start clicking for a couple of times then stop. what, s going on?.
Most times it is corrosion at the plug on the BCM(body control module). A couple times is was the BCM. A couple times the door lock switch, but they were really loose. The springs broke down and let make contact to unlock. The reason it locks is the BCM see the car is moving and locks them.
Feb 20, 2016 | 2002 Chevrolet Impala
Why does my scrabble complete game hang up all the time using windows 7
When it locks up like that, it means you've got a virus that slows things to the point of aggravation. Just reinstall your Operating system and you'll get back to new again. Make sure you JUST replace the OS and it will leave everything else in tact. It's easy to do, just takes time for the fresh install. Patience is required.
Sep 09, 2014 | Infogrames Scrabble Complete for Windows
Fuse burn out all the time. Interior light, door locks, trunck relese and radio.
Check what circuits are connected around this fuse, then check each one, test voltage and wire connections.
Good luck.
Jan 03, 2014 | Chrysler Concorde Cars & Trucks
My brinks 4-dial combination padlock will not open
Add my solution??? Cut the lock off and don't buy another brinks lock. I bought two of these combination locks. Over priced and over rated. I bought one for our locker at work. After about a month it refused to open. After working with it for days I finally had to cut the lock off. I bought another one. It didn't even last a week. After working with this lock again we had no choice but to cut the lock off. Being a retired locksmith of 20 years I know locks. These are worthless.
Sep 25, 2012 | Brinks 4-Dial Combination Padlock
F4 fault with Vizo Plus 24. Not condensation tube as this was changed to new tube with sensors on ''blue plug'' by engineer last year when I called them out for re-curring F4 fault - new sensors are bone...
Hi, if the ignition module fires or tries to fire 4 times, this indicates the module is faulty and locks out for safety reasons because of an internal fault.The f-4 code sounds like the pressure switch was open due to condensation not letting it fire up, so the switch was ok, so they changed out the tubing. When you re-set the boiler control module, it locks out due to a internal fault. Change it out and you will be back up and running. The electrodes from the module will cause this as they come from the module. Make sure the condensate trap has no blockage at all as this can cause this problem. I am not guessing, I would replace the boiler module control that you have been re-setting. Keep me posted,
Sincerely,
Shastalaker7
Mar 18, 2010 | Heating & Cooling
My door locks are making a buzzing sound
Spray as you can , (inside, upside down, downward) the latches, & Locks, down in the handles etc , with penetrant and keep working them. After loosened up , try getting a spray grease in there too, like white lithium grease in aerosol. Sounds like latches are getting partially seized/sticky, and causing electric motor on locks to spin a bit. I've had to remove door panels to really get them loosened up & greased, but you may get lucky
Nov 20, 2008 | 2000 Dodge Durango
Driver's side door power locks are stuck; door stuck shut.
sounds like the rods are disconnected the clips hold the rods in place the latching mechanism holds the handle in place as well did you replace the speakers or did a shop? if a shop did then they caused this if you did then you may have caused this either way untill you reattach the rods none of it will work. you will have to manually open the door at the latch from inside teh door behind the panel.
Jul 16, 2008 | 1993 Ford Mustang
Creative Labs Creative Technology Zen MP3 Player Logo
128 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
