Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp AR-5127, the error code U2-40
I have the copier machine Sharp AR-5127, the error code U2-40 appears and coping cannot be done. I tried what you wrote before but it didn't work
I don't have a [Image Quality] key. I have [Auto Image] key and 14 can be entered directly without pressing 10 + 1 + 1 + 1 +1
  • 4 more comments
  • Anonymous May 02, 2008
    I have sharp AR 5127 it's new when i installed and put it on no coping it just come white paper
  • memo00212 Jun 09, 2008
    I have the same problem for sharp AR-5127 and it shows error code u2-40 and when i try to do what u told us here it doesn't work and the machine doesn't start just shows the same error code and there is no image quality button just auto image button
    i will appreciate your reply
    regards
  • POWERNET Jun 10, 2008
    NEW SHARP AR-5127 DISPLAYS EROR MESSAGE CALL FOR SERVICE L1-00
  • sirbigbust Jul 14, 2008
    the u2-40 is a problem i dont even have an idea of how to solve it.
  • woodyssupply Feb 20, 2009
    All action stops in copier. A U2-40 error code appears in window. Nothing seems to help or remove error code, including the C-CA-Interrupt-CA sequence.
    AggieJack
  • Anonymous May 06, 2009
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127
PRESS #
PRESS =
PRESS C
PRESS =
TYPE 16
PRESS ENTER BUTTON (the button for making photocopy)
PRESS 'OK' TWICE
Note: be fast in pressing all the buttons.
FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
Posted on Oct 20, 2011
Posted on Feb 22, 2010
    President:
  • 2,072 Answers
Uf that doesnt work try replacing the toner cartridge.Frequently the microchip on the back of the toner cartridge fails or does not seat well.
Try a toner cartridge. That will most likely cure if a reset 14 wont. Yeah the auto image key is the same. Just the process I posted is for a different version of the same machine.
Posted on Apr 18, 2008
  • Rick Kasper Apr 18, 2008
    You press Clear, then Auto, Clear Auto twice in succession, the display should go blank. Then as you say, press the 10s button and the 1 ,,4 times until it displays 14 and press start for the reset.
  • Adeshina Oluwarotimi
    Adeshina Oluwarotimi Feb 19, 2012
    What is the problem of machine showing E 7
I have a 5127c sharp copier
an error code appear : e1-15 than e1-88
i don't know how i find the solution but think god it works
and now an other erreur code appeared : e5-02
can you help me
Posted on Sep 16, 2011
To clear U2 codes, try this: pound key, star key, clear key (not clear all), star key, punch in 1 and 6 (as in 16), start key, answer yes, start key and wait a moment or two. We have a Sharp MX M450U at the office. My service tech said UR codes are a motherboard glitch and this will clear them. At least it worked for him when he showed me how to do it.
Posted on Dec 30, 2009
  • tdebolt Dec 30, 2009
    Sorry -- I meant to say that my service tech said U2 codes are a motherboard glitch and not "UR" codes.
  • Sharp Expert
  • 316 Answers
L1 00-Thescanner does not complete feeding in thespecified time
Posted on Apr 12, 2011
Had the same problem. ensure that the screw that holds the dev box in position is fastened and clear the code using sim 16. for more details contact muchjerry@yahoo.com
Posted on May 09, 2008
2 Suggested Answers
  • 61 Answers
SOURCE: Sharp AR-5127, the error code U2-40
U2-40 is a board error, F1-15 is finisher lift motor error.
To reset: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, print, are you sure? , yes.
For the finisher error, follow above procudure, entering 14 instead of 16. if error returns, disconnect the finisher
Posted on Nov 28, 2008
I have the copier machine Sharp AR-5127, the error code H4-00 appears and coping cannot be done what do i do
The heating element or the thermal fuse in the fuser unit has failed. Try pressing clear,interupt, 0, interupt, 1,4, the blue copy button to reset it.
May 23, 2012 | Office Equipment & Supplies
Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Feb 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Error code sharp 5127
go to percision roller in phx arizona you can get all sharp service manuels i have alos seen them on ebay?
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Nov 26, 2008 | Office Equipment & Supplies
Error messsage cal for service E1-88 from sharp AR-5127
Unplug the Machine, remove the board you installed, re-seat the board,
make sure everything is connected, turn machine back on..
This is what the Manual says:
IMC PWB communication trouble (Timeout)
Check the connectors of the IMC PWB
and MCU PWB.
Check the grounding of the copier.
If you need further help let me know..
Oct 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
8,438 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
